I had thought that I could use USB jtag on the esp32s3 board to get it into 'download mode'.
If I run this python code snippet, implementing the approach in section 33.4.2 of esp32s3 TRM v1.4:
with serial.serial_for_url(args.port, args.baud, do_not_open=True) as serial_instance:
serial_instance.dtr = False
serial_instance.rts = False
serial_instance.dtr = True # set download mode flag
serial_instance.rts = False # propagate dtr flag
serial_instance.rts = True
serial_instance.dtr = False # reset
serial_instance.rts = True # propagate dtr
serial_instance.rts = False # clear download flag
invalid header: 0xffffffff
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40049b23
0x40049b23: SPI_WakeUp in ROM
invalid header: 0xffffffESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0x0 (DOWNLOAD(USB/UART0))
Saved PC:0x40043d08
0x40043d08: _cvt in ROM
waiting for download
However, when I try do program it from this point, I can do a bunch of things, but it always errors out at the same point in commands like this, when I try to flash 'hello world' to it: This output contains some arguments to be more verbose.
$ python -m esptool --chip esp32s3 --port /dev/ttyACM0 -b 9600 --trace --no-stub --before default_reset --after no_reset_stub write_flash --flash_mode dio --flash_size detect --flash_freq 80m 0x0 build/bootloader/bootloader.bin 0x8000 build/partition_table/partition-table.bin 0x10000 build/hello_world.bin
esptool.py v4.7.0
Serial port /dev/ttyACM0
Connecting...TRACE +0.000 command op=0x08 data len=36 wait_response=1 timeout=0.100 data=
0707122055555555 5555555555555555 | ... UUUUUUUUUUUU
5555555555555555 5555555555555555 | UUUUUUUUUUUUUUUU
55555555 | UUUU
TRACE +0.000 Write 46 bytes:
c000082400000000 0007071220555555 | ...$........ UUU
5555555555555555 5555555555c0 | UUUUUUUUUUUUU.
TRACE +0.100 No serial data received.
.TRACE +0.050 command op=0x08 data len=36 wait_response=1 timeout=0.100 data=
55555555 | UUUU
TRACE +0.001 Read 1 bytes: c0
TRACE +0.000 Read 27 bytes:
0108040007071220 00000000c0c00108 | ....... ........
0400070712200000 0000c0 | ..... .....
TRACE +0.000 Received full packet: 010804000707122000000000
TRACE +0.000 Read 28 bytes:
c001080400070712 2000000000c0c001 | ........ .......
0804000707122000 000000c0 | ...... .....
TRACE +0.000 Read 14 bytes: c0010804000707122000000000c0
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=00100040
TRACE +0.000 Write 14 bytes: c0000a04000000000000100040c0
TRACE +0.000 Read 1 bytes: c0
TRACE +0.000 Read 13 bytes: 010a04000900000000000000c0
TRACE +0.000 Received full packet: 010a04000900000000000000
TRACE +0.000 command op=0x14 data len=0 wait_response=1 timeout=3.000 data=
TRACE +0.000 Write 10 bytes: c00014000000000000c0
TRACE +0.000 Read 33 bytes:
0114180009000000 0000000000000000 | ................
0000000c09000000 0000000000000000 | ................
c0 | .
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=4cf1ce3f
TRACE +0.000 Write 14 bytes: c0000a0400000000004cf1ce3fc0
TRACE +0.000 Read 13 bytes: 010a04000400000000000000c0
TRACE +0.000 Received full packet: 010a04000400000000000000
TRACE +0.002 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=b0800060a13ad850ffffffff00000000
TRACE +0.000 Write 26 bytes:
c000091000000000 00b0800060a13ad8 | ............`.:.
50ffffffff000000 00c0 | P.........
TRACE +0.000 Read 13 bytes: 010904000400000000000000c0
TRACE +0.000 Received full packet: 010904000400000000000000
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=9880006000000000ffffffff00000000
c000091000000000 0098800060000000 | ............`...
00ffffffff000000 00c0 | ..........
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=b080006000000000ffffffff00000000
c000091000000000 00b0800060000000 | ............`...
