Microphone recognition source code is extracted and voice recognition is performed when it is driven
In this source code, dB always stays at the 40th line.
I need your help
Code: Untitled.c Select all
#include <nvs_flash.h>
#include "freertos/task.h"
#include "driver/gpio.h"
#include "esp_camera.h"
#include "esp_http_server.h"
#include "esp_timer.h"
#include "connect_wifi.h"
#include "esp_log.h"
#include <math.h>
#include "driver/i2s.h"
#include "esp_heap_caps.h"
#define CAM_PIN_PWDN -1
#define CAM_PIN_RESET -1
#define CAM_PIN_XCLK 4
#define CAM_PIN_SIOD 18
#define CAM_PIN_SIOC 23
#define CAM_PIN_D7 36
#define CAM_PIN_D6 37
#define CAM_PIN_D5 38
#define CAM_PIN_D4 39
#define CAM_PIN_D3 35
#define CAM_PIN_D2 14
#define CAM_PIN_D1 13
#define CAM_PIN_D0 34
#define CAM_PIN_VSYNC 5
#define CAM_PIN_HREF 27
#define CAM_PIN_PCLK 25
static const char *TAG = "esp32-cam Webserver";
camera_fb_t *last_fb = NULL;
bool capture_flag = false;
static void print_memory_status()
ESP_LOGI(TAG, "Free heap: %d", (unsigned int)esp_get_free_heap_size());
ESP_LOGI(TAG, "Free internal heap: %d", (unsigned int)heap_caps_get_free_size(MALLOC_CAP_INTERNAL));
ESP_LOGI(TAG, "Free PSRAM: %d", (unsigned int)heap_caps_get_free_size(MALLOC_CAP_SPIRAM));
static esp_err_t init_camera(void)
print_memory_status();
camera_config_t camera_config = {
.pin_pwdn = CAM_PIN_PWDN,
.pin_reset = CAM_PIN_RESET,
.pin_xclk = CAM_PIN_XCLK,
.pin_sccb_sda = CAM_PIN_SIOD,
.pin_sccb_scl = CAM_PIN_SIOC,
.pin_d7 = CAM_PIN_D7,
.pin_d6 = CAM_PIN_D6,
.pin_d5 = CAM_PIN_D5,
.pin_d4 = CAM_PIN_D4,
.pin_d3 = CAM_PIN_D3,
.pin_d2 = CAM_PIN_D2,
.pin_d1 = CAM_PIN_D1,
.pin_d0 = CAM_PIN_D0,
.pin_vsync = CAM_PIN_VSYNC,
.pin_href = CAM_PIN_HREF,
.pin_pclk = CAM_PIN_PCLK,
.xclk_freq_hz = 10000000,
.ledc_timer = LEDC_TIMER_0,
.ledc_channel = LEDC_CHANNEL_0,
.pixel_format = PIXFORMAT_JPEG,
.frame_size = FRAMESIZE_QQVGA,
.jpeg_quality = 15,
.fb_count = 1,
.grab_mode = CAMERA_GRAB_WHEN_EMPTY,
.fb_location = CAMERA_FB_IN_PSRAM
esp_err_t err = esp_camera_init(&camera_config);
if (err != ESP_OK)
ESP_LOGE(TAG, "Camera init failed with error 0x%x", err);
return err;
return ESP_OK;
void capture_image_task(void *pvParameters)
while (true)
if (capture_flag)
camera_fb_t *fb = esp_camera_fb_get();
if (fb)
if (last_fb)
esp_camera_fb_return(last_fb);
last_fb = fb;
ESP_LOGI(TAG, "Image captured");
else
ESP_LOGE(TAG, "Failed to capture image, reinitializing camera");
esp_camera_deinit();
init_camera();
vTaskDelay(pdMS_TO_TICKS(500));
esp_err_t capture_image_httpd_handler(httpd_req_t *req)
if (!last_fb)
httpd_resp_set_status(req, "204 No Content");
return httpd_resp_send(req, NULL, 0);
esp_err_t res = httpd_resp_set_type(req, "image/jpeg");
if (res == ESP_OK)
res = httpd_resp_send(req, (const char *)last_fb->buf, last_fb->len);
else
ESP_LOGE(TAG, "Failed to set HTTP response type");
return res;
esp_err_t index_html_handler(httpd_req_t *req)
const char* html = "<!DOCTYPE html><html><body>"
"<h1>ESP32 CAM</h1>"
"<img id='capture' src='/capture' width='320' height='240'/>"
"<script>"
"function updateImage() {"
" var img = document.getElementById('capture');"
" img.src = '/capture?' + new Date().getTime();"
