ESP32C3 USB CDC Handler
baotd_innova
Postby baotd_innova » Wed May 22, 2024 1:57 pm
I am using ESP32C3 USB CDC to handle data but I am encountering a problem after Set config Log Output: No output, then esp32-c3 does not respond. I have researched a lot but found nothing about this problem.
Code ESP32C3
#include "usb_serial.h"
#include "sdkconfig.h"
#include "freertos/task.h"
#include "esp_system.h"
#include <fcntl.h>
#include "driver/usb_serial_jtag.h"
#include "esp_vfs_usb_serial_jtag.h"
#include "hal/usb_serial_jtag_ll.h"
#include "esp_vfs_dev.h"
#include "mi_processes.h"
#include "esp_err.h"
#include "esp_log.h"
#include <stdio.h>
#include <stdio_ext.h>
#include "driver/gpio.h"
#define PIN_VBUSMONITOR 8
#define DEBUG_USB_DATA 0
bool send_usb = false;
static void Receive_callback(void *argument);
void init_usb_serial(void)
    // init GPIO detect USB
    gpio_set_direction(PIN_VBUSMONITOR, GPIO_MODE_INPUT);
    /* Disable buffering on stdin */
    setvbuf(stdin, NULL, _IONBF, 0);
    /* Minicom, screen, idf_monitor send CR when ENTER key is pressed */
    esp_vfs_dev_usb_serial_jtag_set_rx_line_endings(ESP_LINE_ENDINGS_CR);
    /* Move the caret to the beginning of the next line on '\n' */
    esp_vfs_dev_usb_serial_jtag_set_tx_line_endings(ESP_LINE_ENDINGS_CRLF);
    /* Enable non-blocking mode on stdin and stdout */
    fcntl(fileno(stdout), F_SETFL, 0);
    fcntl(fileno(stdin), F_SETFL, 0);
    usb_serial_jtag_driver_config_t usb_serial_jtag_config;
    usb_serial_jtag_config.rx_buffer_size = 1024;
    usb_serial_jtag_config.tx_buffer_size = 1024;
    esp_err_t ret = ESP_OK;
    /* Install USB-SERIAL-JTAG driver for interrupt-driven reads and writes */
    ret = usb_serial_jtag_driver_install(&usb_serial_jtag_config);
    if (ret != ESP_OK)
        return;
    /* Tell vfs to use usb-serial-jtag driver */
    esp_vfs_usb_serial_jtag_use_driver();
    xTaskCreate(Receive_callback, "usb serial callback", 4096, NULL, 5, NULL); // receiving commands from main uart
bool get_connect_usb(void)
    return gpio_get_level(PIN_VBUSMONITOR);
    enumMsgRecState msg_rx_state = MSG_WAIT_FOR_CMD;
    // char c[10];
    char c;
    static uint8_t check_sum;
    static uint16_t rx_len;
    VBUS_MSG msg;
    const int in_fd = fileno(stdin);
    for (;;)
        if(usb_serial_jtag_read_bytes(&c, 1, 0) > 0)
            #if DEBUG_USB_DATA
            printf("char received = %X \n",c);
            #endif
            switch (msg_rx_state) {
            case MSG_WAIT_FOR_CMD:
            case MSG_REC_SIGNATURE_1:
            case MSG_WAIT_FOR_EXCEPTION:
                if (c == MSG_SIGNATURE_1) {
                    check_sum = c;
                    msg_rx_state = MSG_REC_SIGNATURE_2;
                    #if DEBUG_USB_DATA
                    printf("MSG_WAIT_FOR_CMD");
                    #endif
                else {
                    msg_rx_state = MSG_WAIT_FOR_EXCEPTION;
            case MSG_REC_SIGNATURE_2:
                msg.MsgID = c;
                check_sum += c;
                msg_rx_state = MSG_REC_LOW_BYTE_LEN;
                #if DEBUG_USB_DATA
                printf("MSG_REC_SIGNATURE_2");
                #endif
            case MSG_REC_LOW_BYTE_LEN:
                rx_len = 0;
                msg.MsgLen = c;
                check_sum += c;
                #if DEBUG_USB_DATA
                printf("MSG_REC_LOW_BYTE_LEN");
                #endif
                if (msg.MsgLen > 0) {
                    msg_rx_state = MSG_REC_DATA;
                else {
                    msg_rx_state = MSG_REC_CHECKSUM;
            case MSG_REC_DATA:
                msg.MsgParamBuf[rx_len] = c;
                check_sum += c;
                rx_len++;
                #if DEBUG_USB_DATA
                printf("MSG_REC_DATA");
                #endif
                if (rx_len < msg.MsgLen) {
                    /*Continue receive until get full msg data*/
                else {
            case MSG_REC_CHECKSUM:
                #if DEBUG_USB_DATA
                printf("MSG_REC_CHECKSUM");
                #endif
                #if DEBUG_USB_DATA
                printf("check_sum = 0x%X", check_sum);
                #endif
                if (check_sum != c) /*Wrong check sum*/
                else {
                    msg_rx_state = MSG_WAIT_PROCESSING;
                    set_usb_send();
            case MSG_WAIT_PROCESSING:
            default:
            if(msg_rx_state == MSG_WAIT_PROCESSING)
                #if DEBUG_USB_DATA
                printf("MSG_WAIT_PROCESSING");
                #endif
                Proc_Battery(&msg);
        vTaskDelay(pdMS_TO_TICKS(20));
void set_usb_send(void)
    send_usb = true;
void reset_usb_send(void)
    send_usb = false;
bool get_mode_usb(void)
    return send_usb;
static void flushWrite(void) {
    if (__fbufsize(stdout) > 0) {
        fflush(stdout);
    fsync(fileno(stdout));
void usb_send(uint8_t* buffer, uint32_t len)
    const int out_fd = fileno(stdout);
    write(out_fd, buffer, len);
    flushWrite();
    printf("\n");
//     usb_serial_jtag_write_bytes(buffer[, len, 0);
//     usb_serial_jtag_ll_txfifo_flush();
ESP-IDF : v4.4.7
Thank you for your support.
Users browsing this forum: Baidu [Spider], Bing [Bot], ChatGPT-User, Qwantbot and 2 guests
