In, for example, an OS context switch, the assembly code must write to the mstatus register with something like:
csrw mstatus, t0What I notice is that when this instruction is executed by instruction single-stepping, the value of mstatus does not change, but if I set a breakpoint somewhere past this instruction and continue over it, the value of mstatus will change.
The simplest example I have to show this is below:
.section .text.start, "ax", %progbits
.global start
.type start, %function
start:
csrs mstatus, 8
ebreak
I'm wondering if something about the debugger is implicitly manipulating mstatus in an unexpected way.
Loading the program and continuing:
(gdb) continue
Continuing.
Program received signal SIGTRAP, Trace/breakpoint trap.
start () at src/start/start.S:6
6 ebreak
(gdb) p/x $mstatus
$1 = 0x88
(gdb) si
6 ebreak
(gdb) p/x $mstatus
$2 = 0x0
