Arduino Deep Sleep with with timer wake up example issue
0miker0
Postby 0miker0 » Wed Jan 03, 2018 12:31 pm
I'm having trouble with the Arduino deep sleep with timer wake up example code. On my hardware I've added a little led that is supposed to blink every 10 minutes. Right now it will wake up and blink for a few hours and then stay sleeping forever.
The battery voltage remains fine during the entire test so that isn't the issue. If someone has an ESP32 with an IO pin going to an LED then I would love to know if it a software issue or something wrong with my hardware.
Simple Deep Sleep with Timer Wake Up
ESP32 offers a deep sleep mode for effective power
saving as power is an important factor for IoT
applications. In this mode CPUs, most of the RAM,
and all the digital peripherals which are clocked
from APB_CLK are powered off. The only parts of
the chip which can still be powered on are:
RTC controller, RTC peripherals ,and RTC memories
This code displays the most basic deep sleep with
a timer to wake it up and how to store data in
RTC memory to use it over reboots
This code is under Public Domain License.
Author:
Pranav Cherukupalli <cherukupallip@gmail.com>
#define uS_TO_S_FACTOR 1000000  /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP  30        /* Time ESP32 will go to sleep (in seconds) */
#define Orange_Led 33
RTC_DATA_ATTR int bootCount = 0;
Method to print the reason by which ESP32
has been awaken from sleep
void print_wakeup_reason(){
  esp_sleep_wakeup_cause_t wakeup_reason;
  wakeup_reason = esp_sleep_get_wakeup_cause();
  switch(wakeup_reason)
    case 1  : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
    case 2  : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
    case 3  : Serial.println("Wakeup caused by timer"); break;
    case 4  : Serial.println("Wakeup caused by touchpad"); break;
    case 5  : Serial.println("Wakeup caused by ULP program"); break;
    default : Serial.println("Wakeup was not caused by deep sleep"); break;
void setup()
  delay(1000); //Take some time to open up the Serial Monitor
  pinMode(Orange_Led, OUTPUT);
  //Increment boot number and print it every reboot
  ++bootCount;
  Serial.println("Boot number: " + String(bootCount));
  //Print the wakeup reason for ESP32
  print_wakeup_reason();
  First we configure the wake up source
  We set our ESP32 to wake up every 5 seconds
  esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
  Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) +
  " Seconds");
  Next we decide what all peripherals to shut down/keep on
  By default, ESP32 will automatically power down the peripherals
  not needed by the wakeup source, but if you want to be a poweruser
  this is for you. Read in detail at the API docs
  http://esp-idf.readthedocs.io/en/latest/api-reference/system/deep_sleep.html
  Left the line commented as an example of how to configure peripherals.
  The line below turns off all RTC peripherals in deep sleep.
  //esp_deep_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH, ESP_PD_OPTION_OFF);
  //Serial.println("Configured all RTC Peripherals to be powered down in sleep");
  Now that we have setup a wake cause and if needed setup the
  peripherals state in deep sleep, we can now start going to
  deep sleep.
  In the case that no wake up sources were provided but deep
  sleep was started, it will sleep forever unless hardware
  reset occurs.
  Fast_Blink_LED();
  Serial.println("Going to sleep now");
  esp_deep_sleep_start();
  Serial.println("This will never be printed");
void loop()
  //This is not going to be called
void Fast_Blink_LED(void)
 digitalWrite(Orange_Led, HIGH);
 delay(200);
 digitalWrite(Orange_Led, LOW);
 delay(200);
 delay(200);
 delay(200);
Users browsing this forum: ChatGPT-User and 3 guests
