ESP32 can not initialize IP101 Ethernet PHY
Posted: Mon Jul 08, 2024 2:31 pm
by Vilius
I have spent a lot of time developing some ESP32 ethernet application on a genuine ESP Ethernet development board. I wrote a very long code that worked flawlessly on my testing hardware setup. Now I am implementing all that on a custom PCB. I can flash and get logs from ESP microcontroller, so I guess there is no hardware problems related to ESP32. However, as soon as I try to run the developed code on the ESP, I get logs:
I (31) boot: ESP-IDF v5.1.1 2nd stage bootloader
I (31) boot: compile time Jul 2 2024 14:39:20
I (31) boot: Multicore bootloader
I (36) boot: chip revision: v3.0
I (40) boot.esp32: SPI Speed : 20MHz
I (44) boot.esp32: SPI Mode : DIO
I (49) boot.esp32: SPI Flash Size : 16MB
I (53) boot: Enabling RNG early entropy source...
I (59) boot: Partition Table:
I (62) boot: ## Label Usage Type ST Offset Length
I (70) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (77) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (85) boot: 2 factory factory app 00 00 00010000 00100000
I (92) boot: End of partition table
I (96) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=210f0h (135408) map
I (149) esp_image: segment 1: paddr=00031118 vaddr=3ffb0000 size=064cch ( 25804) load
I (158) esp_image: segment 2: paddr=000375ec vaddr=40080000 size=08a2ch ( 35372) load
I (172) esp_image: segment 3: paddr=00040020 vaddr=400d0020 size=59358h (365400) map
I (291) esp_image: segment 4: paddr=00099380 vaddr=40088a2c size=04f84h ( 20356) load
I (307) boot: Loaded app from partition at offset 0x10000
I (307) boot: Disabling RNG early entropy source...
I (318) cpu_start: Multicore app
I (319) cpu_start: Pro cpu up.
I (319) cpu_start: Starting app cpu, entry point is 0x400813a0
0x400813a0: call_start_cpu1 at D:/ESPIDF/esp-idf/components/esp_system/port/cpu_start.c:154
I (306) cpu_start: App cpu up.
I (337) cpu_start: Pro cpu start user code
I (337) cpu_start: cpu freq: 240000000 Hz
I (337) cpu_start: Application information:
I (342) cpu_start: Project name: ESPTCP
I (347) cpu_start: App version: 1
I (351) cpu_start: Compile time: Jul 8 2024 15:04:18
I (357) cpu_start: ELF file SHA256: 156b58563b3a0660...
I (363) cpu_start: ESP-IDF: v5.1.1
I (368) cpu_start: Min chip rev: v0.0
I (373) cpu_start: Max chip rev: v3.99
I (377) cpu_start: Chip rev: v3.0
I (383) heap_init: Initializing. RAM available for dynamic allocation:
I (390) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (395) heap_init: At 3FFB8088 len 00027F78 (159 KiB): DRAM
I (402) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (408) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (414) heap_init: At 4008D9B0 len 00012650 (73 KiB): IRAM
I (423) spi_flash: detected chip: winbond
I (425) spi_flash: flash io: dio
I (430) app_start: Starting scheduler on CPU0
I (434) app_start: Starting scheduler on CPU1
I (434) main_task: Started on CPU0
I (444) main_task: Calling app_main()
E (2554) esp.emac: emac_esp32_init(369): reset timeout
E (2554) esp_eth: esp_eth_driver_install(228): init mac failed
E (2554) example_eth_init: eth_init_internal(89): Ethernet driver install failed
E (2564) example_eth_init: example_eth_init(244): internal Ethernet init failed
ESP_ERROR_CHECK failed: esp_err_t 0xffffffff (ESP_FAIL) at 0x400d82b8
0x400d82b8: app_main at C:/Users/Admin/Desktop/ESPTCP/main/main.c:512 (discriminator 1)
file: "./main/main.c" line 512
func: app_main
expression: example_eth_init(&eth_handles, &eth_port_cnt)
abort() was called at PC 0x4008680b on core 0
0x4008680b: _esp_error_check_failed at D:/ESPIDF/esp-idf/components/esp_system/esp_err.c:50
Backtrace: 0x400819ce:0x3ffc1cb0 0x40086815:0x3ffc1cd0 0x4008c4f6:0x3ffc1cf0 0x4008680b:0x3ffc1d60 0x400d82b8:0x3ffc1d90 0x40128a40:0x3ffc1e50 0x400890ed:0x3ffc1e70
0x400819ce: panic_abort at D:/ESPIDF/esp-idf/components/esp_system/panic.c:452
0x40086815: esp_system_abort at D:/ESPIDF/esp-idf/components/esp_system/port/esp_system_chip.c:84
0x4008c4f6: abort at D:/ESPIDF/esp-idf/components/newlib/abort.c:38
0x40128a40: main_task at D:/ESPIDF/esp-idf/components/freertos/app_startup.c:208
0x400890ed: vPortTaskWrapper at D:/ESPIDF/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:162
After doing initial research online, I saw that most likely the problem lies in the IP101 clock and synchronization with ESP32. Down below in the attachments, you can see my hardware schematics. I tried various different combinations of the highlighted components (placing and removing them one by one) But it did not give me any consistent results. I may be wrong, but I want to pick the internal 50 MHz ref clock as the main clock source (I should be getting that 50 MHz clock signal on the GPIO 0 as an input from the perspective of the ESP.) It happened for a couple of times but it was not consistent. Other than that I have checked my wiring, menuconfig PHY settings for reset pin and even the sdkconfig file for the right RMII GPIO pins. I am almost certain that problem lies somewhere in the hardware but I do not understand where exactly. I made the schematic replicating ethernet part of the mentioned ESP ethernet devboard (pdf in the attachments), but maybe they have implemented slight modifications to proceeding revisions (its just a guess anyway...) I highly appreciate any observations or advices on what could be wrong with my IP101 hardware schematics.
My sdkconfig file (because only 3 attachments are allowed):
# Automatically generated file. DO NOT EDIT.
# Espressif IoT Development Framework (ESP-IDF) 5.1.1 Project Configuration
CONFIG_SOC_BROWNOUT_RESET_SUPPORTED="Not determined"
CONFIG_SOC_TWAI_BRP_DIV_SUPPORTED="Not determined"
CONFIG_SOC_DPORT_WORKAROUND="Not determined"
CONFIG_SOC_CAPS_ECO_VER_MAX=301
CONFIG_SOC_ADC_SUPPORTED=y
CONFIG_SOC_DAC_SUPPORTED=y
CONFIG_SOC_UART_SUPPORTED=y
CONFIG_SOC_MCPWM_SUPPORTED=y
CONFIG_SOC_GPTIMER_SUPPORTED=y
CONFIG_SOC_SDMMC_HOST_SUPPORTED=y
CONFIG_SOC_BT_SUPPORTED=y
CONFIG_SOC_PCNT_SUPPORTED=y
CONFIG_SOC_WIFI_SUPPORTED=y
CONFIG_SOC_SDIO_SLAVE_SUPPORTED=y
CONFIG_SOC_TWAI_SUPPORTED=y
CONFIG_SOC_EMAC_SUPPORTED=y
CONFIG_SOC_ULP_SUPPORTED=y
CONFIG_SOC_CCOMP_TIMER_SUPPORTED=y
CONFIG_SOC_RTC_FAST_MEM_SUPPORTED=y
CONFIG_SOC_RTC_SLOW_MEM_SUPPORTED=y
CONFIG_SOC_RTC_MEM_SUPPORTED=y
CONFIG_SOC_I2S_SUPPORTED=y
CONFIG_SOC_RMT_SUPPORTED=y
CONFIG_SOC_SDM_SUPPORTED=y
CONFIG_SOC_GPSPI_SUPPORTED=y
CONFIG_SOC_LEDC_SUPPORTED=y
CONFIG_SOC_I2C_SUPPORTED=y
CONFIG_SOC_SUPPORT_COEXISTENCE=y
CONFIG_SOC_AES_SUPPORTED=y
CONFIG_SOC_MPI_SUPPORTED=y
CONFIG_SOC_SHA_SUPPORTED=y
CONFIG_SOC_FLASH_ENC_SUPPORTED=y
CONFIG_SOC_SECURE_BOOT_SUPPORTED=y
CONFIG_SOC_TOUCH_SENSOR_SUPPORTED=y
CONFIG_SOC_BOD_SUPPORTED=y
CONFIG_SOC_ULP_FSM_SUPPORTED=y
CONFIG_SOC_DPORT_WORKAROUND_DIS_INTERRUPT_LVL=5
CONFIG_SOC_XTAL_SUPPORT_26M=y
CONFIG_SOC_XTAL_SUPPORT_40M=y
CONFIG_SOC_XTAL_SUPPORT_AUTO_DETECT=y
CONFIG_SOC_ADC_RTC_CTRL_SUPPORTED=y
CONFIG_SOC_ADC_DIG_CTRL_SUPPORTED=y
CONFIG_SOC_ADC_DMA_SUPPORTED=y
CONFIG_SOC_ADC_PERIPH_NUM=2
CONFIG_SOC_ADC_MAX_CHANNEL_NUM=10
CONFIG_SOC_ADC_ATTEN_NUM=4
CONFIG_SOC_ADC_DIGI_CONTROLLER_NUM=2
CONFIG_SOC_ADC_PATT_LEN_MAX=16
CONFIG_SOC_ADC_DIGI_MIN_BITWIDTH=9
CONFIG_SOC_ADC_DIGI_MAX_BITWIDTH=12
CONFIG_SOC_ADC_DIGI_RESULT_BYTES=2
CONFIG_SOC_ADC_DIGI_DATA_BYTES_PER_CONV=4
CONFIG_SOC_ADC_SAMPLE_FREQ_THRES_HIGH=2
CONFIG_SOC_ADC_SAMPLE_FREQ_THRES_LOW=20
CONFIG_SOC_ADC_RTC_MIN_BITWIDTH=9
CONFIG_SOC_ADC_RTC_MAX_BITWIDTH=12
CONFIG_SOC_SHARED_IDCACHE_SUPPORTED=y
CONFIG_SOC_IDCACHE_PER_CORE=y
CONFIG_SOC_CPU_CORES_NUM=2
CONFIG_SOC_CPU_INTR_NUM=32
CONFIG_SOC_CPU_HAS_FPU=y
CONFIG_SOC_CPU_BREAKPOINTS_NUM=2
CONFIG_SOC_CPU_WATCHPOINTS_NUM=2
CONFIG_SOC_CPU_WATCHPOINT_SIZE=64
CONFIG_SOC_DAC_CHAN_NUM=2
CONFIG_SOC_DAC_RESOLUTION=8
CONFIG_SOC_DAC_DMA_16BIT_ALIGN=y
CONFIG_SOC_GPIO_PORT=1
CONFIG_SOC_GPIO_PIN_COUNT=40
CONFIG_SOC_GPIO_VALID_GPIO_MASK=0xFFFFFFFFFF
CONFIG_SOC_GPIO_VALID_DIGITAL_IO_PAD_MASK=0xEF0FEA
CONFIG_SOC_I2C_NUM=2
CONFIG_SOC_I2C_FIFO_LEN=32
CONFIG_SOC_I2C_CMD_REG_NUM=16
CONFIG_SOC_I2C_SUPPORT_SLAVE=y
CONFIG_SOC_I2C_SUPPORT_APB=y
CONFIG_SOC_I2S_NUM=2
CONFIG_SOC_I2S_HW_VERSION_1=y
CONFIG_SOC_I2S_SUPPORTS_APLL=y
CONFIG_SOC_I2S_SUPPORTS_PLL_F160M=y
CONFIG_SOC_I2S_SUPPORTS_PDM=y
CONFIG_SOC_I2S_SUPPORTS_PDM_TX=y
CONFIG_SOC_I2S_PDM_MAX_TX_LINES=1
CONFIG_SOC_I2S_SUPPORTS_PDM_RX=y
CONFIG_SOC_I2S_PDM_MAX_RX_LINES=1
