[solved] can't accept new connection from listen socket second time
engelant
Postby engelant » Thu Nov 03, 2016 10:39 am
EDIT: It's solved in the meantime, just works now as expecetd
every time when I post something like this, I really hope I'm not the cause of this issue. Unfortunatly I'm not working with sockets that often. And I haven't used lwip before, so I'don't know where my troubles are coming from.
This is some code, I can run locally, it works as expected. Only one connection can be served at a time, but once it's done, the next one will get accepted.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
const static char http_html_hdr[] =
                "HTTP/1.1 200 OK\r\nContent-type: text/html\r\n\r\n";
int main() {
        int sock = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
        printf("New sock = %d\n", sock);
        struct sockaddr_in serverAddress;
        serverAddress.sin_family = AF_INET;
        serverAddress.sin_addr.s_addr = htonl(INADDR_ANY);
        serverAddress.sin_port = htons(80);
        int rc = bind(sock, (struct sockaddr * ) &serverAddress,
                        sizeof(serverAddress));
        printf("bind completed! %d\n", rc);
        rc = listen(sock, 10);
        printf("listen completed! %d\n", rc);
        struct sockaddr_in clientAddress;
        socklen_t clientAddressLength = sizeof(clientAddress);
        int newsockfd, n;
        char buffer[256];
        while (1) {
                printf("Waiting connection accept\n");
                newsockfd = accept(sock, (struct sockaddr * ) &clientAddress,
                                &clientAddressLength);
                printf("Accepted a client connection\n");
                if (newsockfd < 0)
                        printf("ERROR on accept\n");
                bzero(buffer, 256);
                printf("About to read\n");
                n = read(newsockfd, buffer, 255);
                printf("I've red %d\n", n);
                if (n < 0)
                        printf("ERROR reading from socket\n");
                printf("Here is the message: %s\n", buffer);
                n = write(newsockfd, http_html_hdr, sizeof(http_html_hdr));
                if (n < 0)
                        printf("ERROR writing to socket\n");
                close(newsockfd);
                printf("socket closed %d\n", newsockfd);
Now same thing on the esp32 results in being able to connect once, after that accept seems to block forever.
/* Hello World Example
#include <stdio.h>
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event_loop.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "driver/ledc.h"
#include "lwip/err.h"
#include "lwip/sockets.h"
/* FreeRTOS event group to signal when we are connected & ready to make a request */
static EventGroupHandle_t wifi_event_group;
/* The event group allows multiple bits for each event,
 but we only care about one event - are we connected
 to the AP with an IP? */
static const int CONNECTED_BIT = BIT0;
static const char *TAG = "example";
/* The examples use simple WiFi configuration that you can set via
 'make menuconfig'.
 If you'd rather not, just change the below entries to strings with
 the config you want - ie #define EXAMPLE_WIFI_SSID "mywifissid"
#define EXAMPLE_WIFI_SSID "miau"
#define EXAMPLE_WIFI_PASS "***EDITED***"
static esp_err_t event_handler(void *ctx, system_event_t *event) {
	switch (event->event_id) {
	case SYSTEM_EVENT_STA_START:
		esp_wifi_connect();
	case SYSTEM_EVENT_STA_GOT_IP:
		xEventGroupSetBits(wifi_event_group, CONNECTED_BIT);
	case SYSTEM_EVENT_STA_DISCONNECTED:
		/* This is a workaround as ESP32 WiFi libs don't currently
		 auto-reassociate. */
		esp_wifi_connect();
		xEventGroupClearBits(wifi_event_group, CONNECTED_BIT);
	default:
	return ESP_OK;
static void initialise_wifi(void) {
	tcpip_adapter_init();
	wifi_event_group = xEventGroupCreate();
	ESP_ERROR_CHECK(esp_event_loop_init(event_handler, NULL));
	wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT()
	ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
	wifi_config_t wifi_config = { .sta = { .ssid = EXAMPLE_WIFI_SSID,
			.password = EXAMPLE_WIFI_PASS, }, };
	ESP_LOGI(TAG, "Setting WiFi configuration SSID %s...", wifi_config.sta.ssid);
	ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
	ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config));
	ESP_ERROR_CHECK(esp_wifi_start());
const static char http_index_html[] =
		"<html><head><title>Congrats!</title></head><body><h1>Welcome to our lwIP HTTP server!</h1><p>This is a small test page, served by httpserver-netconn.</body></html>";
static void http_server_thread() {
	xEventGroupWaitBits(wifi_event_group, CONNECTED_BIT,
	false, true, portMAX_DELAY);
	int newsockfd, n;
	char buffer[256];
	while (1) {
		if (newsockfd < 0)
		bzero(buffer, 256);
		if (n < 0)
		if (n < 0)
		close(newsockfd);
void app_main() {
	nvs_flash_init();
	system_init();
	initialise_wifi();
	xTaskCreate(&http_server_thread, "http_server_netconn_thread", 2048, NULL,
			5, NULL);
And this is what happens:
New sock = 0
bind completed! 0
listen completed! 0
About to read
I've red 7
Here is the message: asdasd
socket closed 1
ivan@ivan-desktop:~/Documents/esp/myapp$ nc 192.168.2.111 80
asdasd
HTTP/1.1 200 OK
EDIT: for some reason it worked another time, but I had to wait several minutes.
New sock = 0
bind completed! 0
listen completed! 0
About to read
I've red 7
socket closed 1
About to read
I've red 7
socket closed 2
EDIT: And after a few more minutes It will again accept a connection:
New sock = 0
bind completed! 0
listen completed! 0
About to read
I've red 7
socket closed 1
About to read
I've red 7
socket closed 2
About to read
I've red 7
socket closed 3
Users browsing this forum: Applebot, Semrush [Bot] and 1 guest
