Code: Untitled.cpp Select all
uint64_t SD_CARD_INFO[5] = {0,0,0,0,0}; //type and present, size, totalbyte, used, freebyte
Preferences nvs_;
void gatto_fw_set_writable(){
nvs_.putBool("update",true);
void gatto_fw_set_protect(){
nvs_.putBool("update",false);
bool gatto_fw_get_staus(){
bool str = nvs_.getBool("update");
return str;
void firmware_progress(size_t currSize, size_t totalSize) {
Serial.printf("FIRMWARE: Update %d of %d bytes...\n", currSize, totalSize);
void firmware_update(){
if(SD_CARD_INFO[0]>0){
String pluto = gatto_fw_get_staus(); // enable update (?)
if(pluto=="true"){
if (SD.exists("/firmware.bin")) {
SD.remove("/firmware.bak");
if (SD.rename("/firmware.bin", "/firmware.bak")){
// Serial.println(F("Firmware rename succesfully!"));
gatto_fw_set_protect(); // disable update (!)
File firmware = SD.open("/firmware.bak");
if (firmware) {
Update.onProgress(firmware_progress);
Update.begin(firmware.size(), U_FLASH);
Update.writeStream(firmware);
if (Update.end()){
// Serial.println(F("Update finished!"));
}else{
//Serial.println(F("Update error!"));
//Serial.println(Update.getError());
firmware.close();
// delay(2000);
ESP.restart();
}else{
// Serial.println(F("error reading firmware"));
}else{
// Serial.println(F("error rename firmware"));
}else{
// Serial.println(F("No new firmware"));
}else{
SD.remove("/firmware.bin");
void setup_sdcard(){
pinMode(SD_CS, OUTPUT);
digitalWrite(SD_CS, HIGH);
SPI.begin(SDMMC_CLK, SDMMC_D0, SDMMC_CMD);
if(!SD.begin(SD_CS)){
// if(!SD.begin(SD_CS)){
SD_CARD_INFO[0] = 0;
}else{
SD_CARD_INFO[0] = SD.cardType();
//onError["SD"]["type"] = tipo;
SD_CARD_INFO[1] = SD.cardSize() / (1024 * 1024);
//onError["SD"]["size"] = cardSize;
SD_CARD_INFO[2] = SD.totalBytes() / (1024 * 1024);
//onError["SD"]["totalbytes"] = totalBytes;
SD_CARD_INFO[3] = SD.usedBytes() / (1024 * 1024);
//onError["SD"]["usedbytes"] = usedBytes;
SD_CARD_INFO[4] = (SD_CARD_INFO[2] - SD_CARD_INFO[3]); //free
setup(){
setup_sdcard();
firmware_update();
