vtaskdelay() causes the GPIO# assigned in esp_sleep_enable_ext0_wakeup(GPIO#, high) to immediately go high. (Behavior is observed via o-scope.) When the device goes to deep sleep, the device is immediately awaken with the wakeup cause "ext0 wakeup".
Removing the vtaskdelay() function, the GPIO# is remains low as designed. (Behavior is confirmed via o-scope.) This allows the expected "ext0 wakeup" in deep sleep to work properly, which the GPIO# is transitioned to high. (Behavior is confirmed via o-scope.)
Please advise how to make ext0_wakup work properly with vtaskdelay().
Thanks.
ESP32S3, deep sleep wakeup and vtaskdelay()
jjones7432
Re: ESP32S3, deep sleep wakeup and vtaskdelay()
I doubt that's actually what's happening, given that vTaskDelay has absolutely nothing to do with interrupts, wakeup sources or GPIO. Can you post the code that replicates this?
jjones7432
Thanks for replying.
As you suggest, after more testing, it doesn't appear to be vTaskDelay() associated.
There are two deep sleep wakeups:
1. wakeup_ext0 - This wakeup if from a sensor driving GPIO1 to force a wakeup. This wakeup is behaving as expected, performing some operations, clearing the sensor, resetting the two wakeups and going back to deep_sleep. wakeup_ext0 is not triggered unless we deliberately trigger the sensor.
2. wakeup_timer - Our problem occurs during the processing. This wakeup is triggered when the time period expires and does a lot of wifi operations. We ensure that GPIO1 is not active before the device resets both wakeups and goes to sleep. However, GPIO1 goes active immediately and wakeup_ext0 is triggered. Wakeup_ext0 finishes and does not trigger again, since GPIO1 is not triggered by the sensor.
We only have these "false" triggering during the timer_wakeup and it's only once per timer_wakeup. Both wakeups run through the same GPIO setup.
Not sure what we can post to show the behavior. The o-scope only shows that the GPIO1 was low before going to sleep but went active during sleep for the wakeup_timer.
Any suggestion is appreciated.
Users browsing this forum: Bing [Bot], ChatGPT-User, PerplexityBot and 3 guests