CONFIG_SOC_I2S_SUPPORTS_ADC_DAC=y
CONFIG_SOC_I2S_SUPPORTS_ADC=y
CONFIG_SOC_I2S_SUPPORTS_DAC=y
CONFIG_SOC_I2S_SUPPORTS_LCD_CAMERA=y
CONFIG_SOC_I2S_TRANS_SIZE_ALIGN_WORD=y
CONFIG_SOC_I2S_LCD_I80_VARIANT=y
CONFIG_SOC_LCD_I80_SUPPORTED=y
CONFIG_SOC_LCD_I80_BUSES=2
CONFIG_SOC_LCD_I80_BUS_WIDTH=24
CONFIG_SOC_LEDC_HAS_TIMER_SPECIFIC_MUX=y
CONFIG_SOC_LEDC_SUPPORT_APB_CLOCK=y
CONFIG_SOC_LEDC_SUPPORT_REF_TICK=y
CONFIG_SOC_LEDC_SUPPORT_HS_MODE=y
CONFIG_SOC_LEDC_CHANNEL_NUM=8
CONFIG_SOC_LEDC_TIMER_BIT_WIDTH=20
CONFIG_SOC_MCPWM_GROUPS=2
CONFIG_SOC_MCPWM_TIMERS_PER_GROUP=3
CONFIG_SOC_MCPWM_OPERATORS_PER_GROUP=3
CONFIG_SOC_MCPWM_COMPARATORS_PER_OPERATOR=2
CONFIG_SOC_MCPWM_GENERATORS_PER_OPERATOR=2
CONFIG_SOC_MCPWM_TRIGGERS_PER_OPERATOR=2
CONFIG_SOC_MCPWM_GPIO_FAULTS_PER_GROUP=3
CONFIG_SOC_MCPWM_CAPTURE_TIMERS_PER_GROUP=y
CONFIG_SOC_MCPWM_CAPTURE_CHANNELS_PER_TIMER=3
CONFIG_SOC_MCPWM_GPIO_SYNCHROS_PER_GROUP=3
CONFIG_SOC_MMU_PERIPH_NUM=2
CONFIG_SOC_MMU_LINEAR_ADDRESS_REGION_NUM=3
CONFIG_SOC_MPU_MIN_REGION_SIZE=0x20000000
CONFIG_SOC_MPU_REGIONS_MAX_NUM=8
CONFIG_SOC_PCNT_GROUPS=1
CONFIG_SOC_PCNT_UNITS_PER_GROUP=8
CONFIG_SOC_PCNT_CHANNELS_PER_UNIT=2
CONFIG_SOC_PCNT_THRES_POINT_PER_UNIT=2
CONFIG_SOC_RMT_GROUPS=1
CONFIG_SOC_RMT_TX_CANDIDATES_PER_GROUP=8
CONFIG_SOC_RMT_RX_CANDIDATES_PER_GROUP=8
CONFIG_SOC_RMT_CHANNELS_PER_GROUP=8
CONFIG_SOC_RMT_MEM_WORDS_PER_CHANNEL=64
CONFIG_SOC_RMT_SUPPORT_REF_TICK=y
CONFIG_SOC_RMT_SUPPORT_APB=y
CONFIG_SOC_RMT_CHANNEL_CLK_INDEPENDENT=y
CONFIG_SOC_RTCIO_PIN_COUNT=18
CONFIG_SOC_RTCIO_INPUT_OUTPUT_SUPPORTED=y
CONFIG_SOC_RTCIO_HOLD_SUPPORTED=y
CONFIG_SOC_RTCIO_WAKE_SUPPORTED=y
CONFIG_SOC_SDM_GROUPS=1
CONFIG_SOC_SDM_CHANNELS_PER_GROUP=8
CONFIG_SOC_SDM_CLK_SUPPORT_APB=y
CONFIG_SOC_SPI_HD_BOTH_INOUT_SUPPORTED=y
CONFIG_SOC_SPI_AS_CS_SUPPORTED=y
CONFIG_SOC_SPI_PERIPH_NUM=3
CONFIG_SOC_SPI_DMA_CHAN_NUM=2
CONFIG_SOC_SPI_MAX_CS_NUM=3
CONFIG_SOC_SPI_SUPPORT_CLK_APB=y
CONFIG_SOC_SPI_MAXIMUM_BUFFER_SIZE=64
CONFIG_SOC_SPI_MAX_PRE_DIVIDER=8192
CONFIG_SOC_MEMSPI_SRC_FREQ_80M_SUPPORTED=y
CONFIG_SOC_MEMSPI_SRC_FREQ_40M_SUPPORTED=y
CONFIG_SOC_MEMSPI_SRC_FREQ_26M_SUPPORTED=y
CONFIG_SOC_MEMSPI_SRC_FREQ_20M_SUPPORTED=y
CONFIG_SOC_TIMER_GROUPS=2
CONFIG_SOC_TIMER_GROUP_TIMERS_PER_GROUP=2
CONFIG_SOC_TIMER_GROUP_COUNTER_BIT_WIDTH=64
CONFIG_SOC_TIMER_GROUP_TOTAL_TIMERS=4
CONFIG_SOC_TIMER_GROUP_SUPPORT_APB=y
CONFIG_SOC_TOUCH_VERSION_1=y
CONFIG_SOC_TOUCH_SENSOR_NUM=10
CONFIG_SOC_TOUCH_PAD_MEASURE_WAIT_MAX=0xFF
CONFIG_SOC_TWAI_CONTROLLER_NUM=1
CONFIG_SOC_TWAI_BRP_MIN=2
CONFIG_SOC_TWAI_CLK_SUPPORT_APB=y
CONFIG_SOC_TWAI_SUPPORT_MULTI_ADDRESS_LAYOUT=y
CONFIG_SOC_UART_NUM=3
CONFIG_SOC_UART_SUPPORT_APB_CLK=y
CONFIG_SOC_UART_SUPPORT_REF_TICK=y
CONFIG_SOC_UART_FIFO_LEN=128
CONFIG_SOC_UART_BITRATE_MAX=5000000
CONFIG_SOC_SPIRAM_SUPPORTED=y
CONFIG_SOC_SPI_MEM_SUPPORT_CONFIG_GPIO_BY_EFUSE=y
CONFIG_SOC_SHA_SUPPORT_PARALLEL_ENG=y
CONFIG_SOC_SHA_SUPPORT_SHA1=y
CONFIG_SOC_SHA_SUPPORT_SHA256=y
CONFIG_SOC_SHA_SUPPORT_SHA384=y
CONFIG_SOC_SHA_SUPPORT_SHA512=y
CONFIG_SOC_RSA_MAX_BIT_LEN=4096
CONFIG_SOC_AES_SUPPORT_AES_128=y
CONFIG_SOC_AES_SUPPORT_AES_192=y
CONFIG_SOC_AES_SUPPORT_AES_256=y
CONFIG_SOC_SECURE_BOOT_V1=y
CONFIG_SOC_EFUSE_SECURE_BOOT_KEY_DIGESTS=y
CONFIG_SOC_FLASH_ENCRYPTED_XTS_AES_BLOCK_MAX=32
CONFIG_SOC_PHY_DIG_REGS_MEM_SIZE=21
CONFIG_SOC_PM_SUPPORT_EXT0_WAKEUP=y
CONFIG_SOC_PM_SUPPORT_EXT1_WAKEUP=y
CONFIG_SOC_PM_SUPPORT_EXT_WAKEUP=y
CONFIG_SOC_PM_SUPPORT_TOUCH_SENSOR_WAKEUP=y
CONFIG_SOC_PM_SUPPORT_RTC_PERIPH_PD=y
CONFIG_SOC_PM_SUPPORT_RTC_FAST_MEM_PD=y
CONFIG_SOC_PM_SUPPORT_RTC_SLOW_MEM_PD=y
CONFIG_SOC_PM_SUPPORT_RC_FAST_PD=y
CONFIG_SOC_PM_SUPPORT_VDDSDIO_PD=y
CONFIG_SOC_PM_SUPPORT_MODEM_PD=y
CONFIG_SOC_CONFIGURABLE_VDDSDIO_SUPPORTED=y
CONFIG_SOC_CLK_APLL_SUPPORTED=y
CONFIG_SOC_APLL_MULTIPLIER_OUT_MIN_HZ=350000000
CONFIG_SOC_APLL_MULTIPLIER_OUT_MAX_HZ=500000000
CONFIG_SOC_APLL_MIN_HZ=5303031
CONFIG_SOC_APLL_MAX_HZ=125000000
CONFIG_SOC_CLK_RC_FAST_D256_SUPPORTED=y
CONFIG_SOC_RTC_SLOW_CLK_SUPPORT_RC_FAST_D256=y
CONFIG_SOC_CLK_RC_FAST_SUPPORT_CALIBRATION=y
CONFIG_SOC_CLK_XTAL32K_SUPPORTED=y
CONFIG_SOC_SDMMC_USE_IOMUX=y
CONFIG_SOC_SDMMC_NUM_SLOTS=2
CONFIG_SOC_WIFI_WAPI_SUPPORT=y
CONFIG_SOC_WIFI_CSI_SUPPORT=y
CONFIG_SOC_WIFI_MESH_SUPPORT=y
CONFIG_SOC_WIFI_SUPPORT_VARIABLE_BEACON_WINDOW=y
CONFIG_SOC_WIFI_NAN_SUPPORT=y
CONFIG_SOC_BLE_SUPPORTED=y
CONFIG_SOC_BLE_MESH_SUPPORTED=y
CONFIG_SOC_BT_CLASSIC_SUPPORTED=y
CONFIG_SOC_BLUFI_SUPPORTED=y
CONFIG_SOC_ULP_HAS_ADC=y
CONFIG_IDF_CMAKE=y
CONFIG_IDF_TARGET_ARCH_XTENSA=y
CONFIG_IDF_TARGET_ARCH="xtensa"
CONFIG_IDF_TARGET="esp32"
CONFIG_IDF_TARGET_ESP32=y
CONFIG_IDF_FIRMWARE_CHIP_ID=0x0000
# Build type
CONFIG_APP_BUILD_TYPE_APP_2NDBOOT=y
# CONFIG_APP_BUILD_TYPE_RAM is not set
CONFIG_APP_BUILD_GENERATE_BINARIES=y
CONFIG_APP_BUILD_BOOTLOADER=y
CONFIG_APP_BUILD_USE_FLASH_SECTIONS=y
# CONFIG_APP_REPRODUCIBLE_BUILD is not set
# CONFIG_APP_NO_BLOBS is not set
# CONFIG_APP_COMPATIBLE_PRE_V2_1_BOOTLOADERS is not set
# CONFIG_APP_COMPATIBLE_PRE_V3_1_BOOTLOADERS is not set
# end of Build type
# Bootloader config
CONFIG_BOOTLOADER_OFFSET_IN_FLASH=0x1000
CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_SIZE=y
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_DEBUG is not set
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_PERF is not set
# CONFIG_BOOTLOADER_COMPILER_OPTIMIZATION_NONE is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_NONE is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_ERROR is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_WARN is not set
CONFIG_BOOTLOADER_LOG_LEVEL_INFO=y
# CONFIG_BOOTLOADER_LOG_LEVEL_DEBUG is not set
# CONFIG_BOOTLOADER_LOG_LEVEL_VERBOSE is not set
CONFIG_BOOTLOADER_LOG_LEVEL=3
# CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_8V is not set
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V=y
# CONFIG_BOOTLOADER_FACTORY_RESET is not set
# CONFIG_BOOTLOADER_APP_TEST is not set
CONFIG_BOOTLOADER_REGION_PROTECTION_ENABLE=y
# CONFIG_BOOTLOADER_WDT_ENABLE is not set
# CONFIG_BOOTLOADER_APP_ROLLBACK_ENABLE is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_IN_DEEP_SLEEP is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_ON_POWER_ON is not set
# CONFIG_BOOTLOADER_SKIP_VALIDATE_ALWAYS is not set
CONFIG_BOOTLOADER_RESERVE_RTC_SIZE=0
# CONFIG_BOOTLOADER_CUSTOM_RESERVE_RTC is not set
CONFIG_BOOTLOADER_FLASH_XMC_SUPPORT=y
# end of Bootloader config
# Security features
CONFIG_SECURE_BOOT_V1_SUPPORTED=y
# CONFIG_SECURE_SIGNED_APPS_NO_SECURE_BOOT is not set
# CONFIG_SECURE_BOOT is not set
# CONFIG_SECURE_FLASH_ENC_ENABLED is not set
# end of Security features
# Application manager
CONFIG_APP_COMPILE_TIME_DATE=y
# CONFIG_APP_EXCLUDE_PROJECT_VER_VAR is not set
# CONFIG_APP_EXCLUDE_PROJECT_NAME_VAR is not set
# CONFIG_APP_PROJECT_VER_FROM_CONFIG is not set
CONFIG_APP_RETRIEVE_LEN_ELF_SHA=16
# end of Application manager
CONFIG_ESP_ROM_HAS_CRC_LE=y
CONFIG_ESP_ROM_HAS_CRC_BE=y
CONFIG_ESP_ROM_HAS_MZ_CRC32=y
CONFIG_ESP_ROM_HAS_JPEG_DECODE=y
CONFIG_ESP_ROM_HAS_UART_BUF_SWITCH=y
CONFIG_ESP_ROM_NEEDS_SWSETUP_WORKAROUND=y
CONFIG_ESP_ROM_HAS_NEWLIB_NANO_FORMAT=y
# Serial flasher config
# CONFIG_ESPTOOLPY_NO_STUB is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QIO is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE_DIO=y
# CONFIG_ESPTOOLPY_FLASHMODE_DOUT is not set
CONFIG_ESPTOOLPY_FLASH_SAMPLE_MODE_STR=y
CONFIG_ESPTOOLPY_FLASHMODE="dio"
# CONFIG_ESPTOOLPY_FLASHFREQ_80M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_40M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_26M is not set
CONFIG_ESPTOOLPY_FLASHFREQ_20M=y
CONFIG_ESPTOOLPY_FLASHFREQ="20m"
# CONFIG_ESPTOOLPY_FLASHSIZE_1MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_2MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_4MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_8MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE_16MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_32MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_64MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_128MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="16MB"
CONFIG_ESPTOOLPY_HEADER_FLASHSIZE_UPDATE=y
CONFIG_ESPTOOLPY_BEFORE_RESET=y
# CONFIG_ESPTOOLPY_BEFORE_NORESET is not set
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
# CONFIG_ESPTOOLPY_AFTER_NORESET is not set
CONFIG_ESPTOOLPY_AFTER="hard_reset"
CONFIG_ESPTOOLPY_MONITOR_BAUD=115200
