Hello
Is possible to use Rainmaker with the wt32-eth01 board using the Ethernet connection? My university utilizes the wpa2 enterprise which i could'nt make it work also.
Thanks in advance
Eduardo
wt32-eth01 LAN8720 with Rainmaker
Re: wt32-eth01 LAN8720 with Rainmaker
ESP RainMaker will indeed work with Ethernet, but since the User-Node mapping in RainMaker relies on the data exchanged during Wi-Fi provisioning, the node wont be usable from the phone app. In case you perform the Wi-Fi provisioning (may be with any random credentials) but with Ethernet also connected, this may work too. I haven't checked though.
