Set Workspace folder
Posted: Tue May 21, 2024 9:25 am
0
I have created ESP project from sample template with ESP-IDF extension in Visual Studio code. As result I have project folder that contains besides source code and other configuration files folder .devcontainer with devcontainer.json and Dockerfile files. I suppose I need to create container and run project inside of it. I do View->Command Palette->Reopen in Container
I got error message:
Whole devcontainer.json
Visual Studio Code
Workspace folder in devcontainer.json must be an absolute path.
[Open devcontainer.json] [Cancel]
What is wrong with my project configuration? How to solve this problem?Code: Select all
// For format details, see https://aka.ms/devcontainer.json. For config options, see the README at:
// https://github.com/microsoft/vscode-dev-containers/tree/v0.183.0/containers/ubuntu
"name": "ESP-IDF QEMU",
"build": {
"dockerfile": "Dockerfile"
// Add the IDs of extensions you want installed when the container is created
"workspaceMount": "source=${localWorkspaceFolder},target=${localWorkspaceFolder},type=bind",
/* the path of workspace folder to be opened after container is running
"workspaceFolder": "${localWorkspaceFolder}",
"mounts": [
"source=extensionCache,target=/root/.vscode-server/extensions,type=volume"
"customizations": {
"vscode": {
"settings": {
"terminal.integrated.defaultProfile.linux": "bash",
"idf.espIdfPath": "/opt/esp/idf",
"idf.customExtraPaths": "",
"idf.pythonBinPath": "/opt/esp/python_env/idf5.3_py3.10_env/bin/python",
"idf.toolsPath": "/opt/esp",
"idf.gitPath": "/usr/bin/git"
"extensions": [
"espressif.esp-idf-extension"
"codespaces": {
"settings": {
"extensions": [
"runArgs": ["--privileged"]