# end of Serial flasher config
# Partition Table
CONFIG_PARTITION_TABLE_SINGLE_APP=y
# CONFIG_PARTITION_TABLE_SINGLE_APP_LARGE is not set
# CONFIG_PARTITION_TABLE_TWO_OTA is not set
# CONFIG_PARTITION_TABLE_CUSTOM is not set
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_FILENAME="partitions_singleapp.csv"
CONFIG_PARTITION_TABLE_OFFSET=0x8000
CONFIG_PARTITION_TABLE_MD5=y
# end of Partition Table
# Example Connection Configuration
CONFIG_ENV_GPIO_RANGE_MIN=0
CONFIG_ENV_GPIO_RANGE_MAX=39
CONFIG_ENV_GPIO_IN_RANGE_MAX=39
CONFIG_ENV_GPIO_OUT_RANGE_MAX=33
# CONFIG_EXAMPLE_CONNECT_WIFI is not set
CONFIG_EXAMPLE_CONNECT_ETHERNET=y
CONFIG_EXAMPLE_ETHERNET_EMAC_TASK_STACK_SIZE=2048
CONFIG_EXAMPLE_USE_INTERNAL_ETHERNET=y
# CONFIG_EXAMPLE_USE_DM9051 is not set
# CONFIG_EXAMPLE_USE_W5500 is not set
# CONFIG_EXAMPLE_USE_OPENETH is not set
CONFIG_EXAMPLE_ETH_PHY_IP101=y
# CONFIG_EXAMPLE_ETH_PHY_RTL8201 is not set
# CONFIG_EXAMPLE_ETH_PHY_LAN87XX is not set
# CONFIG_EXAMPLE_ETH_PHY_DP83848 is not set
# CONFIG_EXAMPLE_ETH_PHY_KSZ80XX is not set
CONFIG_EXAMPLE_ETH_MDC_GPIO=23
CONFIG_EXAMPLE_ETH_MDIO_GPIO=18
CONFIG_EXAMPLE_ETH_PHY_RST_GPIO=5
CONFIG_EXAMPLE_ETH_PHY_ADDR=1
CONFIG_EXAMPLE_CONNECT_IPV4=y
CONFIG_EXAMPLE_CONNECT_IPV6=y
CONFIG_EXAMPLE_CONNECT_IPV6_PREF_LOCAL_LINK=y
# CONFIG_EXAMPLE_CONNECT_IPV6_PREF_GLOBAL is not set
# CONFIG_EXAMPLE_CONNECT_IPV6_PREF_SITE_LOCAL is not set
# CONFIG_EXAMPLE_CONNECT_IPV6_PREF_UNIQUE_LOCAL is not set
# end of Example Connection Configuration
# Compiler options
CONFIG_COMPILER_OPTIMIZATION_DEFAULT=y
# CONFIG_COMPILER_OPTIMIZATION_SIZE is not set
# CONFIG_COMPILER_OPTIMIZATION_PERF is not set
# CONFIG_COMPILER_OPTIMIZATION_NONE is not set
CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_ENABLE=y
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_COMPILER_OPTIMIZATION_ASSERTIONS_DISABLE is not set
CONFIG_COMPILER_FLOAT_LIB_FROM_GCCLIB=y
CONFIG_COMPILER_OPTIMIZATION_ASSERTION_LEVEL=2
# CONFIG_COMPILER_OPTIMIZATION_CHECKS_SILENT is not set
CONFIG_COMPILER_HIDE_PATHS_MACROS=y
# CONFIG_COMPILER_CXX_EXCEPTIONS is not set
# CONFIG_COMPILER_CXX_RTTI is not set
CONFIG_COMPILER_STACK_CHECK_MODE_NONE=y
# CONFIG_COMPILER_STACK_CHECK_MODE_NORM is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_STRONG is not set
# CONFIG_COMPILER_STACK_CHECK_MODE_ALL is not set
# CONFIG_COMPILER_WARN_WRITE_STRINGS is not set
# CONFIG_COMPILER_DISABLE_GCC12_WARNINGS is not set
# CONFIG_COMPILER_DUMP_RTL_FILES is not set
# end of Compiler options
# Component config
# Application Level Tracing
# CONFIG_APPTRACE_DEST_JTAG is not set
CONFIG_APPTRACE_DEST_NONE=y
# CONFIG_APPTRACE_DEST_UART1 is not set
# CONFIG_APPTRACE_DEST_UART2 is not set
CONFIG_APPTRACE_DEST_UART_NONE=y
CONFIG_APPTRACE_UART_TASK_PRIO=1
CONFIG_APPTRACE_LOCK_ENABLE=y
# end of Application Level Tracing
# Bluetooth
# CONFIG_BT_ENABLED is not set
# end of Bluetooth
# Driver Configurations
# Legacy ADC Configuration
CONFIG_ADC_DISABLE_DAC=y
# CONFIG_ADC_SUPPRESS_DEPRECATE_WARN is not set
# Legacy ADC Calibration Configuration
CONFIG_ADC_CAL_EFUSE_TP_ENABLE=y
CONFIG_ADC_CAL_EFUSE_VREF_ENABLE=y
CONFIG_ADC_CAL_LUT_ENABLE=y
# CONFIG_ADC_CALI_SUPPRESS_DEPRECATE_WARN is not set
# end of Legacy ADC Calibration Configuration
# end of Legacy ADC Configuration
# SPI Configuration
# CONFIG_SPI_MASTER_IN_IRAM is not set
CONFIG_SPI_MASTER_ISR_IN_IRAM=y
# CONFIG_SPI_SLAVE_IN_IRAM is not set
CONFIG_SPI_SLAVE_ISR_IN_IRAM=y
# end of SPI Configuration
# TWAI Configuration
# CONFIG_TWAI_ISR_IN_IRAM is not set
CONFIG_TWAI_ERRATA_FIX_BUS_OFF_REC=y
CONFIG_TWAI_ERRATA_FIX_TX_INTR_LOST=y
CONFIG_TWAI_ERRATA_FIX_RX_FRAME_INVALID=y
CONFIG_TWAI_ERRATA_FIX_RX_FIFO_CORRUPT=y
CONFIG_TWAI_ERRATA_FIX_LISTEN_ONLY_DOM=y
# end of TWAI Configuration
# UART Configuration
# CONFIG_UART_ISR_IN_IRAM is not set
# end of UART Configuration
# GPIO Configuration
# CONFIG_GPIO_ESP32_SUPPORT_SWITCH_SLP_PULL is not set
# CONFIG_GPIO_CTRL_FUNC_IN_IRAM is not set
# end of GPIO Configuration
# Sigma Delta Modulator Configuration
# CONFIG_SDM_CTRL_FUNC_IN_IRAM is not set
# CONFIG_SDM_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_SDM_ENABLE_DEBUG_LOG is not set
# end of Sigma Delta Modulator Configuration
# GPTimer Configuration
# CONFIG_GPTIMER_CTRL_FUNC_IN_IRAM is not set
# CONFIG_GPTIMER_ISR_IRAM_SAFE is not set
# CONFIG_GPTIMER_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_GPTIMER_ENABLE_DEBUG_LOG is not set
# end of GPTimer Configuration
# PCNT Configuration
# CONFIG_PCNT_CTRL_FUNC_IN_IRAM is not set
# CONFIG_PCNT_ISR_IRAM_SAFE is not set
# CONFIG_PCNT_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_PCNT_ENABLE_DEBUG_LOG is not set
# end of PCNT Configuration
# RMT Configuration
# CONFIG_RMT_ISR_IRAM_SAFE is not set
# CONFIG_RMT_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_RMT_ENABLE_DEBUG_LOG is not set
# end of RMT Configuration
# MCPWM Configuration
# CONFIG_MCPWM_ISR_IRAM_SAFE is not set
# CONFIG_MCPWM_CTRL_FUNC_IN_IRAM is not set
# CONFIG_MCPWM_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_MCPWM_ENABLE_DEBUG_LOG is not set
# end of MCPWM Configuration
# I2S Configuration
# CONFIG_I2S_ISR_IRAM_SAFE is not set
# CONFIG_I2S_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_I2S_ENABLE_DEBUG_LOG is not set
# end of I2S Configuration
# DAC Configuration
# CONFIG_DAC_CTRL_FUNC_IN_IRAM is not set
# CONFIG_DAC_ISR_IRAM_SAFE is not set
# CONFIG_DAC_SUPPRESS_DEPRECATE_WARN is not set
# CONFIG_DAC_ENABLE_DEBUG_LOG is not set
CONFIG_DAC_DMA_AUTO_16BIT_ALIGN=y
# end of DAC Configuration
# end of Driver Configurations
# eFuse Bit Manager
# CONFIG_EFUSE_CUSTOM_TABLE is not set
# CONFIG_EFUSE_VIRTUAL is not set
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_NONE is not set
CONFIG_EFUSE_CODE_SCHEME_COMPAT_3_4=y
# CONFIG_EFUSE_CODE_SCHEME_COMPAT_REPEAT is not set
CONFIG_EFUSE_MAX_BLK_LEN=192
# end of eFuse Bit Manager
# ESP-TLS
CONFIG_ESP_TLS_USING_MBEDTLS=y
# CONFIG_ESP_TLS_USE_SECURE_ELEMENT is not set
# CONFIG_ESP_TLS_CLIENT_SESSION_TICKETS is not set
# CONFIG_ESP_TLS_SERVER is not set
# CONFIG_ESP_TLS_PSK_VERIFICATION is not set
# CONFIG_ESP_TLS_INSECURE is not set
# end of ESP-TLS
# ADC and ADC Calibration
# CONFIG_ADC_ONESHOT_CTRL_FUNC_IN_IRAM is not set
# CONFIG_ADC_CONTINUOUS_ISR_IRAM_SAFE is not set
# ADC Calibration Configurations
CONFIG_ADC_CALI_EFUSE_TP_ENABLE=y
CONFIG_ADC_CALI_EFUSE_VREF_ENABLE=y
CONFIG_ADC_CALI_LUT_ENABLE=y
# end of ADC Calibration Configurations
CONFIG_ADC_DISABLE_DAC_OUTPUT=y
# end of ADC and ADC Calibration
# Wireless Coexistence
# end of Wireless Coexistence
# Common ESP-related
CONFIG_ESP_ERR_TO_NAME_LOOKUP=y
# end of Common ESP-related
# Ethernet
CONFIG_ETH_ENABLED=y
CONFIG_ETH_USE_ESP32_EMAC=y
CONFIG_ETH_PHY_INTERFACE_RMII=y
CONFIG_ETH_RMII_CLK_INPUT=y
# CONFIG_ETH_RMII_CLK_OUTPUT is not set
CONFIG_ETH_RMII_CLK_IN_GPIO=0
CONFIG_ETH_DMA_BUFFER_SIZE=512
CONFIG_ETH_DMA_RX_BUFFER_NUM=10
CONFIG_ETH_DMA_TX_BUFFER_NUM=10
CONFIG_ETH_USE_SPI_ETHERNET=y
# CONFIG_ETH_SPI_ETHERNET_DM9051 is not set
# CONFIG_ETH_SPI_ETHERNET_W5500 is not set
# CONFIG_ETH_SPI_ETHERNET_KSZ8851SNL is not set
# CONFIG_ETH_USE_OPENETH is not set
CONFIG_ETH_TRANSMIT_MUTEX=y
# end of Ethernet
# Event Loop Library
# CONFIG_ESP_EVENT_LOOP_PROFILING is not set
CONFIG_ESP_EVENT_POST_FROM_ISR=y
CONFIG_ESP_EVENT_POST_FROM_IRAM_ISR=y
# end of Event Loop Library
# GDB Stub
# end of GDB Stub
# ESP HTTP client
CONFIG_ESP_HTTP_CLIENT_ENABLE_HTTPS=y
# CONFIG_ESP_HTTP_CLIENT_ENABLE_BASIC_AUTH is not set
# CONFIG_ESP_HTTP_CLIENT_ENABLE_DIGEST_AUTH is not set
# end of ESP HTTP client
# HTTP Server
CONFIG_HTTPD_MAX_REQ_HDR_LEN=512
CONFIG_HTTPD_MAX_URI_LEN=512
CONFIG_HTTPD_ERR_RESP_NO_DELAY=y
CONFIG_HTTPD_PURGE_BUF_LEN=32
# CONFIG_HTTPD_LOG_PURGE_DATA is not set
# CONFIG_HTTPD_WS_SUPPORT is not set
# CONFIG_HTTPD_QUEUE_WORK_BLOCKING is not set
# end of HTTP Server
# ESP HTTPS OTA
# CONFIG_ESP_HTTPS_OTA_DECRYPT_CB is not set
# CONFIG_ESP_HTTPS_OTA_ALLOW_HTTP is not set
# end of ESP HTTPS OTA
# ESP HTTPS server
# CONFIG_ESP_HTTPS_SERVER_ENABLE is not set
# end of ESP HTTPS server
# Hardware Settings
# Chip revision
CONFIG_ESP32_REV_MIN_0=y
# CONFIG_ESP32_REV_MIN_1 is not set
# CONFIG_ESP32_REV_MIN_1_1 is not set
# CONFIG_ESP32_REV_MIN_2 is not set
# CONFIG_ESP32_REV_MIN_3 is not set
# CONFIG_ESP32_REV_MIN_3_1 is not set
CONFIG_ESP32_REV_MIN=0
CONFIG_ESP32_REV_MIN_FULL=0