"setInterval(updateImage, 1000);"
"</script>"
"</body></html>";
return httpd_resp_send(req, html, strlen(html));
httpd_uri_t uri_root = {
.uri = "/",
.method = HTTP_GET,
.handler = index_html_handler,
.user_ctx = NULL};
httpd_uri_t uri_capture = {
.uri = "/capture",
.method = HTTP_GET,
.handler = capture_image_httpd_handler,
.user_ctx = NULL};
httpd_handle_t setup_server(void)
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
httpd_handle_t capture_httpd = NULL;
if (httpd_start(&capture_httpd , &config) == ESP_OK)
httpd_register_uri_handler(capture_httpd , &uri_root);
httpd_register_uri_handler(capture_httpd , &uri_capture);
else
ESP_LOGE(TAG, "Failed to start HTTP server");
return capture_httpd;
#define I2S_NUM 0
#define SAMPLE_RATE 44100
#define SAMPLE_BITS I2S_BITS_PER_SAMPLE_16BIT
#define I2S_BUF_LEN 512
void measure_decibel_task(void *pvParameters)
i2s_config_t i2s_config = {
.mode = I2S_MODE_MASTER | I2S_MODE_RX,
.sample_rate = SAMPLE_RATE,
.bits_per_sample = SAMPLE_BITS,
.channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
.communication_format = I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB,
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL2,
.dma_buf_count = 8,
.dma_buf_len = I2S_BUF_LEN,
.use_apll = false,
.tx_desc_auto_clear = false,
.fixed_mclk = 0
i2s_pin_config_t pin_config = {
.bck_io_num = 26,
.ws_io_num = 32,
.data_out_num = I2S_PIN_NO_CHANGE,
.data_in_num = 33
esp_err_t err;
ESP_LOGI(TAG, "Installing I2S driver");
err = i2s_driver_install(I2S_NUM, &i2s_config, 0, NULL);
if (err != ESP_OK) {
ESP_LOGE(TAG, "Failed to install I2S driver: %s", esp_err_to_name(err));
return;
ESP_LOGI(TAG, "Setting I2S pins");
err = i2s_set_pin(I2S_NUM, &pin_config);
ESP_LOGE(TAG, "Failed to set I2S pins: %s", esp_err_to_name(err));
i2s_driver_uninstall(I2S_NUM);
return;
ESP_LOGI(TAG, "Setting I2S clock");
err = i2s_set_clk(I2S_NUM, SAMPLE_RATE, SAMPLE_BITS, I2S_CHANNEL_MONO);
ESP_LOGE(TAG, "Failed to set I2S clock: %s", esp_err_to_name(err));
return;
while (1) {
ESP_LOGI(TAG, "Reading I2S data");
int16_t i2s_buffer[I2S_BUF_LEN];
size_t bytes_read;
i2s_read(I2S_NUM, &i2s_buffer, sizeof(i2s_buffer), &bytes_read, 2000);
ESP_LOGI(TAG, "Processing I2S data");
uint32_t sum_squares = 0;
for (int i = 0; i < bytes_read / sizeof(int16_t); ++i) {
sum_squares += i2s_buffer * i2s_buffer;
printf("buffer data: %d\n",i2s_buffer);
float rms = sqrt((float)sum_squares / (bytes_read / sizeof(int16_t)));
float decibels = 20 * log10(rms);
printf("RMS: %f dB: %f\n", rms, decibels);
if (decibels >= 39) {
ESP_LOGI(TAG, "dB over");
capture_flag = true;
memset(i2s_buffer, 0, sizeof(i2s_buffer));
vTaskDelay(pdMS_TO_TICKS(1500));
void app_main()
esp_err_t err;
// Initialize NVS
if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND)
connect_wifi();
if (wifi_connect_status)
err = init_camera();
if (err != ESP_OK)
ESP_LOGE(TAG, "Camera init failed: %s", esp_err_to_name(err));
return;
setup_server();
ESP_LOGI(TAG, "ESP32 CAM Web Server is up and running\n");
xTaskCreatePinnedToCore(capture_image_task, "capture_image_task", 4096, NULL, 5, NULL, 0);
xTaskCreatePinnedToCore(measure_decibel_task, "measure_decibel_task", 4096, NULL, 6, NULL, 1);
