Rainmaker guideline for ESP32 and IDE
fmb787
Postby fmb787 » Sat Aug 10, 2024 10:04 pm
iam looking for guideline how to use Rainmaker , a person new into this and i learn from the examples that comes with library which unfortunately there are only 4 examples :
1-RMakerCustom
2-RMakerCustomAirCooler
3-RMakersonoffDualR3
4-RMakerSwitch
so could someone guide me with this issue
not able to uses below info , believe they are very advance for me .
https://docs.espressif.com/projects/ard ... maker.html
https://espressif-docs.readthedocs-host ... maker.html
https://rainmaker.espressif.com/docs/standard-types
thanks ..
Piyush
Re: Rainmaker guideline for ESP32 and IDE
Postby Piyush » Mon Aug 12, 2024 9:29 am
The examples typically are meant to serve as a starting point and the ones for RainMaker Arduino cater to different use cases like standard device, custom device and multi device. Depending on your use case, you can start with one. The "issue" regarding using these is not clear from your description. Can you be a bit more specific about what you are trying to do and what did not work?
