ESP-IDF Zigbee Light on/off example Network Join
TinTin
Postby TinTin » Tue Jun 25, 2024 6:08 pm
I'm trying to connect the Seeed Studio XIAO ESP32C6 with Zigbee to my HomeAssistant-Server. On that Server there is an zigbee2mqtt
as Coordinator that uses an SONOFF Zigbee 3.0 USB Dongle Plus.
As base Program I'm using the light on off example from the zigbee sdk. For now i just want that the Board joins the Zigbee Network.
With the base programm as is i just get the message "Network steering was not successful (status: ESP_FAIL)". I already made sure that they are both running on the same Channel(11). Do i need to make other changes in the code? Is it even possible to connect the board to the zigbee network?
Thanks for any help
My current code looks like this:
#include "esp_zb_light.h"
#include "esp_check.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "freertos/task.h"
#include "ha/esp_zigbee_ha_standard.h"
#include "driver/gpio.h"
#if !defined ZB_ED_ROLE
#error Define ZB_ED_ROLE in idf.py menuconfig to compile light (End Device) source code.
#endif
static const char *TAG = "ESP_ZB_ON_OFF_LIGHT";
#define BLINK_GPIO 15
/********************* Define functions **************************/
static esp_err_t deferred_driver_init(void)
    ESP_LOGI(TAG, "Deferred driver init called");
    light_driver_init(LIGHT_DEFAULT_OFF);
    return ESP_OK;
static void configure_led(void)
    ESP_LOGI(TAG, "Configuring LED");
    gpio_reset_pin(BLINK_GPIO);
    gpio_set_direction(BLINK_GPIO, GPIO_MODE_OUTPUT);
static void bdb_start_top_level_commissioning_cb(uint8_t mode_mask)
    ESP_LOGI(TAG, "Starting top-level commissioning");
    ESP_RETURN_ON_FALSE(esp_zb_bdb_start_top_level_commissioning(mode_mask) == ESP_OK, , TAG, "Failed to start Zigbee commissioning");
void esp_zb_app_signal_handler(esp_zb_app_signal_t *signal_struct)
    ESP_LOGI(TAG, "Signal handler called");
    uint32_t *p_sg_p = signal_struct->p_app_signal;
    esp_err_t err_status = signal_struct->esp_err_status;
    esp_zb_app_signal_type_t sig_type = *p_sg_p;
    switch (sig_type) {
    case ESP_ZB_ZDO_SIGNAL_SKIP_STARTUP:
        ESP_LOGI(TAG, "Initialize Zigbee stack");
        esp_err_t ret = esp_zb_bdb_start_top_level_commissioning(ESP_ZB_BDB_MODE_INITIALIZATION);
        ESP_LOGE(TAG, "Code: %s", esp_err_to_name(ret));
    case ESP_ZB_BDB_SIGNAL_DEVICE_FIRST_START:
    case ESP_ZB_BDB_SIGNAL_DEVICE_REBOOT:
        if (err_status == ESP_OK) {
            ESP_LOGI(TAG, "Deferred driver initialization %s", deferred_driver_init() ? "failed" : "successful");
            ESP_LOGI(TAG, "Device started up in %s factory-reset mode", esp_zb_bdb_is_factory_new() ? "" : "non");
            if (esp_zb_bdb_is_factory_new()) {
                ESP_LOGI(TAG, "Start network steering");
                esp_zb_bdb_start_top_level_commissioning(ESP_ZB_BDB_MODE_NETWORK_STEERING);
                ESP_LOGI(TAG, "Device rebooted");
            ESP_LOGW(TAG, "Failed to initialize Zigbee stack (status: %s)", esp_err_to_name(err_status));
    case ESP_ZB_BDB_SIGNAL_STEERING:
            esp_zb_ieee_addr_t extended_pan_id;
            esp_zb_get_extended_pan_id(extended_pan_id);
            ESP_LOGI(TAG, "Joined network successfully (Extended PAN ID: %02x:%02x:%02x:%02x:%02x:%02x:%02x:%02x, PAN ID: 0x%04hx, Channel:%d, Short Address: 0x%04hx)",
                     extended_pan_id[7], extended_pan_id[6], extended_pan_id[5], extended_pan_id[4],
                     extended_pan_id[3], extended_pan_id[2], extended_pan_id[1], extended_pan_id[0],
