ESP32-8048S043C not programming
wolfrose
Postby wolfrose » Fri May 31, 2024 8:38 pm
I have both ESP32-3248S035C & ESP32-8048S043C.
I was able to program ESP32-3248S035C easily on
https://suchmememanyskill.github.io/CYD-Klipper/
and
https://install.openhasp.com/
but ESP32-8048S043C isn't programming.
even on arduino ide, I can't upload a simple blink code
In arduino ide I get this error:
Sketch uses 248501 bytes (18%) of program storage space. Maximum is 1310720 bytes.
Global variables use 18456 bytes (5%) of dynamic memory, leaving 309224 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port COM8
Connecting...
A serial exception error occurred: Cannot configure port, something went wrong. Original message: PermissionError(13, 'Access is denied.', None, 5)
Note: This error originates from pySerial. It is likely not a problem with esptool, but with the hardware connection or drivers.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
the selected serial port For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
 does not exist or your board is not connected
MicroController
Re: ESP32-8048S043C not programming
Postby MicroController » Mon Jun 03, 2024 10:07 am
the selected serial port does not exist or your board is not connected
1) Check that you are using the correct COM port,
2) Check that the COM port isn't in use by another program.
jeffiet3
Postby jeffiet3 » Wed Jun 03, 2026 4:53 pm
Try some different cables. I had the same problem with the cable it came with. I tried a few different one. One worked.
Users browsing this forum: Bing [Bot], ChatGPT-User, Perplexity-User, PerplexityBot, trendictionbot and 3 guests
