esp32-s3-wroom1 RTC Cell
dkb1412
Postby dkb1412 » Fri Aug 09, 2024 12:18 pm
Does anyone know the recommended cell or circuitry for an RTC use case?
I want to use the RTC function on an ESP32-S3-WROOM-1 module but am unsure about the recommended cell or circuitry suggested by Espressif.
If anyone has experience with this, please help me find a solution.
Thanks and regards.
Re: esp32-s3-wroom1 RTC Cell
Postby Sprite » Fri Aug 09, 2024 11:53 pm
There is none: the RTC does not support running off a separate battery.
dkb1412
Postby dkb1412 » Sat Aug 10, 2024 12:58 pm
Would I need to use an external RTC IC and configure it with I2C on an ESP32-S3? If so, what RTC IC and circuit would you recommend?
Thanks & Regards
Users browsing this forum: Bing [Bot], Qwantbot and 1 guest
