Reducing Classic Bluetooth library size
aldami
Postby aldami » Tue Jun 18, 2024 10:15 am
Adding support for classic BT a2dp increases flash usage by more than half a megabyte.
As reported by idf_size.py --archives :
With debug logs:
Archive File DRAM .data & 0.bss IRAM0 .text & 0.vectors ram_st_total Flash .text & .rodata & .rodata_noload & .appdesc flash_total
     libbt.a       4723    2387        1725           0         8835      416578    119988                0          0      543014
With CONFIG_BT_STACK_NO_LOG=y the situation is better, but still problematic:
     libbt.a       4722    2387        1725           0         8834      350371     24986                0          0      381804
I have already set the BT controller to BR/EDR only as I am not using BLE, and BT HID is disabled.
Is there a way to further reduce the size ? Are all the 340 KB of code required for Classic BT A2DP ?
Thank you
Users browsing this forum: Bing [Bot], ChatGPT-User, PetalBot and 1 guest