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=b88000602a311d8fffffffff00000000
c000091000000000 00b88000602a311d | ............`*1.
8fffffffff000000 00c0 | ..........
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=b4800060
TRACE +0.000 Write 14 bytes: c0000a040000000000b4800060c0
TRACE +0.000 Read 13 bytes: 010a04000000b00400000000c0
TRACE +0.000 Received full packet: 010a04000000b00400000000
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=b48000600000b084ffffffff00000000
c000091000000000 00b48000600000b0 | ............`...
84ffffffff000000 00c0 | ..........
TRACE +0.000 Read 13 bytes: 010904000000b00400000000c0
TRACE +0.000 Received full packet: 010904000000b00400000000
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=b880006000000000ffffffff00000000
c000091000000000 00b8800060000000 | ............`...
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=58700060
TRACE +0.000 Write 14 bytes: c0000a04000000000058700060c0
TRACE +0.000 Read 13 bytes: 010a0400b4e4008000000000c0
TRACE +0.000 Received full packet: 010a0400b4e4008000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=50700060
TRACE +0.000 Write 14 bytes: c0000a04000000000050700060c0
TRACE +0.000 Read 13 bytes: 010a04000000080300000000c0
TRACE +0.000 Received full packet: 010a04000000080300000000
TRACE +0.000 Read 14 bytes: c0010a04000000080300000000c0
Chip is ESP32-S3 (QFN56) (revision v0.2)
TRACE +0.001 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=54700060
TRACE +0.000 Write 14 bytes: c0000a04000000000054700060c0
TRACE +0.000 Read 13 bytes: 010a0400c878dadc00000000c0
TRACE +0.000 Received full packet: 010a0400c878dadc00000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=54700060
Features: WiFi, BLE, Embedded PSRAM 8MB (AP_3v3)
Crystal is 40MHz
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=44700060
TRACE +0.000 Write 14 bytes: c0000a04000000000044700060c0
TRACE +0.000 Read 13 bytes: 010a0400204806f900000000c0
TRACE +0.000 Received full packet: 010a0400204806f900000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=48700060
TRACE +0.000 Write 14 bytes: c0000a04000000000048700060c0
TRACE +0.000 Read 13 bytes: 010a04003030000000000000c0
TRACE +0.000 Received full packet: 010a04003030000000000000
MAC: 30:30:f9:06:48:20
Enabling default SPI flash mode...
TRACE +0.000 command op=0x0d data len=8 wait_response=1 timeout=3.000 data=0000000000000000
TRACE +0.000 Write 18 bytes:
c0000d0800000000 0000000000000000 | ................
00c0 | ..
TRACE +0.000 Read 13 bytes: 010d04003030000000000000c0
TRACE +0.000 Received full packet: 010d04003030000000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=18200060
TRACE +0.000 Write 14 bytes: c0000a04000000000018200060c0
TRACE +0.000 Read 13 bytes: 010a04000000008000000000c0
TRACE +0.000 Received full packet: 010a04000000008000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=20200060
TRACE +0.000 Write 14 bytes: c0000a04000000000020200060c0
TRACE +0.000 Read 13 bytes: 010a04000000007000000000c0
TRACE +0.000 Received full packet: 010a04000000007000000000
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2820006017000000ffffffff00000000
c000091000000000 0028200060170000 | .........( .`...
TRACE +0.000 Read 13 bytes: 010904000000007000000000c0
TRACE +0.000 Received full packet: 010904000000007000000000
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1820006000000090ffffffff00000000
c000091000000000 0018200060000000 | .......... .`...
90ffffffff000000 00c0 | ..........
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=202000609f000070ffffffff00000000
c000091000000000 00202000609f0000 | ......... .`...
70ffffffff000000 00c0 | p.........
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=5820006000000000ffffffff00000000
c000091000000000 0058200060000000 | .........X .`...
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=0020006000000400ffffffff00000000
c000091000000000 0000200060000004 | .......... .`...
