ESP_TIMER_ISR on the ESP32-C3
bstolk
Postby bstolk » Sat Jun 01, 2024 10:10 pm
I have used both the ESP32-S3 and the ESP32-C3 (M5Stack Stamp devices.)
On the EPS32-S3 I was able to create an interrupt-service-routine with this configuration:
        const esp_timer_create_args_t periodic_scan_timer_args =
                .callback = &led_driver_scan_isr,
                .dispatch_method = ESP_TIMER_ISR,
                .arg = 0,
                .name = "ISR",
                .skip_unhandled_events = 1,
However, this does not compile for the ESP32-C3 target. Even though I have the high precision timer enabled in menuconfig.
For the ESP32-C3, I am forced to use ESP_TIMER_TASK instead, and trying that gave me unsatisfactory results.
So, are the timers on C3 and S3 fundamentally different? How can I make an interrupt-service-routine for the S3 that does not go via the task system?
bstolk
Re: ESP_TIMER_ISR on the ESP32-C3
Postby bstolk » Sat Jun 01, 2024 10:21 pm
Ah, it turns out I forgot to check a box in the menuconfig
Users browsing this forum: PetalBot, Qwantbot and 2 guests
