API Timer , Boards Version 3.0.1
aruffato
Postby aruffato » Mon Jun 10, 2024 9:56 pm
Hi, my name is Adrian and I do not understood the changes in the migration from 2.0.17 to 3.0.1 BOARDS
In the example "Repeat timer example", in the setup() -> Configure a timer interrupt EVERY 1 [sec] ->
  // Set BTN_STOP_ALARM to input mode
  pinMode(BTN_STOP_ALARM, INPUT);
  // Create semaphore to inform us when the timer has fired
  timerSemaphore = xSemaphoreCreateBinary();
  // Set timer frequency to 1Mhz
  timer = timerBegin(1000000);
  // Attach onTimer function to our timer.
  timerAttachInterrupt(timer, &onTimer);
  // Set alarm to call onTimer function every second (value in microseconds).
  // Repeat the alarm (third parameter) with unlimited count = 0 (fourth parameter).
  timerAlarm(timer, 1000000, true, 0);
It is OK, it run.
_____________________________________________________
The questions is, if I need a frequency to 1000 [Hz] = 1 [KHz] ?, the changes are ->
  // Set timer frequency to 1KHz
  timer = timerBegin(1000);
  timerAlarm(timer, 1000, true, 0);
In the old Version 2.0.17 I had TWO types of timers, timer0 to 1[ms] interrupt, and timer1 to 1[sec] interrupt, so my OLD code -> RUN.
hw_timer_t *timerZERO = NULL;
volatile SemaphoreHandle_t timerSemaphoreZERO;
portMUX_TYPE timerMuxZERO = portMUX_INITIALIZER_UNLOCKED;
void setUpTimerZERO(){
  //timerSemaphoreZERO = xSemaphoreCreateBinary();
  timerZERO = timerBegin(0,80,true);
  Serial.print(F("timerZERO -> "));
  Serial.println(timerZERO != NULL ? "is OK." : "have a PROBLEM.");
  timerAttachInterrupt(timerZERO, &onTimerZERO,true);
  // Set timer frequency to 1 000 [Hz]
  timerAlarmWrite(timerZERO, 1000, true);
  /* Start an alarm */
  timerAlarmEnable(timerZERO);
Idem for timerUNO.
This part compile and Run without problem, in the NEW version 3.0.1 with the changes mentioned, I got an error when the timer set Up.
Here is the complete code with changes in version 3.0.1 ->
/** SKETCH: AR-ESP32-V.3.0.1-Timer-01.2.ino
    FECHA:  10/06/2024 15:00
    VERSION:  01.2
    OBJECT:
      Obtener un Timer Interrupt cada 1[ms] SIN ERROR
__________________________________________________________
      This example shows how to use hardware timer in ESP32. The timer calls onTimer
      function every second. The timer can be stopped with button attached to PIN 0
      (IO0).
      This example code is in the public domain.
// Stop button is attached to PIN 0 (IO0)
#define BTN_STOP_ALARM 0
/**	NOTA:  No la utilizo	*/
  /** SET:  timerUNO  >>> */
hw_timer_t *timerUNO = NULL;
volatile SemaphoreHandle_t timerSemaphoreUNO;
portMUX_TYPE timerMuxUNO = portMUX_INITIALIZER_UNLOCKED;
  /** SET:  timerZERO  >>> */
volatile uint32_t isrCounter = 0;
volatile uint32_t isrZeroCOUNTER = 0;
volatile uint32_t lastIsrAt = 0;
volatile bool bTimerUNO=false;
volatile bool bFlag1MS=false;
/** DESHABILITADO:*/
void ARDUINO_ISR_ATTR onTimerZERO() {
  // Increment the counter
  portENTER_CRITICAL_ISR(&timerMuxZERO);
	if(++isrZeroCOUNTER==1000){
	  isrZeroCOUNTER=0;
	  lastIsrAt = millis();
	  bFlag1MS=true;
  portEXIT_CRITICAL_ISR(&timerMuxZERO);
  // Give a semaphore that we can check in the loop
  xSemaphoreGiveFromISR(timerSemaphoreZERO, NULL);
  // It is safe to use digitalRead/Write here if you want to toggle an output
void ARDUINO_ISR_ATTR onTimerUNO() {
  // Increment the counter and set the time of ISR
  portENTER_CRITICAL_ISR(&timerMuxUNO);
    //isrCounter++;
    ++isrCounter;
    bTimerUNO=true;
  portEXIT_CRITICAL_ISR(&timerMuxUNO);
  xSemaphoreGiveFromISR(timerSemaphoreUNO, NULL);
    // Set timer frequency to 1 [KHz]
    timerZERO = timerBegin(1000);
    timerAttachInterrupt(timerZERO, &onTimerZERO);
    timerAlarm(timerZERO, 1000, true, 0);
void setUpTimerUNO(){
  timerSemaphoreUNO = xSemaphoreCreateBinary();
  // Set timer frequency to 1 [MHz]
  timerUNO = timerBegin(1000000);
  Serial.print(F("timerUNO -> "));
  Serial.println(timerUNO != NULL ? "is OK." : "have a PROBLEM.");
  timerAttachInterrupt(timerUNO, &onTimerUNO);
  timerAlarm(timerUNO, 1000000, true, 0);
  Serial.println(F("Probando timerZERO & timerUNO."));
  setUpTimerZERO();
  setUpTimerUNO();
  // If Timer has fired
  //  if ((xSemaphoreTake(timerSemaphoreZERO, 0) == pdTRUE && bFlag1MS==true) {
  if (xSemaphoreTake(timerSemaphoreUNO, 0) == pdTRUE) {
    //if( bTimerUNO==true){
      // bTimerUNO=false;
      uint32_t isrCount = 0, isrTime = 0;
      // Read the interrupt count and time
      portENTER_CRITICAL(&timerMuxUNO);
      isrCount = isrCounter;
      isrTime = lastIsrAt;
      portEXIT_CRITICAL(&timerMuxUNO);
      // Print it
      Serial.print("onTimerUNO N° ");
      Serial.print(isrCount);
      Serial.print(" at ");
      Serial.print(isrTime);
      Serial.println(" ms");
  /** DESHABILITADA:  Para HABILITAR: hay que sacar el COMENTARIO:  >>>
      // If button is pressed
      if (digitalRead(BTN_STOP_ALARM) == LOW) {
        // If timer is still running
        if (timerUNO) {
          // Stop and free timer
          timerEnd(timerUNO);
          timerUNO = NULL;
Could anybody tell me what I missed ? Why such error?
For now, I back to the old version, until I get the solution.
Best regards,
Adrian
