Startup and WiFi connection are more fast in ESP8266 than ESP32-C3
agi63_ita
Postby agi63_ita » Fri Jun 07, 2024 2:25 pm
Hi all,
I'm working with ESP32-C3 with uart AT-commands mode. I use it to connect at WiFi AP as a client.
If I have WiFi network configured, and AUTOCONN enabled, when power-up modem sequence is:
boot --> "ready"
and than URC:
WIFI CONNECT
WIFI GOT IP
Problem is the delay from "ready" to WIFI CONNECT:
in the ESP8266 about 1s
in the ESP32-C3 about 3s
What could be the problem?
I noticed that (in the ESP8266) going from version 2.1.0.0 to 2.2.1.0 the same thing happens!
My device is battery powered and and more time WiFi ON means more consumption!
A big thank you to anyone who can help me, otherwise I will continue to use ESP8266.
bye
Andrea
release fw are:
ESP8266
AT version:2.1.0.0(ded5b14 - Jul 24 2020 12:01:05)
SDK version:v3.3-2-gb6e861a
compile time(36bb200):Jul 28 2020 08:30:34
Bin version:2.1.0(WROOM-02
ESP32-C3
AT version:3.3.0.0(3b13d04 - ESP32C3 - May 8 2024 08:21:54)
SDK version:v5.0.6-dirty
compile time(be332568):May 8 2024 08:51:33
Bin version:v3.3.0.0(MINI-1)
esp-at
Re: Startup and WiFi connection are more fast in ESP8266 than ESP32-C3
Postby esp-at » Fri Jun 28, 2024 8:19 am
Hello, have you tried the v3.3.0.0 firmware: https://docs.espressif.com/projects/esp ... aries.html
in my test, it seems work well every time, see the attachment.
Could you please check your firmware version.
agi63_ita
Postby agi63_ita » Fri Jul 05, 2024 9:46 am
thanks for your reply, I use the same version of modem firmware as you.
In my WiFi connection I use DHPC mode, is it the same in your test ?
Andrea
esp-at
Postby esp-at » Tue Aug 06, 2024 7:55 am
yes, dhcp is enabled by default. Otherwise, it will obtain an IP address (actually, use the static ip address) more quickly.
