ESP32-C6 spi slave
illglu
ESP32-C6 spi slave
Postby illglu » Tue May 14, 2024 4:28 pm
Hello.
Hardware: ESP32-C6 (dev board or any custom boards)
Software: spi slave exsample
Docs says: When an SPI Host is set to 80 MHz or lower frequencies, routing SPI pins via GPIO matrix will behave the same compared to routing them via IO_MUX.
But in reality, when MOSI or MISO or SCLK connected to any other (not IO_MUX) pins, then speed 20Mhz or higher is not working (too many errors).
ESP32-C3 and S3 was tested also - everything works fine, problem detected with C6 only.
It will be fine, if it can be fixed.
Users browsing this forum: PerplexityBot and 3 guests