CONFIG_ESP_REV_MIN_FULL=0
# Maximum Supported ESP32 Revision (Rev v3.99)
CONFIG_ESP32_REV_MAX_FULL=399
CONFIG_ESP_REV_MAX_FULL=399
# end of Chip revision
# MAC Config
CONFIG_ESP_MAC_ADDR_UNIVERSE_WIFI_STA=y
CONFIG_ESP_MAC_ADDR_UNIVERSE_WIFI_AP=y
CONFIG_ESP_MAC_ADDR_UNIVERSE_BT=y
CONFIG_ESP_MAC_ADDR_UNIVERSE_ETH=y
CONFIG_ESP_MAC_UNIVERSAL_MAC_ADDRESSES_FOUR=y
# CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_TWO is not set
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES_FOUR=y
CONFIG_ESP32_UNIVERSAL_MAC_ADDRESSES=4
# CONFIG_ESP_MAC_IGNORE_MAC_CRC_ERROR is not set
# end of MAC Config
# Sleep Config
# CONFIG_ESP_SLEEP_POWER_DOWN_FLASH is not set
CONFIG_ESP_SLEEP_FLASH_LEAKAGE_WORKAROUND=y
# CONFIG_ESP_SLEEP_MSPI_NEED_ALL_IO_PU is not set
CONFIG_ESP_SLEEP_RTC_BUS_ISO_WORKAROUND=y
# CONFIG_ESP_SLEEP_GPIO_RESET_WORKAROUND is not set
CONFIG_ESP_SLEEP_DEEP_SLEEP_WAKEUP_DELAY=2000
# end of Sleep Config
# RTC Clock Config
CONFIG_RTC_CLK_SRC_INT_RC=y
# CONFIG_RTC_CLK_SRC_EXT_CRYS is not set
# CONFIG_RTC_CLK_SRC_EXT_OSC is not set
# CONFIG_RTC_CLK_SRC_INT_8MD256 is not set
CONFIG_RTC_CLK_CAL_CYCLES=1024
# end of RTC Clock Config
# Peripheral Control
CONFIG_PERIPH_CTRL_FUNC_IN_IRAM=y
# end of Peripheral Control
# Main XTAL Config
# CONFIG_XTAL_FREQ_26 is not set
CONFIG_XTAL_FREQ_40=y
# CONFIG_XTAL_FREQ_AUTO is not set
CONFIG_XTAL_FREQ=40
# end of Main XTAL Config
# end of Hardware Settings
# LCD and Touch Panel
# LCD Touch Drivers are maintained in the IDF Component Registry
# LCD Peripheral Configuration
CONFIG_LCD_PANEL_IO_FORMAT_BUF_SIZE=32
# CONFIG_LCD_ENABLE_DEBUG_LOG is not set
# end of LCD Peripheral Configuration
# end of LCD and Touch Panel
# ESP NETIF Adapter
CONFIG_ESP_NETIF_IP_LOST_TIMER_INTERVAL=120
CONFIG_ESP_NETIF_TCPIP_LWIP=y
# CONFIG_ESP_NETIF_LOOPBACK is not set
CONFIG_ESP_NETIF_USES_TCPIP_WITH_BSD_API=y
CONFIG_ESP_NETIF_RECEIVE_REPORT_ERRORS=y
CONFIG_ESP_NETIF_L2_TAP=y
CONFIG_ESP_NETIF_L2_TAP_MAX_FDS=5
CONFIG_ESP_NETIF_L2_TAP_RX_QUEUE_SIZE=20
CONFIG_ESP_NETIF_BRIDGE_EN=y
# end of ESP NETIF Adapter
# Partition API Configuration
# end of Partition API Configuration
# PHY
CONFIG_ESP_PHY_CALIBRATION_AND_DATA_STORAGE=y
# CONFIG_ESP_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP_PHY_MAX_TX_POWER=20
# CONFIG_ESP_PHY_REDUCE_TX_POWER is not set
CONFIG_ESP_PHY_RF_CAL_PARTIAL=y
# CONFIG_ESP_PHY_RF_CAL_NONE is not set
# CONFIG_ESP_PHY_RF_CAL_FULL is not set
CONFIG_ESP_PHY_CALIBRATION_MODE=0
# end of PHY
# Power Management
# CONFIG_PM_ENABLE is not set
# end of Power Management
# ESP PSRAM
# CONFIG_SPIRAM is not set
# end of ESP PSRAM
# ESP Ringbuf
# CONFIG_RINGBUF_PLACE_FUNCTIONS_INTO_FLASH is not set
# end of ESP Ringbuf
# ESP System Settings
# CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_80 is not set
# CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_160 is not set
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_240=y
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ=240
# Memory
# CONFIG_ESP32_USE_FIXED_STATIC_RAM_SIZE is not set
# Non-backward compatible options
# CONFIG_ESP_SYSTEM_ESP32_SRAM1_REGION_AS_IRAM is not set
# end of Non-backward compatible options
# end of Memory
# Trace memory
# CONFIG_ESP32_TRAX is not set
CONFIG_ESP32_TRACEMEM_RESERVE_DRAM=0x0
# end of Trace memory
# CONFIG_ESP_SYSTEM_PANIC_PRINT_HALT is not set
CONFIG_ESP_SYSTEM_PANIC_PRINT_REBOOT=y
# CONFIG_ESP_SYSTEM_PANIC_SILENT_REBOOT is not set
# CONFIG_ESP_SYSTEM_PANIC_GDBSTUB is not set
# CONFIG_ESP_SYSTEM_GDBSTUB_RUNTIME is not set
CONFIG_ESP_SYSTEM_PANIC_REBOOT_DELAY_SECONDS=0
# Memory protection
# end of Memory protection
CONFIG_ESP_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_ESP_SYSTEM_EVENT_TASK_STACK_SIZE=30000
CONFIG_ESP_MAIN_TASK_STACK_SIZE=35000
CONFIG_ESP_MAIN_TASK_AFFINITY_CPU0=y
# CONFIG_ESP_MAIN_TASK_AFFINITY_CPU1 is not set
# CONFIG_ESP_MAIN_TASK_AFFINITY_NO_AFFINITY is not set
CONFIG_ESP_MAIN_TASK_AFFINITY=0x0
CONFIG_ESP_MINIMAL_SHARED_STACK_SIZE=1000
CONFIG_ESP_CONSOLE_UART_DEFAULT=y
# CONFIG_ESP_CONSOLE_UART_CUSTOM is not set
# CONFIG_ESP_CONSOLE_NONE is not set
CONFIG_ESP_CONSOLE_UART=y
CONFIG_ESP_CONSOLE_MULTIPLE_UART=y
CONFIG_ESP_CONSOLE_UART_NUM=0
CONFIG_ESP_CONSOLE_UART_BAUDRATE=115200
# CONFIG_ESP_INT_WDT is not set
# CONFIG_ESP_TASK_WDT_EN is not set
# CONFIG_ESP_PANIC_HANDLER_IRAM is not set
# CONFIG_ESP_DEBUG_STUBS_ENABLE is not set
CONFIG_ESP_DEBUG_OCDAWARE=y
# CONFIG_ESP_SYSTEM_CHECK_INT_LEVEL_5 is not set
CONFIG_ESP_SYSTEM_CHECK_INT_LEVEL_4=y
# Brownout Detector
CONFIG_ESP_BROWNOUT_DET=y
CONFIG_ESP_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_ESP_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_ESP_BROWNOUT_DET_LVL=0
# end of Brownout Detector
# CONFIG_ESP32_DISABLE_BASIC_ROM_CONSOLE is not set
CONFIG_ESP_SYSTEM_BROWNOUT_INTR=y
# end of ESP System Settings
# IPC (Inter-Processor Call)
CONFIG_ESP_IPC_TASK_STACK_SIZE=1024
CONFIG_ESP_IPC_USES_CALLERS_PRIORITY=y
CONFIG_ESP_IPC_ISR_ENABLE=y
# end of IPC (Inter-Processor Call)
# High resolution timer (esp_timer)
# CONFIG_ESP_TIMER_PROFILING is not set
CONFIG_ESP_TIME_FUNCS_USE_RTC_TIMER=y
CONFIG_ESP_TIME_FUNCS_USE_ESP_TIMER=y
CONFIG_ESP_TIMER_TASK_STACK_SIZE=3584
CONFIG_ESP_TIMER_INTERRUPT_LEVEL=1
# CONFIG_ESP_TIMER_SHOW_EXPERIMENTAL is not set
CONFIG_ESP_TIMER_TASK_AFFINITY=0x0
CONFIG_ESP_TIMER_TASK_AFFINITY_CPU0=y
CONFIG_ESP_TIMER_ISR_AFFINITY=0x1
CONFIG_ESP_TIMER_ISR_AFFINITY_CPU0=y
# CONFIG_ESP_TIMER_SUPPORTS_ISR_DISPATCH_METHOD is not set
CONFIG_ESP_TIMER_IMPL_TG0_LAC=y
# end of High resolution timer (esp_timer)
# Wi-Fi
CONFIG_ESP_WIFI_ENABLED=y
CONFIG_ESP_WIFI_STATIC_RX_BUFFER_NUM=10
CONFIG_ESP_WIFI_DYNAMIC_RX_BUFFER_NUM=32
# CONFIG_ESP_WIFI_STATIC_TX_BUFFER is not set
CONFIG_ESP_WIFI_DYNAMIC_TX_BUFFER=y
CONFIG_ESP_WIFI_TX_BUFFER_TYPE=1
CONFIG_ESP_WIFI_DYNAMIC_TX_BUFFER_NUM=32
# CONFIG_ESP_WIFI_CSI_ENABLED is not set
CONFIG_ESP_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP_WIFI_TX_BA_WIN=6
CONFIG_ESP_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP_WIFI_RX_BA_WIN=6
CONFIG_ESP_WIFI_NVS_ENABLED=y
CONFIG_ESP_WIFI_TASK_PINNED_TO_CORE_0=y
# CONFIG_ESP_WIFI_TASK_PINNED_TO_CORE_1 is not set
CONFIG_ESP_WIFI_SOFTAP_BEACON_MAX_LEN=752
CONFIG_ESP_WIFI_MGMT_SBUF_NUM=32
CONFIG_ESP_WIFI_IRAM_OPT=y
CONFIG_ESP_WIFI_RX_IRAM_OPT=y
CONFIG_ESP_WIFI_ENABLE_WPA3_SAE=y
CONFIG_ESP_WIFI_ENABLE_SAE_PK=y
CONFIG_ESP_WIFI_SOFTAP_SAE_SUPPORT=y
CONFIG_ESP_WIFI_ENABLE_WPA3_OWE_STA=y
# CONFIG_ESP_WIFI_SLP_IRAM_OPT is not set
CONFIG_ESP_WIFI_STA_DISCONNECTED_PM_ENABLE=y
# CONFIG_ESP_WIFI_GMAC_SUPPORT is not set
CONFIG_ESP_WIFI_SOFTAP_SUPPORT=y
# CONFIG_ESP_WIFI_SLP_BEACON_LOST_OPT is not set
CONFIG_ESP_WIFI_ESPNOW_MAX_ENCRYPT_NUM=7
# CONFIG_ESP_WIFI_NAN_ENABLE is not set
CONFIG_ESP_WIFI_MBEDTLS_CRYPTO=y
CONFIG_ESP_WIFI_MBEDTLS_TLS_CLIENT=y
# CONFIG_ESP_WIFI_WAPI_PSK is not set
# CONFIG_ESP_WIFI_SUITE_B_192 is not set
# CONFIG_ESP_WIFI_11KV_SUPPORT is not set
# CONFIG_ESP_WIFI_MBO_SUPPORT is not set
# CONFIG_ESP_WIFI_DPP_SUPPORT is not set
# CONFIG_ESP_WIFI_11R_SUPPORT is not set
# CONFIG_ESP_WIFI_WPS_SOFTAP_REGISTRAR is not set
# WPS Configuration Options
# CONFIG_ESP_WIFI_WPS_STRICT is not set
# CONFIG_ESP_WIFI_WPS_PASSPHRASE is not set
# end of WPS Configuration Options
# CONFIG_ESP_WIFI_DEBUG_PRINT is not set
# CONFIG_ESP_WIFI_TESTING_OPTIONS is not set
# end of Wi-Fi
# Core dump
# CONFIG_ESP_COREDUMP_ENABLE_TO_FLASH is not set
# CONFIG_ESP_COREDUMP_ENABLE_TO_UART is not set
CONFIG_ESP_COREDUMP_ENABLE_TO_NONE=y
# end of Core dump
# FAT Filesystem support
CONFIG_FATFS_VOLUME_COUNT=2
CONFIG_FATFS_LFN_NONE=y
# CONFIG_FATFS_LFN_HEAP is not set
# CONFIG_FATFS_LFN_STACK is not set
# CONFIG_FATFS_SECTOR_512 is not set
CONFIG_FATFS_SECTOR_4096=y
# CONFIG_FATFS_CODEPAGE_DYNAMIC is not set
CONFIG_FATFS_CODEPAGE_437=y
# CONFIG_FATFS_CODEPAGE_720 is not set
# CONFIG_FATFS_CODEPAGE_737 is not set
# CONFIG_FATFS_CODEPAGE_771 is not set
# CONFIG_FATFS_CODEPAGE_775 is not set
# CONFIG_FATFS_CODEPAGE_850 is not set
# CONFIG_FATFS_CODEPAGE_852 is not set
# CONFIG_FATFS_CODEPAGE_855 is not set
# CONFIG_FATFS_CODEPAGE_857 is not set
# CONFIG_FATFS_CODEPAGE_860 is not set
# CONFIG_FATFS_CODEPAGE_861 is not set
# CONFIG_FATFS_CODEPAGE_862 is not set
# CONFIG_FATFS_CODEPAGE_863 is not set
# CONFIG_FATFS_CODEPAGE_864 is not set
# CONFIG_FATFS_CODEPAGE_865 is not set
# CONFIG_FATFS_CODEPAGE_866 is not set
# CONFIG_FATFS_CODEPAGE_869 is not set
# CONFIG_FATFS_CODEPAGE_932 is not set
# CONFIG_FATFS_CODEPAGE_936 is not set
# CONFIG_FATFS_CODEPAGE_949 is not set
# CONFIG_FATFS_CODEPAGE_950 is not set
CONFIG_FATFS_CODEPAGE=437