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=00200060
TRACE +0.000 Write 14 bytes: c0000a04000000000000200060c0
TRACE +0.000 Read 13 bytes: 010a04000000000000000000c0
TRACE +0.000 Received full packet: 010a04000000000000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=58200060
TRACE +0.000 Write 14 bytes: c0000a04000000000058200060c0
TRACE +0.000 Read 13 bytes: 010a04007fffff0000000000c0
TRACE +0.000 Received full packet: 010a04007fffff0000000000
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1820006000000080ffffffff00000000
80ffffffff000000 00c0 | ..........
TRACE +0.000 Read 13 bytes: 010904007fffff0000000000c0
TRACE +0.000 Received full packet: 010904007fffff0000000000
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2020006000000070ffffffff00000000
c000091000000000 0020200060000000 | ......... .`...
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2820006007000000ffffffff00000000
c000091000000000 0028200060070000 | .........( .`...
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1c2000600700005cffffffff00000000
c000091000000000 001c200060070000 | .......... .`...
5cffffffff000000 00c0 | \.........
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=18200060000000f0ffffffff00000000
f0ffffffff000000 00c0 | ..........
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=202000605a000070ffffffff00000000
c000091000000000 00202000605a0000 | ......... .`Z..
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=0420006010000000ffffffff00000000
c000091000000000 0004200060100000 | .......... .`...
TRACE +0.000 Read 13 bytes: 010a0400ff00000000000000c0
TRACE +0.000 Received full packet: 010a0400ff00000000000000
TRACE +0.000 Read 13 bytes: 01090400ff00000000000000c0
TRACE +0.000 Received full packet: 01090400ff00000000000000
Configuring flash size...
Warning: Could not auto-detect Flash size (FlashID=0xffff7f, SizeID=0xff), defaulting to 4MB
TRACE +0.000 command op=0x0b data len=24 wait_response=1 timeout=3.000 data=
0000000000004000 0000010000100000 | ......@.........
00010000ffff0000 | ........
TRACE +0.000 Write 34 bytes:
c0000b1800000000 0000000000000040 | ...............@
0000000100001000 0000010000ffff00 | ................
00c0 | ..
TRACE +0.000 Read 13 bytes: 010b0400ff00000000000000c0
TRACE +0.000 Received full packet: 010b0400ff00000000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=38700060
TRACE +0.000 Write 14 bytes: c0000a04000000000038700060c0
TRACE +0.001 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=58700060
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=30700060
TRACE +0.000 Write 14 bytes: c0000a04000000000030700060c0
Flash will be erased from 0x00000000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x00045fff...
Erasing flash...
Flash params set to 0x022f
TRACE +0.001 command op=0x02 data len=20 wait_response=1 timeout=3.000 data=
2052000015000000 0004000000000000 | R..............
00000000 | ....
TRACE +0.000 Write 30 bytes:
c000021400000000 0020520000150000 | ......... R.....
0000040000000000 0000000000c0 | ..............
TRACE +3.003 Serial data stream stopped: Possible serial noise or corruption.
A fatal error occurred: Serial data stream stopped: Possible serial noise or corruption.
# esptool.cfg file to configure internal settings of esptool
[esptool]
chip_erase_timeout = 140
serial_write_timeout = 8.5
connect_attempts = 7
write_block_attempts = 2
reset_delay = 0.75
# Overriding the default reset sequence to work in an abnormal environment
custom_reset_sequence = D0|R1|W0.5|D1|R0|W0.5|D0
esptool.py v4.7.0
Loaded custom configuration from /home/ubuntu/esp/my_tests/hello_world/esptool.cfg
55555555 | UUUU
TRACE +1.386 Read 4095 bytes:
7866666666666666 660d0a696e76616c | xffffffff..inval
6964206865616465 723a203078666666 | id header: 0xfff
66666666660d0a69 6e76616c69642068 | fffff..invalid h
65616465723a2030 7866666666666666 | eader: 0xfffffff
660d0a696e76616c 6964206865616465 | f..invalid heade
723a203078666666 66666666660d0a69 | r: 0xffffffff..i
6e76616c69642068 65616465723a2030 | nvalid header: 0
