Zigbee examples: help understanding how they work
Rob190
Postby Rob190 » Wed May 29, 2024 7:03 pm
I'm looking at the example here: examples/esp_zigbee_HA_sample/HA_on_off_light
It works fine but I'm having trouble understanding the code. In particular, I don't see how the main loop runs.
static void esp_zb_task(void *pvParameters)
    /* initialize Zigbee stack */
    esp_zb_cfg_t zb_nwk_cfg = ESP_ZB_ZED_CONFIG();
    esp_zb_init(&zb_nwk_cfg);
    esp_zb_on_off_light_cfg_t light_cfg = ESP_ZB_DEFAULT_ON_OFF_LIGHT_CONFIG();
    esp_zb_ep_list_t *esp_zb_on_off_light_ep = esp_zb_on_off_light_ep_create(HA_ESP_LIGHT_ENDPOINT, &light_cfg);
    esp_zb_device_register(esp_zb_on_off_light_ep);
    esp_zb_core_action_handler_register(zb_action_handler);
    esp_zb_set_primary_network_channel_set(ESP_ZB_PRIMARY_CHANNEL_MASK);
    ESP_ERROR_CHECK(esp_zb_start(false));
    esp_zb_main_loop_iteration();
This is called as a task from app_main:
    xTaskCreate(esp_zb_task, "Zigbee_main", 4096, NULL, 5, NULL);
It looks to me that esp_zb_main_loop_iteration() is only run once. Shouldn't it be inside a while(true) loop?
The documentation says "Must be called after esp_zb_int() and esp_zb_start() inside the application’s main cycle. ". This implies it is called repeatedly but the documentation for xTaskCreate implies that you need a loop, for(;;) in the example:
https://www.freertos.org/a00125.html
stef70
Re: Zigbee examples: help understanding how they work
Postby stef70 » Mon Jun 03, 2024 1:14 pm
According to https://github.com/espressif/esp-zigbee ... 1986330620 , the disassembly of esp_zb_main_loop_iteration is
4202075e <esp_zb_main_loop_iteration>:
4202075e:       1141                    add     sp,sp,-16
42020760:       c606                    sw      ra,12(sp)
42020762:       a029                    j       4202076c <esp_zb_main_loop_iteration+0xe>
42020764:       7d02e0ef                jal     4204ef34 <zboss_main_loop_iteration>
42020768:       fe9ff0ef                jal     42020750 <esp_zb_lock_release>
4202076c:       557d                    li      a0,-1
4202076e:       fd5ff0ef                jal     42020742 <esp_zb_lock_acquire>
42020772:       f96d                    bnez    a0,42020764 <esp_zb_main_loop_iteration+0x6>
42020774:       bfd5                    j       42020768 <esp_zb_main_loop_iteration+0xa>
If I am not mistaken, that should correspond to the following code:
void esp_zb_main_loop_iteration() {
  while(true) {
    if ( esp_zb_lock_acquire(portMAX_DELAY) ) {
      zboss_main_loop_iteration()
    esp_zb_lock_release()
So there is a infinite loop. The name was poorly chosen.
Rob190
Postby Rob190 » Wed Jun 05, 2024 9:00 am
Thanks!
Agree, not a good name. Maybe I'll suggest they change it. Can't imagine I'm the only person to be confused by it.