CONFIG_FATFS_FS_LOCK=0
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=y
# CONFIG_FATFS_USE_FASTSEEK is not set
CONFIG_FATFS_VFS_FSTAT_BLKSIZE=0
# end of FAT Filesystem support
# FreeRTOS
# Kernel
# CONFIG_FREERTOS_SMP is not set
# CONFIG_FREERTOS_UNICORE is not set
CONFIG_FREERTOS_HZ=100
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE is not set
# CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL is not set
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=1
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1536
# CONFIG_FREERTOS_USE_IDLE_HOOK is not set
# CONFIG_FREERTOS_USE_TICK_HOOK is not set
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
# CONFIG_FREERTOS_ENABLE_BACKWARD_COMPATIBILITY is not set
CONFIG_FREERTOS_TIMER_TASK_PRIORITY=1
CONFIG_FREERTOS_TIMER_TASK_STACK_DEPTH=2048
CONFIG_FREERTOS_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=10
CONFIG_FREERTOS_TASK_NOTIFICATION_ARRAY_ENTRIES=1
# CONFIG_FREERTOS_USE_TRACE_FACILITY is not set
# CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS is not set
# end of Kernel
# Port
CONFIG_FREERTOS_TASK_FUNCTION_WRAPPER=y
# CONFIG_FREERTOS_WATCHPOINT_END_OF_STACK is not set
CONFIG_FREERTOS_TLSP_DELETION_CALLBACKS=y
# CONFIG_FREERTOS_ENABLE_STATIC_TASK_CLEAN_UP is not set
CONFIG_FREERTOS_CHECK_MUTEX_GIVEN_BY_OWNER=y
CONFIG_FREERTOS_ISR_STACKSIZE=10000
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
# CONFIG_FREERTOS_FPU_IN_ISR is not set
CONFIG_FREERTOS_TICK_SUPPORT_CORETIMER=y
CONFIG_FREERTOS_CORETIMER_0=y
# CONFIG_FREERTOS_CORETIMER_1 is not set
CONFIG_FREERTOS_SYSTICK_USES_CCOUNT=y
# CONFIG_FREERTOS_PLACE_FUNCTIONS_INTO_FLASH is not set
# CONFIG_FREERTOS_PLACE_SNAPSHOT_FUNS_INTO_FLASH is not set
# CONFIG_FREERTOS_CHECK_PORT_CRITICAL_COMPLIANCE is not set
CONFIG_FREERTOS_ENABLE_TASK_SNAPSHOT=y
# end of Port
CONFIG_FREERTOS_NO_AFFINITY=0x7FFFFFFF
CONFIG_FREERTOS_SUPPORT_STATIC_ALLOCATION=y
CONFIG_FREERTOS_DEBUG_OCDAWARE=y
# end of FreeRTOS
# Hardware Abstraction Layer (HAL) and Low Level (LL)
CONFIG_HAL_ASSERTION_EQUALS_SYSTEM=y
# CONFIG_HAL_ASSERTION_DISABLE is not set
# CONFIG_HAL_ASSERTION_SILENT is not set
# CONFIG_HAL_ASSERTION_ENABLE is not set
CONFIG_HAL_DEFAULT_ASSERTION_LEVEL=2
CONFIG_HAL_SPI_MASTER_FUNC_IN_IRAM=y
CONFIG_HAL_SPI_SLAVE_FUNC_IN_IRAM=y
# end of Hardware Abstraction Layer (HAL) and Low Level (LL)
# Heap memory debugging
CONFIG_HEAP_POISONING_DISABLED=y
# CONFIG_HEAP_POISONING_LIGHT is not set
# CONFIG_HEAP_POISONING_COMPREHENSIVE is not set
CONFIG_HEAP_TRACING_OFF=y
# CONFIG_HEAP_TRACING_STANDALONE is not set
# CONFIG_HEAP_TRACING_TOHOST is not set
CONFIG_HEAP_USE_HOOKS=y
# CONFIG_HEAP_ABORT_WHEN_ALLOCATION_FAILS is not set
# CONFIG_HEAP_PLACE_FUNCTION_INTO_FLASH is not set
# end of Heap memory debugging
CONFIG_IEEE802154_CCA_THRESHOLD=-60
CONFIG_IEEE802154_PENDING_TABLE_SIZE=20
# Log output
# CONFIG_LOG_DEFAULT_LEVEL_NONE is not set
# CONFIG_LOG_DEFAULT_LEVEL_ERROR is not set
# CONFIG_LOG_DEFAULT_LEVEL_WARN is not set
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
# CONFIG_LOG_DEFAULT_LEVEL_DEBUG is not set
# CONFIG_LOG_DEFAULT_LEVEL_VERBOSE is not set
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_MAXIMUM_EQUALS_DEFAULT=y
# CONFIG_LOG_MAXIMUM_LEVEL_DEBUG is not set
# CONFIG_LOG_MAXIMUM_LEVEL_VERBOSE is not set
CONFIG_LOG_MAXIMUM_LEVEL=3
CONFIG_LOG_COLORS=y
CONFIG_LOG_TIMESTAMP_SOURCE_RTOS=y
# CONFIG_LOG_TIMESTAMP_SOURCE_SYSTEM is not set
# end of Log output
# LWIP
CONFIG_LWIP_LOCAL_HOSTNAME="espressif"
# CONFIG_LWIP_NETIF_API is not set
# CONFIG_LWIP_TCPIP_CORE_LOCKING is not set
# CONFIG_LWIP_CHECK_THREAD_SAFETY is not set
CONFIG_LWIP_DNS_SUPPORT_MDNS_QUERIES=y
# CONFIG_LWIP_L2_TO_L3_COPY is not set
# CONFIG_LWIP_IRAM_OPTIMIZATION is not set
CONFIG_LWIP_TIMERS_ONDEMAND=y
CONFIG_LWIP_MAX_SOCKETS=10
# CONFIG_LWIP_USE_ONLY_LWIP_SELECT is not set
# CONFIG_LWIP_SO_LINGER is not set
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
# CONFIG_LWIP_SO_RCVBUF is not set
# CONFIG_LWIP_NETBUF_RECVINFO is not set
CONFIG_LWIP_IP4_FRAG=y
CONFIG_LWIP_IP6_FRAG=y
# CONFIG_LWIP_IP4_REASSEMBLY is not set
# CONFIG_LWIP_IP6_REASSEMBLY is not set
CONFIG_LWIP_IP_REASS_MAX_PBUFS=10
# CONFIG_LWIP_IP_FORWARD is not set
# CONFIG_LWIP_STATS is not set
CONFIG_LWIP_ESP_GRATUITOUS_ARP=y
CONFIG_LWIP_GARP_TMR_INTERVAL=60
CONFIG_LWIP_ESP_MLDV6_REPORT=y
CONFIG_LWIP_MLDV6_TMR_INTERVAL=40
CONFIG_LWIP_TCPIP_RECVMBOX_SIZE=32
# CONFIG_LWIP_DHCP_DOES_ARP_CHECK is not set
# CONFIG_LWIP_DHCP_DISABLE_CLIENT_ID is not set
CONFIG_LWIP_DHCP_DISABLE_VENDOR_CLASS_ID=y
# CONFIG_LWIP_DHCP_RESTORE_LAST_IP is not set
CONFIG_LWIP_DHCP_OPTIONS_LEN=68
CONFIG_LWIP_NUM_NETIF_CLIENT_DATA=0
CONFIG_LWIP_DHCP_COARSE_TIMER_SECS=1
# DHCP server
CONFIG_LWIP_DHCPS=y
CONFIG_LWIP_DHCPS_LEASE_UNIT=60
CONFIG_LWIP_DHCPS_MAX_STATION_NUM=8
# end of DHCP server
CONFIG_LWIP_AUTOIP=y
CONFIG_LWIP_AUTOIP_TRIES=2
CONFIG_LWIP_AUTOIP_MAX_CONFLICTS=9
CONFIG_LWIP_AUTOIP_RATE_LIMIT_INTERVAL=20
CONFIG_LWIP_IPV4=y
CONFIG_LWIP_IPV6=y
# CONFIG_LWIP_IPV6_AUTOCONFIG is not set
CONFIG_LWIP_IPV6_NUM_ADDRESSES=3
# CONFIG_LWIP_IPV6_FORWARD is not set
# CONFIG_LWIP_NETIF_STATUS_CALLBACK is not set
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=8
# TCP
CONFIG_LWIP_MAX_ACTIVE_TCP=16
CONFIG_LWIP_MAX_LISTENING_TCP=16
CONFIG_LWIP_TCP_HIGH_SPEED_RETRANSMISSION=y
CONFIG_LWIP_TCP_MAXRTX=12
CONFIG_LWIP_TCP_SYNMAXRTX=12
CONFIG_LWIP_TCP_MSS=1440
CONFIG_LWIP_TCP_TMR_INTERVAL=50
CONFIG_LWIP_TCP_MSL=60000
CONFIG_LWIP_TCP_FIN_WAIT_TIMEOUT=20000
CONFIG_LWIP_TCP_SND_BUF_DEFAULT=5744
CONFIG_LWIP_TCP_WND_DEFAULT=5744
CONFIG_LWIP_TCP_RECVMBOX_SIZE=6
CONFIG_LWIP_TCP_QUEUE_OOSEQ=y
# CONFIG_LWIP_TCP_SACK_OUT is not set
CONFIG_LWIP_TCP_OVERSIZE_MSS=y
# CONFIG_LWIP_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_LWIP_TCP_OVERSIZE_DISABLE is not set
CONFIG_LWIP_TCP_RTO_TIME=1500
# end of TCP
# UDP
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_LWIP_UDP_RECVMBOX_SIZE=6
# end of UDP
# Checksums
# CONFIG_LWIP_CHECKSUM_CHECK_IP is not set
# CONFIG_LWIP_CHECKSUM_CHECK_UDP is not set
CONFIG_LWIP_CHECKSUM_CHECK_ICMP=y
# end of Checksums
CONFIG_LWIP_TCPIP_TASK_STACK_SIZE=29999
CONFIG_LWIP_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU0 is not set
# CONFIG_LWIP_TCPIP_TASK_AFFINITY_CPU1 is not set
CONFIG_LWIP_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_LWIP_PPP_SUPPORT is not set
CONFIG_LWIP_IPV6_MEMP_NUM_ND6_QUEUE=3
CONFIG_LWIP_IPV6_ND6_NUM_NEIGHBORS=5
# CONFIG_LWIP_SLIP_SUPPORT is not set
# ICMP
CONFIG_LWIP_ICMP=y
# CONFIG_LWIP_MULTICAST_PING is not set
# CONFIG_LWIP_BROADCAST_PING is not set
# end of ICMP
# LWIP RAW API
CONFIG_LWIP_MAX_RAW_PCBS=16
# end of LWIP RAW API
# SNTP
CONFIG_LWIP_SNTP_MAX_SERVERS=1
# CONFIG_LWIP_DHCP_GET_NTP_SRV is not set
CONFIG_LWIP_SNTP_UPDATE_DELAY=3600000
# end of SNTP
CONFIG_LWIP_BRIDGEIF_MAX_PORTS=7
CONFIG_LWIP_ESP_LWIP_ASSERT=y
# Hooks
# CONFIG_LWIP_HOOK_TCP_ISN_NONE is not set
CONFIG_LWIP_HOOK_TCP_ISN_DEFAULT=y
# CONFIG_LWIP_HOOK_TCP_ISN_CUSTOM is not set
CONFIG_LWIP_HOOK_IP6_ROUTE_NONE=y
# CONFIG_LWIP_HOOK_IP6_ROUTE_DEFAULT is not set
# CONFIG_LWIP_HOOK_IP6_ROUTE_CUSTOM is not set
CONFIG_LWIP_HOOK_ND6_GET_GW_NONE=y
# CONFIG_LWIP_HOOK_ND6_GET_GW_DEFAULT is not set
# CONFIG_LWIP_HOOK_ND6_GET_GW_CUSTOM is not set
CONFIG_LWIP_HOOK_IP6_SELECT_SRC_ADDR_NONE=y
# CONFIG_LWIP_HOOK_IP6_SELECT_SRC_ADDR_DEFAULT is not set
# CONFIG_LWIP_HOOK_IP6_SELECT_SRC_ADDR_CUSTOM is not set
CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_NONE=y
# CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_DEFAULT is not set
# CONFIG_LWIP_HOOK_NETCONN_EXT_RESOLVE_CUSTOM is not set
CONFIG_LWIP_HOOK_IP6_INPUT_NONE=y
# CONFIG_LWIP_HOOK_IP6_INPUT_DEFAULT is not set
# CONFIG_LWIP_HOOK_IP6_INPUT_CUSTOM is not set
# end of Hooks
# CONFIG_LWIP_DEBUG is not set
# end of LWIP
# mbedTLS
CONFIG_MBEDTLS_INTERNAL_MEM_ALLOC=y
# CONFIG_MBEDTLS_DEFAULT_MEM_ALLOC is not set
# CONFIG_MBEDTLS_CUSTOM_MEM_ALLOC is not set
CONFIG_MBEDTLS_ASYMMETRIC_CONTENT_LEN=y
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
