SD Card Won't Mount ESP32 Arduino
CobaltTheFox
Postby CobaltTheFox » Tue Jul 16, 2024 9:36 pm
I have been using the following code for my project to attempt to mount an SD card.
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define REASSIGN_PINS
int sck = 40;
int miso = 39;
int mosi = 41;
int cs = 42;
  while (!Serial) {
    delay(10);
#ifdef REASSIGN_PINS
  SPI.begin(sck, miso, mosi, cs);
  if (!SD.begin(cs)) {
#else
  if (!SD.begin()) {
#endif
    Serial.println("Card Mount Failed");
    return;
  uint8_t cardType = SD.cardType();
  if (cardType == CARD_NONE) {
    Serial.println("No SD card attached");
    return;
  Serial.print("SD Card Type: ");
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
  } else if (cardType == CARD_SD) {
    Serial.println("SDSC");
  } else if (cardType == CARD_SDHC) {
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  uint64_t cardSize = SD.cardSize() / (1024 * 1024);
  Serial.printf("SD Card Size: %lluMB\n", cardSize);
  listDir(SD, "/", 0);
  createDir(SD, "/mydir");
  removeDir(SD, "/mydir");
  listDir(SD, "/", 2);
  writeFile(SD, "/hello.txt", "Hello ");
  appendFile(SD, "/hello.txt", "World!\n");
  readFile(SD, "/hello.txt");
  deleteFile(SD, "/foo.txt");
  renameFile(SD, "/hello.txt", "/foo.txt");
  readFile(SD, "/foo.txt");
  testFileIO(SD, "/test.txt");
  Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
  Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
I am constantly getting "Card not mounted". The SD card module is being supplied with about 3.215V. When I connect a logic analyzer, I'm not seeing anything off of the SPI lines. I'm sure I'm missing something minor but I'm not sure what it is.
Users browsing this forum: Baidu [Spider], ChatGPT-User, Google [Bot] and 2 guests
