Set Workspace folder
column
Postby column » Tue May 21, 2024 9:25 am
0
I have created ESP project from sample template with ESP-IDF extension in Visual Studio code. As result I have project folder that contains besides source code and other configuration files folder .devcontainer with devcontainer.json and Dockerfile files. I suppose I need to create container and run project inside of it. I do View->Command Palette->Reopen in Container
I got error message:
Visual Studio Code
Workspace folder in devcontainer.json must be an absolute path.
[Open devcontainer.json] [Cancel]
What is wrong with my project configuration? How to solve this problem?
Whole devcontainer.json
// For format details, see https://aka.ms/devcontainer.json. For config options, see the README at:
// https://github.com/microsoft/vscode-dev-containers/tree/v0.183.0/containers/ubuntu
    "name": "ESP-IDF QEMU",
    "build": {
        "dockerfile": "Dockerfile"
    // Add the IDs of extensions you want installed when the container is created
    "workspaceMount": "source=${localWorkspaceFolder},target=${localWorkspaceFolder},type=bind",
    /* the path of workspace folder to be opened after container is running
    "workspaceFolder": "${localWorkspaceFolder}",
    "mounts": [
        "source=extensionCache,target=/root/.vscode-server/extensions,type=volume"
    "customizations": {
        "vscode": {
            "settings": {
                "terminal.integrated.defaultProfile.linux": "bash",
                "idf.espIdfPath": "/opt/esp/idf",
                "idf.customExtraPaths": "",
                "idf.pythonBinPath": "/opt/esp/python_env/idf5.3_py3.10_env/bin/python",
                "idf.toolsPath": "/opt/esp",
                "idf.gitPath": "/usr/bin/git"
            "extensions": [
                "espressif.esp-idf-extension"
        "codespaces": {
            "settings": {
            "extensions": [
    "runArgs": ["--privileged"]
edwin.sun
Re: Set Workspace folder
Postby edwin.sun » Thu Jun 20, 2024 8:11 pm
As mentioned in the error:
You need to fill in this field
specifically: "${localWorkspaceFolder}" with the path to the workspace.
Users browsing this forum: Bytespider, ChatGPT-User, Qwantbot, Semrush [Bot] and 6 guests