# CONFIG_MBEDTLS_DYNAMIC_BUFFER is not set
# CONFIG_MBEDTLS_DEBUG is not set
# mbedTLS v3.x related
# CONFIG_MBEDTLS_SSL_PROTO_TLS1_3 is not set
# CONFIG_MBEDTLS_SSL_VARIABLE_BUFFER_LENGTH is not set
# CONFIG_MBEDTLS_X509_TRUSTED_CERT_CALLBACK is not set
# CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION is not set
CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE=y
CONFIG_MBEDTLS_PKCS7_C=y
# end of mbedTLS v3.x related
# Certificate Bundle
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE=y
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_FULL=y
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_CMN is not set
# CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_DEFAULT_NONE is not set
# CONFIG_MBEDTLS_CUSTOM_CERTIFICATE_BUNDLE is not set
CONFIG_MBEDTLS_CERTIFICATE_BUNDLE_MAX_CERTS=200
# end of Certificate Bundle
# CONFIG_MBEDTLS_ECP_RESTARTABLE is not set
# CONFIG_MBEDTLS_CMAC_C is not set
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_HARDWARE_MPI=y
CONFIG_MBEDTLS_HARDWARE_SHA=y
CONFIG_MBEDTLS_ROM_MD5=y
# CONFIG_MBEDTLS_ATCA_HW_ECDSA_SIGN is not set
# CONFIG_MBEDTLS_ATCA_HW_ECDSA_VERIFY is not set
CONFIG_MBEDTLS_HAVE_TIME=y
# CONFIG_MBEDTLS_PLATFORM_TIME_ALT is not set
# CONFIG_MBEDTLS_HAVE_TIME_DATE is not set
CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=y
CONFIG_MBEDTLS_SHA512_C=y
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
# CONFIG_MBEDTLS_TLS_SERVER_ONLY is not set
# CONFIG_MBEDTLS_TLS_CLIENT_ONLY is not set
# CONFIG_MBEDTLS_TLS_DISABLED is not set
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
# TLS Key Exchange Methods
# CONFIG_MBEDTLS_PSK_MODES is not set
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y
# end of TLS Key Exchange Methods
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
# CONFIG_MBEDTLS_SSL_PROTO_GMTSSL1_1 is not set
# CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_CLIENT_SSL_SESSION_TICKETS=y
CONFIG_MBEDTLS_SERVER_SSL_SESSION_TICKETS=y
# Symmetric Ciphers
CONFIG_MBEDTLS_AES_C=y
# CONFIG_MBEDTLS_CAMELLIA_C is not set
# CONFIG_MBEDTLS_DES_C is not set
# CONFIG_MBEDTLS_BLOWFISH_C is not set
# CONFIG_MBEDTLS_XTEA_C is not set
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
# CONFIG_MBEDTLS_NIST_KW_C is not set
# end of Symmetric Ciphers
# CONFIG_MBEDTLS_RIPEMD160_C is not set
# Certificates
CONFIG_MBEDTLS_PEM_PARSE_C=y
CONFIG_MBEDTLS_PEM_WRITE_C=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
# end of Certificates
CONFIG_MBEDTLS_ECP_C=y
# CONFIG_MBEDTLS_DHM_C is not set
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
# CONFIG_MBEDTLS_ECJPAKE_C is not set
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
# CONFIG_MBEDTLS_POLY1305_C is not set
# CONFIG_MBEDTLS_CHACHA20_C is not set
# CONFIG_MBEDTLS_HKDF_C is not set
# CONFIG_MBEDTLS_THREADING_C is not set
# CONFIG_MBEDTLS_LARGE_KEY_SOFTWARE_MPI is not set
# CONFIG_MBEDTLS_SECURITY_RISKS is not set
# end of mbedTLS
# ESP-MQTT Configurations
CONFIG_MQTT_PROTOCOL_311=y
# CONFIG_MQTT_PROTOCOL_5 is not set
CONFIG_MQTT_TRANSPORT_SSL=y
CONFIG_MQTT_TRANSPORT_WEBSOCKET=y
CONFIG_MQTT_TRANSPORT_WEBSOCKET_SECURE=y
# CONFIG_MQTT_MSG_ID_INCREMENTAL is not set
# CONFIG_MQTT_SKIP_PUBLISH_IF_DISCONNECTED is not set
# CONFIG_MQTT_REPORT_DELETED_MESSAGES is not set
# CONFIG_MQTT_USE_CUSTOM_CONFIG is not set
# CONFIG_MQTT_TASK_CORE_SELECTION_ENABLED is not set
# CONFIG_MQTT_CUSTOM_OUTBOX is not set
# end of ESP-MQTT Configurations
# Newlib
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF=y
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_LF is not set
# CONFIG_NEWLIB_STDOUT_LINE_ENDING_CR is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_CRLF is not set
# CONFIG_NEWLIB_STDIN_LINE_ENDING_LF is not set
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
# CONFIG_NEWLIB_NANO_FORMAT is not set
CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC_HRT=y
# CONFIG_NEWLIB_TIME_SYSCALL_USE_RTC is not set
# CONFIG_NEWLIB_TIME_SYSCALL_USE_HRT is not set
# CONFIG_NEWLIB_TIME_SYSCALL_USE_NONE is not set
# end of Newlib
# NVS
# CONFIG_NVS_ASSERT_ERROR_CHECK is not set
# end of NVS
# OpenThread
# CONFIG_OPENTHREAD_ENABLED is not set
# Thread Operational Dataset
CONFIG_OPENTHREAD_NETWORK_NAME="OpenThread-ESP"
CONFIG_OPENTHREAD_NETWORK_CHANNEL=15
CONFIG_OPENTHREAD_NETWORK_PANID=0x1234
CONFIG_OPENTHREAD_NETWORK_EXTPANID="dead00beef00cafe"
CONFIG_OPENTHREAD_NETWORK_MASTERKEY="00112233445566778899aabbccddeeff"
CONFIG_OPENTHREAD_NETWORK_PSKC="104810e2315100afd6bc9215a6bfac53"
# end of Thread Operational Dataset
# end of OpenThread
# Protocomm
CONFIG_ESP_PROTOCOMM_SUPPORT_SECURITY_VERSION_0=y
CONFIG_ESP_PROTOCOMM_SUPPORT_SECURITY_VERSION_1=y
CONFIG_ESP_PROTOCOMM_SUPPORT_SECURITY_VERSION_2=y
# end of Protocomm
# PThreads
CONFIG_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_PTHREAD_TASK_STACK_SIZE_DEFAULT=10000
CONFIG_PTHREAD_STACK_MIN=768
CONFIG_PTHREAD_DEFAULT_CORE_NO_AFFINITY=y
# CONFIG_PTHREAD_DEFAULT_CORE_0 is not set
# CONFIG_PTHREAD_DEFAULT_CORE_1 is not set
CONFIG_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_PTHREAD_TASK_NAME_DEFAULT="pthread"
# end of PThreads
# MMU Config
CONFIG_MMU_PAGE_SIZE_64KB=y
CONFIG_MMU_PAGE_MODE="64KB"
CONFIG_MMU_PAGE_SIZE=0x10000
# end of MMU Config
# SPI Flash driver
# CONFIG_SPI_FLASH_VERIFY_WRITE is not set
# CONFIG_SPI_FLASH_ENABLE_COUNTERS is not set
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_ABORTS is not set
# CONFIG_SPI_FLASH_DANGEROUS_WRITE_FAILS is not set
CONFIG_SPI_FLASH_DANGEROUS_WRITE_ALLOWED=y
# CONFIG_SPI_FLASH_SHARE_SPI1_BUS is not set
# CONFIG_SPI_FLASH_BYPASS_BLOCK_ERASE is not set
CONFIG_SPI_FLASH_YIELD_DURING_ERASE=y
CONFIG_SPI_FLASH_ERASE_YIELD_DURATION_MS=20
CONFIG_SPI_FLASH_ERASE_YIELD_TICKS=1
CONFIG_SPI_FLASH_WRITE_CHUNK_SIZE=8192
# CONFIG_SPI_FLASH_SIZE_OVERRIDE is not set
# CONFIG_SPI_FLASH_CHECK_ERASE_TIMEOUT_DISABLED is not set
# CONFIG_SPI_FLASH_OVERRIDE_CHIP_DRIVER_LIST is not set
# SPI Flash behavior when brownout
CONFIG_SPI_FLASH_BROWNOUT_RESET_XMC=y
CONFIG_SPI_FLASH_BROWNOUT_RESET=y
# end of SPI Flash behavior when brownout
# Auto-detect flash chips
CONFIG_SPI_FLASH_VENDOR_XMC_SUPPORTED=y
CONFIG_SPI_FLASH_VENDOR_GD_SUPPORTED=y
CONFIG_SPI_FLASH_VENDOR_ISSI_SUPPORTED=y
CONFIG_SPI_FLASH_VENDOR_MXIC_SUPPORTED=y
CONFIG_SPI_FLASH_VENDOR_WINBOND_SUPPORTED=y
CONFIG_SPI_FLASH_SUPPORT_ISSI_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_MXIC_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_GD_CHIP=y
CONFIG_SPI_FLASH_SUPPORT_WINBOND_CHIP=y
# CONFIG_SPI_FLASH_SUPPORT_BOYA_CHIP is not set
# CONFIG_SPI_FLASH_SUPPORT_TH_CHIP is not set
# end of Auto-detect flash chips
CONFIG_SPI_FLASH_ENABLE_ENCRYPTED_READ_WRITE=y
# end of SPI Flash driver
# SPIFFS Configuration
CONFIG_SPIFFS_MAX_PARTITIONS=3
# SPIFFS Cache Configuration
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
# CONFIG_SPIFFS_CACHE_STATS is not set
# end of SPIFFS Cache Configuration
CONFIG_SPIFFS_PAGE_CHECK=y
CONFIG_SPIFFS_GC_MAX_RUNS=10
# CONFIG_SPIFFS_GC_STATS is not set
CONFIG_SPIFFS_PAGE_SIZE=256
CONFIG_SPIFFS_OBJ_NAME_LEN=32
# CONFIG_SPIFFS_FOLLOW_SYMLINKS is not set
CONFIG_SPIFFS_USE_MAGIC=y
CONFIG_SPIFFS_USE_MAGIC_LENGTH=y
CONFIG_SPIFFS_META_LENGTH=4
CONFIG_SPIFFS_USE_MTIME=y
# Debug Configuration
# CONFIG_SPIFFS_DBG is not set
# CONFIG_SPIFFS_API_DBG is not set
# CONFIG_SPIFFS_GC_DBG is not set
# CONFIG_SPIFFS_CACHE_DBG is not set
# CONFIG_SPIFFS_CHECK_DBG is not set
# CONFIG_SPIFFS_TEST_VISUALISATION is not set
# end of Debug Configuration
# end of SPIFFS Configuration
# TCP Transport
# Websocket
CONFIG_WS_TRANSPORT=y
CONFIG_WS_BUFFER_SIZE=10000
# CONFIG_WS_DYNAMIC_BUFFER is not set
# end of Websocket
# end of TCP Transport
# Ultra Low Power (ULP) Co-processor
# CONFIG_ULP_COPROC_ENABLED is not set
# end of Ultra Low Power (ULP) Co-processor
# Unity unit testing library
CONFIG_UNITY_ENABLE_FLOAT=y
CONFIG_UNITY_ENABLE_DOUBLE=y
# CONFIG_UNITY_ENABLE_64BIT is not set
# CONFIG_UNITY_ENABLE_COLOR is not set
CONFIG_UNITY_ENABLE_IDF_TEST_RUNNER=y
# CONFIG_UNITY_ENABLE_FIXTURE is not set
# CONFIG_UNITY_ENABLE_BACKTRACE_ON_FAIL is not set
# end of Unity unit testing library
# Root Hub configuration
# end of Root Hub configuration
# Virtual file system
CONFIG_VFS_SUPPORT_IO=y
CONFIG_VFS_SUPPORT_DIR=y
CONFIG_VFS_SUPPORT_SELECT=y
CONFIG_VFS_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_VFS_SUPPORT_TERMIOS=y
CONFIG_VFS_MAX_COUNT=8
# Host File System I/O (Semihosting)
CONFIG_VFS_SEMIHOSTFS_MAX_MOUNT_POINTS=1
