I am currently struggling with the integration of the new ESP32 P4 evaluation board.
The BSP are not loaded. The following error messages appear:
Manifest files have changed, solving dependencies.
Using component placed at C:\Kammerer\Projekte\ESP32P4\LVGL\TestLVGL\esp32_p4_function_ev_board for dependency esp32_p4_function_ev_board(*), specified in C:/Kammerer/Projekte/ESP32P4/LVGL/TestLVGL/main\idf_component.yml
.......................Using component placed at C:\Kammerer\Projekte\ESP32P4\LVGL\TestLVGL\esp32_p4_function_ev_board for dependency esp32_p4_function_ev_board(*), specified in C:/Kammerer/Projekte/ESP32P4/LVGL/TestLVGL/main\idf_component.yml
.......................CMake Error at C:/Users/OKammerer/esp/v5.3/esp-idf/tools/cmake/build.cmake:552 (message):
ERROR: Because no versions of esp32_p4_function_ev_board match
>=0.0.0,<0.0.1 || >0.0.1
and esp32_p4_function_ev_board (0.0.1) depends on espressif/esp_lcd_ek79007 (^0.1.0), esp32_p4_function_ev_board (>=0.0.0) requires espressif/esp_lcd_ek79007 (^0.1.0).
So, because no versions of espressif/esp_lcd_ek79007 match ^0.1.0
and project depends on esp32_p4_function_ev_board (*), version solving failed.
I am using:
OS: WIN11
VS Code 1.91.1
ESP_IDF: v5.3.0
Has anyone been able to compile the esp32-p4-function-ev-board LVGL examples?
esp32-p4-function-ev-board BSP
DerFrickler
Re: esp32-p4-function-ev-board BSP
I have found a solution. Following the instructions in this post:
https://github.com/espressif/esp-iot-so ... issues/383
After Installing component manager 2.0.0, I was able to compare the examples.
This board is a bit strange for me.
1) Why did they add USB serial chip and not connected USB JTAG / Serial from ESP32-P4 directly?
2) Why they used ESP32-C6 instead of ESP32 for radio? This would allow to use BT classic too and make it useful for wider range of applications.
Early ECOs had an issue that caused USB-JTAG-serial not to work from bootup. Not sure if the current ECO still has that issue, but I can imagine the board to be still the same.This board is a bit strange for me.
I imagine WiFi6 was deemed more important than BT Classic.2) Why they used ESP32-C6 instead of ESP32 for radio? This would allow to use BT classic too and make it useful for wider range of applications.
Thank you for information.
I have got this board now and indeed it is mentioned in the Sample notes that 0.1 chip revision does not yet support USB Serial JTAG.
I also get your points concerning WiFi 6.
But now, as ESP32-P4 is available, i hope Espressif could develop some "radio only" chip with BT Classic, BLE and WiFi 6 (2.4 and 5 Ghz) and strip all other peripherals to make it cheap and minimize power consumption. This would be perfect all-purpose communication processor for ESP32-P4.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
