GPIO pulse generated - inconsistent width
Posted: Thu Jun 20, 2024 11:44 am
by marsal64
using ESP32-S3 at 160MHz, I run once per some seconds the code:
gpio_set_level(GPIO_NUM_36, 1);
gpio_set_level(GPIO_NUM_36, 0);
My app runs WiFi, UART and two other lightweight FreeRTOS tasks.
I observe non-consistent width of the "pulse" I generate on GPIO_NUM_36 pin:
Typically: 6.6uS
Sometimes: 1.275uS
Rarely: 3.3625uS
Could please anybody explain what is happening here?
Thank you
Re: GPIO pulse generated - inconsistent width
Posted: Thu Jun 20, 2024 1:45 pm
by ok-home
Hi
bitbang on esp32 gives unpredictable results
- interrupts (wifi,freertos...)
- cache misses
as an example simple code
 gpio_set_level(GPIO_BLINK, 1);
 gpio_set_level(GPIO_BLINK, 0);
 GPIO.out_w1ts = mask;
 GPIO.out_w1tc = mask;
when code in flash memory and IRAM and the process of swapping cache from flash memory
Posted: Thu Jun 20, 2024 2:11 pm
by MicroController
Likely: Caching, possibly: synchronization of the CPU with the APB and the GPIO peripheral.
You can look into Dedicated GPIO to improve the latter, and put code into IRAM to avoid cache issues.
