Help with using cURL in ESP32 Project
souler
Postby souler » Sun May 26, 2024 1:23 am
Hello, I'm working on an ESP32 project and having some trouble integrating cURL.
Initially, my project structure looked like this:
Project
├── MyLibs/
│   ├── rol.h
│   ├── web.h
│   ├── APImain.h
├── second/
│   ├── Rol/
│   │   ├── roles.c
│   │   └── CMakeLists.txt
│   └── API/
│       ├── APImain.c
├── main/
│   ├── main.c
└── CMakeLists.txt
I had some problems getting my project to detect curl, so to make it work I added the curl folder to my project:
Project
├── MyLibs/
│   ├── cURL/
│   │   ├── include/
│   │   │   ├── curl/
│   │   │   │   ├── curl.h
│   │   │   ├── lib/
│   │   │   │   ├── libcurl.a
│   ├── rol.h
│   ├── web.h
│   ├── APImain.h
├── second/
│   ├── Rol/
│   │   ├── roles.c
│   └── API/
│       ├── APImain.c
├── main/
│   ├── main.c
└── CMakeLists.txt
This change works fine for me but now I have the problem that it does not detect some curl functions:
undefined reference to 'curl_easy_init'
undefined reference to 'curl_easy_setopt'
These are some examples, in my APImain.c file I have this:
  #include "cURL/include/curl/curl.h"
I tried adding things to the CMake files but despite several tests I still get the same error
c:/users/luis_/.espressif/tools/xtensa-esp32-elf/esp-12.2.0_20230208/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/12.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(APImain.c.obj):(.literal.POSTdata+0x3c): undefined reference to `curl_easy_init'
I was thinking if I should add the curl folder or files to the expressif tools.
MicroController
Re: Help with using cURL in ESP32 Project
Postby MicroController » Sun May 26, 2024 11:57 am
That's the right approach. Make sure you define the include paths correctly and include cURL's sources in the build, or if you already have the lib precompiled for your ESP tell the linker that you want it linked in, see e.g https://docs.espressif.com/projects/esp ... components
Alternatively, you can look into doing away with cURL and just use the ESP-IDF HTTP client.
souler
Postby souler » Mon May 27, 2024 5:15 am
I downloaded curl from the website, specifically cURL 8.8.0 for Windows. My understanding is that the .a files indicate that it is a precompiled version since the lib/ folder contains libcurl.a and libcurl.dll.a.
What should I put in the cmake files? Should I add instructions to the root cmake file?
in cmake root
cmake_minimum_required(VERSION 3.16)
project(ProyectoESP)
in cmake from APImain.c
idf_component_register(SRCS "APImain.c"
                      INCLUDE_DIRS "." "../../MyLibs"
                  REQUIRES  MyLibs )
and cmake from main.c
idf_component_register(SRCS "main.c" "../second/Roles/roles.c"  "../second/API/APImain.c"
                            INCLUDE_DIRS
                                    "../MyLibs"
                                    "../MyLibs/cURL"
When it starts to fail the first thing that appears is this:
[2/4] Linking CXX executable ProyectoESP.elf
FAILED: ProyectoESP.elf
I have modified the cmake files several times to indicate the curl path but I always return them as I showed before because I get other problems and I am new to using cmake
MicroController
Postby MicroController » Mon May 27, 2024 12:12 pm
is of no use for an ESP32.
Users browsing this forum: Baidu [Spider], ChatGPT-User, meta-externalagent and 3 guests