                     esp_zb_get_pan_id(), esp_zb_get_current_channel(), esp_zb_get_short_address());
            ESP_LOGI(TAG, "Network steering was not successful (status: %s)", esp_err_to_name(err_status));
            esp_zb_scheduler_alarm((esp_zb_callback_t)bdb_start_top_level_commissioning_cb, ESP_ZB_BDB_MODE_NETWORK_STEERING, 150000); // 5 Sekunden
    default:
        ESP_LOGI(TAG, "ZDO signal: %s (0x%x), status: %s", esp_zb_zdo_signal_to_string(sig_type), sig_type, esp_err_to_name(err_status));
static esp_err_t zb_attribute_handler(const esp_zb_zcl_set_attr_value_message_t *message)
    ESP_LOGI(TAG, "Attribute handler called");
    esp_err_t ret = ESP_OK;
    bool light_state = 0;
    ESP_RETURN_ON_FALSE(message, ESP_FAIL, TAG, "Empty message");
    ESP_RETURN_ON_FALSE(message->info.status == ESP_ZB_ZCL_STATUS_SUCCESS, ESP_ERR_INVALID_ARG, TAG, "Received message: error status(%d)",
                        message->info.status);
    ESP_LOGI(TAG, "Received message: endpoint(%d), cluster(0x%x), attribute(0x%x), data size(%d)", message->info.dst_endpoint, message->info.cluster,
             message->attribute.id, message->attribute.data.size);
    if (message->info.dst_endpoint == HA_ESP_LIGHT_ENDPOINT) {
        if (message->info.cluster == ESP_ZB_ZCL_CLUSTER_ID_ON_OFF) {
            if (message->attribute.id == ESP_ZB_ZCL_ATTR_ON_OFF_ON_OFF_ID && message->attribute.data.type == ESP_ZB_ZCL_ATTR_TYPE_BOOL) {
                light_state = message->attribute.data.value ? *(bool *)message->attribute.data.value : light_state;
                ESP_LOGI(TAG, "Light sets to %s", light_state ? "On" : "Off");
                gpio_set_level(BLINK_GPIO, light_state);
    return ret;
static esp_err_t zb_action_handler(esp_zb_core_action_callback_id_t callback_id, const void *message)
    ESP_LOGI(TAG, "Action handler called");
    switch (callback_id) {
    case ESP_ZB_CORE_SET_ATTR_VALUE_CB_ID:
        ret = zb_attribute_handler((esp_zb_zcl_set_attr_value_message_t *)message);
    default:
        ESP_LOGW(TAG, "Received Zigbee action(0x%x) callback", callback_id);
    return ret;
static void esp_zb_task(void *pvParameters)
    ESP_LOGI(TAG, "Starting Zigbee task");
    /* initialize Zigbee stack */
    esp_zb_cfg_t zb_nwk_cfg = ESP_ZB_ZED_CONFIG();
    esp_zb_init(&zb_nwk_cfg);
    esp_zb_on_off_light_cfg_t light_cfg = ESP_ZB_DEFAULT_ON_OFF_LIGHT_CONFIG();
    esp_zb_ep_list_t *esp_zb_on_off_light_ep = esp_zb_on_off_light_ep_create(HA_ESP_LIGHT_ENDPOINT, &light_cfg);
    esp_zb_device_register(esp_zb_on_off_light_ep);
    esp_zb_core_action_handler_register(zb_action_handler);
    esp_zb_set_primary_network_channel_set(1 << 11); // Beispiel: Kanal 11
    ESP_ERROR_CHECK(esp_zb_start(false));
    esp_zb_main_loop_iteration();
void app_main(void)
    ESP_LOGI(TAG, "Main application started");
    configure_led();
    esp_zb_platform_config_t config = {
        .radio_config = ESP_ZB_DEFAULT_RADIO_CONFIG(),
        .host_config = ESP_ZB_DEFAULT_HOST_CONFIG(),
    ESP_ERROR_CHECK(nvs_flash_init());
    ESP_ERROR_CHECK(esp_zb_platform_config(&config));
    xTaskCreate(esp_zb_task, "Zigbee_main", 4096, NULL, 5, NULL);
tshcherban
Re: ESP-IDF Zigbee Light on/off example Network Join
Postby tshcherban » Tue Dec 17, 2024 7:49 pm
Any luck with this?
matzko
Postby matzko » Sat Dec 20, 2025 2:30 pm
In my case the problem was solved after manually selecting the on-board antenna. It seems, that it wasnt selected by default. You can read about the switching procedure in seeed studios documentation.