# end of Host File System I/O (Semihosting)
# end of Virtual file system
# Wear Levelling
# CONFIG_WL_SECTOR_SIZE_512 is not set
CONFIG_WL_SECTOR_SIZE_4096=y
CONFIG_WL_SECTOR_SIZE=4096
# end of Wear Levelling
# Wi-Fi Provisioning Manager
CONFIG_WIFI_PROV_SCAN_MAX_ENTRIES=16
CONFIG_WIFI_PROV_AUTOSTOP_TIMEOUT=30
# CONFIG_WIFI_PROV_BLE_FORCE_ENCRYPTION is not set
CONFIG_WIFI_PROV_STA_ALL_CHANNEL_SCAN=y
# CONFIG_WIFI_PROV_STA_FAST_SCAN is not set
# end of Wi-Fi Provisioning Manager
# end of Component config
# CONFIG_IDF_EXPERIMENTAL_FEATURES is not set
# Deprecated options for backward compatibility
# CONFIG_APP_BUILD_TYPE_ELF_RAM is not set
# CONFIG_NO_BLOBS is not set
# CONFIG_ESP32_NO_BLOBS is not set
# CONFIG_ESP32_COMPATIBLE_PRE_V2_1_BOOTLOADERS is not set
# CONFIG_ESP32_COMPATIBLE_PRE_V3_1_BOOTLOADERS is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_NONE is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_ERROR is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_WARN is not set
CONFIG_LOG_BOOTLOADER_LEVEL_INFO=y
# CONFIG_LOG_BOOTLOADER_LEVEL_DEBUG is not set
# CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE is not set
CONFIG_LOG_BOOTLOADER_LEVEL=3
# CONFIG_APP_ROLLBACK_ENABLE is not set
# CONFIG_FLASH_ENCRYPTION_ENABLED is not set
# CONFIG_FLASHMODE_QIO is not set
# CONFIG_FLASHMODE_QOUT is not set
CONFIG_FLASHMODE_DIO=y
# CONFIG_FLASHMODE_DOUT is not set
CONFIG_MONITOR_BAUD=115200
CONFIG_OPTIMIZATION_LEVEL_DEBUG=y
CONFIG_COMPILER_OPTIMIZATION_LEVEL_DEBUG=y
# CONFIG_OPTIMIZATION_LEVEL_RELEASE is not set
# CONFIG_COMPILER_OPTIMIZATION_LEVEL_RELEASE is not set
CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED=y
# CONFIG_OPTIMIZATION_ASSERTIONS_SILENT is not set
# CONFIG_OPTIMIZATION_ASSERTIONS_DISABLED is not set
CONFIG_OPTIMIZATION_ASSERTION_LEVEL=2
# CONFIG_CXX_EXCEPTIONS is not set
CONFIG_STACK_CHECK_NONE=y
# CONFIG_STACK_CHECK_NORM is not set
# CONFIG_STACK_CHECK_STRONG is not set
# CONFIG_STACK_CHECK_ALL is not set
# CONFIG_WARN_WRITE_STRINGS is not set
# CONFIG_ESP32_APPTRACE_DEST_TRAX is not set
CONFIG_ESP32_APPTRACE_DEST_NONE=y
CONFIG_ESP32_APPTRACE_LOCK_ENABLE=y
CONFIG_ADC2_DISABLE_DAC=y
# CONFIG_MCPWM_ISR_IN_IRAM is not set
# CONFIG_EVENT_LOOP_PROFILING is not set
CONFIG_POST_EVENTS_FROM_ISR=y
CONFIG_POST_EVENTS_FROM_IRAM_ISR=y
# CONFIG_OTA_ALLOW_HTTP is not set
# CONFIG_TWO_UNIVERSAL_MAC_ADDRESS is not set
CONFIG_FOUR_UNIVERSAL_MAC_ADDRESS=y
CONFIG_NUMBER_OF_UNIVERSAL_MAC_ADDRESS=4
# CONFIG_ESP_SYSTEM_PD_FLASH is not set
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=2000
CONFIG_ESP32_RTC_CLK_SRC_INT_RC=y
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
# CONFIG_ESP32_RTC_CLK_SRC_EXT_CRYS is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL is not set
# CONFIG_ESP32_RTC_CLK_SRC_EXT_OSC is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_OSC is not set
# CONFIG_ESP32_RTC_CLK_SRC_INT_8MD256 is not set
# CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_8MD256 is not set
CONFIG_ESP32_RTC_CLK_CAL_CYCLES=1024
# CONFIG_ESP32_XTAL_FREQ_26 is not set
CONFIG_ESP32_XTAL_FREQ_40=y
# CONFIG_ESP32_XTAL_FREQ_AUTO is not set
CONFIG_ESP32_XTAL_FREQ=40
CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE=y
# CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
# CONFIG_REDUCE_PHY_TX_POWER is not set
# CONFIG_ESP32_REDUCE_PHY_TX_POWER is not set
# CONFIG_SPIRAM_SUPPORT is not set
# CONFIG_ESP32_SPIRAM_SUPPORT is not set
# CONFIG_ESP32_DEFAULT_CPU_FREQ_80 is not set
# CONFIG_ESP32_DEFAULT_CPU_FREQ_160 is not set
CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=240
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
# CONFIG_ESP32_PANIC_PRINT_HALT is not set
CONFIG_ESP32_PANIC_PRINT_REBOOT=y
# CONFIG_ESP32_PANIC_SILENT_REBOOT is not set
# CONFIG_ESP32_PANIC_GDBSTUB is not set
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=30000
CONFIG_MAIN_TASK_STACK_SIZE=35000
CONFIG_CONSOLE_UART_DEFAULT=y
# CONFIG_CONSOLE_UART_CUSTOM is not set
# CONFIG_CONSOLE_UART_NONE is not set
# CONFIG_ESP_CONSOLE_UART_NONE is not set
CONFIG_CONSOLE_UART=y
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
# CONFIG_INT_WDT is not set
# CONFIG_ESP32_DEBUG_STUBS_ENABLE is not set
CONFIG_ESP32_DEBUG_OCDAWARE=y
CONFIG_BROWNOUT_DET=y
CONFIG_ESP32_BROWNOUT_DET=y
CONFIG_BROWNOUT_DET_LVL_SEL_0=y
CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_0=y
# CONFIG_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_1 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_2 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_3 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_4 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_5 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_6 is not set
# CONFIG_BROWNOUT_DET_LVL_SEL_7 is not set
# CONFIG_ESP32_BROWNOUT_DET_LVL_SEL_7 is not set
CONFIG_BROWNOUT_DET_LVL=0
CONFIG_ESP32_BROWNOUT_DET_LVL=0
# CONFIG_DISABLE_BASIC_ROM_CONSOLE is not set
CONFIG_IPC_TASK_STACK_SIZE=1024
CONFIG_TIMER_TASK_STACK_SIZE=3584
CONFIG_ESP32_WIFI_ENABLED=y
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=10
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=32
# CONFIG_ESP32_WIFI_STATIC_TX_BUFFER is not set
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=1
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM=32
# CONFIG_ESP32_WIFI_CSI_ENABLED is not set
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=6
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=6
CONFIG_ESP32_WIFI_NVS_ENABLED=y
CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_0=y
# CONFIG_ESP32_WIFI_TASK_PINNED_TO_CORE_1 is not set
CONFIG_ESP32_WIFI_SOFTAP_BEACON_MAX_LEN=752
CONFIG_ESP32_WIFI_MGMT_SBUF_NUM=32
CONFIG_ESP32_WIFI_IRAM_OPT=y
CONFIG_ESP32_WIFI_RX_IRAM_OPT=y
CONFIG_ESP32_WIFI_ENABLE_WPA3_SAE=y
CONFIG_ESP32_WIFI_ENABLE_WPA3_OWE_STA=y
CONFIG_WPA_MBEDTLS_CRYPTO=y
CONFIG_WPA_MBEDTLS_TLS_CLIENT=y
# CONFIG_WPA_WAPI_PSK is not set
# CONFIG_WPA_SUITE_B_192 is not set
# CONFIG_WPA_11KV_SUPPORT is not set
# CONFIG_WPA_MBO_SUPPORT is not set
# CONFIG_WPA_DPP_SUPPORT is not set
# CONFIG_WPA_11R_SUPPORT is not set
# CONFIG_WPA_WPS_SOFTAP_REGISTRAR is not set
# CONFIG_WPA_WPS_STRICT is not set
# CONFIG_WPA_DEBUG_PRINT is not set
# CONFIG_WPA_TESTING_OPTIONS is not set
# CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH is not set
# CONFIG_ESP32_ENABLE_COREDUMP_TO_UART is not set
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_STACK_DEPTH=2048
CONFIG_TIMER_QUEUE_LENGTH=10
# CONFIG_ENABLE_STATIC_TASK_CLEAN_UP_HOOK is not set
# CONFIG_HAL_ASSERTION_SILIENT is not set
# CONFIG_L2_TO_L3_COPY is not set
CONFIG_ESP_GRATUITOUS_ARP=y
CONFIG_GARP_TMR_INTERVAL=60
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=12
CONFIG_TCP_MSS=1440
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
CONFIG_TCP_OVERSIZE_MSS=y
# CONFIG_TCP_OVERSIZE_QUARTER_MSS is not set
# CONFIG_TCP_OVERSIZE_DISABLE is not set
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=29999
CONFIG_TCPIP_TASK_AFFINITY_NO_AFFINITY=y
# CONFIG_TCPIP_TASK_AFFINITY_CPU0 is not set
# CONFIG_TCPIP_TASK_AFFINITY_CPU1 is not set
CONFIG_TCPIP_TASK_AFFINITY=0x7FFFFFFF
# CONFIG_PPP_SUPPORT is not set
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_HRT=y
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
# CONFIG_ESP32_TIME_SYSCALL_USE_RTC is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_HRT is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_FRC1 is not set
# CONFIG_ESP32_TIME_SYSCALL_USE_NONE is not set
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=10000
CONFIG_ESP32_PTHREAD_STACK_MIN=768
CONFIG_ESP32_DEFAULT_PTHREAD_CORE_NO_AFFINITY=y
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_0 is not set
# CONFIG_ESP32_DEFAULT_PTHREAD_CORE_1 is not set
CONFIG_ESP32_PTHREAD_TASK_CORE_DEFAULT=-1
CONFIG_ESP32_PTHREAD_TASK_NAME_DEFAULT="pthread"
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS is not set
# CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_FAILS is not set
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED=y
# CONFIG_ESP32_ULP_COPROC_ENABLED is not set
CONFIG_SUPPRESS_SELECT_DEBUG_OUTPUT=y
CONFIG_SUPPORT_TERMIOS=y
CONFIG_SEMIHOSTFS_MAX_MOUNT_POINTS=1
# End of deprecated options
Re: ESP32 can not initialize IP101 Ethernet PHY
Posted: Mon Jul 08, 2024 3:22 pm
by aliarifat794
Have you performed basic PCB tests on your custom board?
Posted: Mon Jul 08, 2024 6:54 pm
by Vilius
Yes, I have. Like I mentioned, it seems there are no problems with the ESP32 itself, I am getting the right voltages, no shorts, no suspicious current consumption, other than the PHY, PCB works as intended.
Posted: Wed Jul 10, 2024 6:43 am
by ondrej
Have you measured the RMII REF CLK on oscilloscope?
Posted: Sun Aug 04, 2024 10:39 am
by Vilius
Sorry, for such a late response, I spent all this time debugging. Here is m update:
I am trying to replicate ESP Ethernet DEV kit (at least the ethernet part of if) on my custom PCB that I will be using for Ethernet application. I consistently followed the manufacturer's schematic (in the attachments.) All the wiring is tested like a 100 times. I absolutely guarantee that everything you see in my schematics is indeed implemented on the PCB (Schematics are in the attachments). The ESP part works flawlessly, it flashes and runs perfectly. However my problems occur in the ESP-PHY communication level. The ESP can not fully initialize the PHY, I get false logs (for example, I sometimes get ,,Ethernet link up" log when there is no ethernet cable attached etc.) The logs related with PHY are completely unpredictable. One exact log example is in the end.
I am testing my board with manufacturers provided ESP code (ESP-IDF->examples->ethernet->basic). That code has to send a dynamic IP request to the DHCP server and obtain it, but as you can tell, my ESP is not obtaining the dynamic IP. I am absolutely sure that all the connections are right, and my DHCP server is up and running. If I test the exact same code with the ESP Ethernet Dev kit, it works perfectly.
Hope I explained the problem well enough so far. I tried both running the 50 MHz clock from the PHY CLKO as the reference, but I settled on sourcing the 50 MHz clock from the ESP GPIO0 pin and using an inverter right before the PHY's CLKI pin. In any case, I made sure I get nice and continuous real and the inverted 50 MHz clocks (picture in the attachments.) I also probed the MDIO and MDC lines. I can capture occasional MDIO packets, but the clock line MDC always stays low. That is an obvious problem but I guess that is a consequence of some other mistake, rather than the cause. In any case, I have settled on this problem for a couple of weeks now and I am absolutely out of clue what could be wrong, what else can I try. Any observations about the MDC or any other possible solutions are highly appreciated.
P.S. If I missed some crucial details about this problem, just let me know.
Example logs:
I (0) cpu_start: App cpu up.
I (702) cpu_start: Pro cpu start user code
I (702) cpu_start: cpu freq: 240000000 Hz
I (702) cpu_start: Application information:
I (707) cpu_start: Project name: ESPTCP
I (711) cpu_start: App version: 1
I (716) cpu_start: Compile time: Jul 30 2024 11:35:59
I (722) cpu_start: ELF file SHA256: b36ff35f686c4824...
I (728) cpu_start: ESP-IDF: v5.1.1-dirty
I (733) cpu_start: Min chip rev: v0.0
I (738) cpu_start: Max chip rev: v3.99
I (743) cpu_start: Chip rev: v3.0
I (748) heap_init: Initializing. RAM available for dynamic allocation:
I (755) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (761) heap_init: At 3FFB7640 len 000289C0 (162 KiB): DRAM
I (767) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (773) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (780) heap_init: At 4008BDB0 len 00014250 (80 KiB): IRAM
I (788) spi_flash: detected chip: winbond
I (791) spi_flash: flash io: dio
I (795) app_start: Starting scheduler on CPU0
I (800) app_start: Starting scheduler on CPU1
I (800) main_task: Started on CPU0
I (810) main_task: Calling app_main()
D (840) lwip: netif: netmask of interface set to 255.0.0.0
D (840) lwip: netif: GW address of interface set to 127.0.0.1
D (840) lwip: netif_set_ipaddr: netif address being changed
D (840) lwip: netif: added interface lo IP
D (850) lwip: addr
D (850) lwip: 127.0.0.1
D (850) lwip: netmask
D (860) lwip: 255.0.0.0
D (860) lwip: gw
D (860) lwip: 127.0.0.1
D (860) lwip:
I (870) esp_eth.netif.netif_glue: 78:21:84:ef:45:33
I (870) esp_eth.netif.netif_glue: ethernet attached to netif
I (880) main_task: Returned from app_main()
D (880) lwip: netif: added interface en IP
D (890) lwip: addr
D (890) lwip: 0.0.0.0
D (890) lwip: netmask
D (890) lwip: gw
D (900) lwip: 0.0.0.0
D (900) lwip:
I (900) eth_example: Ethernet Started
D (1860) lwip: dhcp_coarse_tmr()
D (1860) lwip: ip6_output_if: lo0
D (1860) lwip: IPv6 header:
D (1860) lwip: +-------------------------------+
D (1860) lwip: | 6 | 0 | 0 | (ver, class, flow)
D (1870) lwip: +-------------------------------+
D (1870) lwip: | 16 | 58 | 255 | (plen, nexth, hopl)
D (1880) lwip: +-------------------------------+
D (1880) lwip: | 0 | 0 | 0 | 0 | (src)
D (1890) lwip: | 0 | 0 | 0 | 1 |
D (1890) lwip: +-------------------------------+
D (1900) lwip: | ff02 | 0 | 0 | 0 | (dest)
D (1900) lwip: | 0 | 0 | 0 | 2 |
D (1910) lwip: +-------------------------------+
D (1910) lwip: netif->output_ip6()
D (1920) lwip: ip6_input: packet not for us.
D (2860) lwip: dhcp_coarse_tmr()
D (3860) lwip: dhcp_coarse_tmr()
D (4860) lwip: dhcp_coarse_tmr()
D (5860) lwip: dhcp_coarse_tmr()
D (5860) lwip: ip6_output_if: lo0
D (5860) lwip: IPv6 header:
D (5860) lwip: +-------------------------------+
D (5860) lwip: | 6 | 0 | 0 | (ver, class, flow)
D (5870) lwip: +-------------------------------+
D (5870) lwip: | 16 | 58 | 255 | (plen, nexth, hopl)
D (5880) lwip: +-------------------------------+
D (5880) lwip: | 0 | 0 | 0 | 0 | (src)
D (5890) lwip: | 0 | 0 | 0 | 1 |
D (5890) lwip: +-------------------------------+
D (5900) lwip: | ff02 | 0 | 0 | 0 | (dest)
D (5900) lwip: | 0 | 0 | 0 | 2 |
D (5910) lwip: +-------------------------------+
D (5910) lwip: netif->output_ip6()
D (5920) lwip: ip6_input: packet not for us.
D (6860) lwip: dhcp_coarse_tmr()
D (7860) lwip: dhcp_coarse_tmr()
D (8860) lwip: dhcp_coarse_tmr()
D (9860) lwip: dhcp_coarse_tmr()
D (9860) lwip: ip6_output_if: lo0
D (9860) lwip: IPv6 header:
D (9860) lwip: +-------------------------------+
D (9860) lwip: | 6 | 0 | 0 | (ver, class, flow)
D (9870) lwip: +-------------------------------+
D (9870) lwip: | 16 | 58 | 255 | (plen, nexth, hopl)
D (9880) lwip: +-------------------------------+
D (9880) lwip: | 0 | 0 | 0 | 0 | (src)
D (9890) lwip: | 0 | 0 | 0 | 1 |
D (9890) lwip: +-------------------------------+
D (9900) lwip: | ff02 | 0 | 0 | 0 | (dest)
D (9900) lwip: | 0 | 0 | 0 | 2 |
D (9910) lwip: +-------------------------------+
D (9910) lwip: netif->output_ip6()
D (9920) lwip: ip6_input: packet not for us.
D (10860) lwip: dhcp_coarse_tmr()
D (11860) lwip: dhcp_coarse_tmr()
D (12860) lwip: dhcp_coarse_tmr()
D (13860) lwip: dhcp_coarse_tmr()
D (14860) lwip: dhcp_coarse_tmr()
D (15860) lwip: dhcp_coarse_tmr()
D (16860) lwip: dhcp_coarse_tmr()
D (17860) lwip: dhcp_coarse_tmr()
D (18860) lwip: dhcp_coarse_tmr()
D (19860) lwip: dhcp_coarse_tmr()
D (20860) lwip: dhcp_coarse_tmr()
D (21860) lwip: dhcp_coarse_tmr()
D (22860) lwip: dhcp_coarse_tmr()
D (23860) lwip: dhcp_coarse_tmr()
D (24860) lwip: dhcp_coarse_tmr()
D (25860) lwip: dhcp_coarse_tmr()
D (26860) lwip: dhcp_coarse_tmr()
D (27860) lwip: dhcp_coarse_tmr()
D (28860) lwip: dhcp_coarse_tmr()
Posted: Thu Aug 08, 2024 8:41 am
by ondrej
At which pin side did you measure the MDC? At ESP32 or PHY? It happened to me once that one of the terminal resistor was not properly assembled and it fell off the board! I spent week of debugging since I really didn't expect such an issue.
Posted: Fri Aug 09, 2024 12:48 pm
by ondrej
Do I understand it correctly that your board is able to boot now? You just don't get IP address? If so, try to download this application https://github.com/espressif/esp-eth-dr ... phy_tester and follow the instructions. Just note it currently works (was tested) only on Linux.
Posted: Wed Nov 19, 2025 11:01 am
by rzerres
Just got hold of your post. It seems the discussion has been solved.
I'm interested in this project, since I'm going to integrate an Ethernet PHY to the [ESP32_8ch_motor_shield](https://github.com/nliaudat/esp32_8ch_motor_shield] PCB.
Your response would be quite helpful. Thanks
