MQTT memory leaks while reconnecting Wi-Fi
sohaib.q
Postby sohaib.q » Mon Aug 12, 2024 8:48 am
The code below is my network_manager.c is used to deinitialize and initialize the wifi task based on the network_change_counter value. The idea is to switch between wifi interface and observe if there is any memory leakage between a wifi connectivity cycle. I'm having almost 800-900 bytes of memory leakage. The problem seems to be the MQTT component if I do not start the MQTT, there is no memory leakage when we initialize, deinitialize, and again initialize the wifi interface.
network_manager.c
Code: Untitled.c Select all
unsigned int network_change_counter = 0;
void network_task(void *pvParameter)
while (1)
if(flag_wifi_connected)
network_change_counter++;
ESP_LOGW(TAG, "Connected Counter: %d.\n", network_change_counter);
if(network_change_counter > 12 && network_change_counter < 14)
ESP_LOGW(TAG, "Deinitializing Wi-Fi mode.\n");
// network_change_counter = 0;
set_current_network_mode(NETWORK_MODE_NO_NETWORK);
// set_change_network_mode_flag();
if(!flag_wifi_connected && get_current_network_mode() == NETWORK_MODE_NO_NETWORK) // switching to Wi-Fi
ESP_LOGW(TAG, "Not connected Counter: %d.\n", network_change_counter);
if(network_change_counter > 14 && network_change_counter < 16)
ESP_LOGW(TAG, "Reinitializing Network mode to: %d.\n", (int)get_current_network_mode());
set_current_network_mode(NETWORK_MODE_ONLY_WIFI);
if(get_change_network_mode_flag() && !flag_wifi_connected)
ESP_LOGI(TAG, "Changing Network mode to: %d.\n", (int)get_current_network_mode());
if(get_current_network_mode() == NETWORK_MODE_ONLY_WIFI) // switching to Wi-Fi
// xTaskCreatePinnedToCore(&lte_bridge_task, "lte_bridge_task", 1024*4, NULL, 21, NULL, 0);
xTaskCreate(&wifi_task, "wifi_task", 1024*6, NULL, 20, NULL);
reset_change_network_mode_flag();
vTaskDelay(3000 / portTICK_PERIOD_MS);
Below is my wifi_manager.c code
wifi_manager.c
//headers
static const char *TAG = "[Wi-Fi]";
wifi_config_t wifi_config;
char esp_def_wifi_ssid[SSID_MAX_LEN] = "testWifi";
char esp_def_wifi_pass[PASS_MAX_LEN] = "12345678";
#define ESP_WIFI_SAE_MODE WPA3_SAE_PWE_HUNT_AND_PECK
#define EXAMPLE_H2E_IDENTIFIER ""
#define ESP_WIFI_SCAN_AUTH_MODE_THRESHOLD WIFI_AUTH_WPA2_PSK
wifi_cred_t wifi_cred;
char wifi_ip[16];
bool flag_wifi_connected = false;
bool flag_wifi_cred_changed = false;
uint32_t wifi_retry_count = 0;
TimerHandle_t wifi_retry_timer = NULL;
static esp_event_handler_instance_t instance_any_id;
static esp_event_handler_instance_t instance_got_ip;
static bool wifi_initialized = false;
extern modem_wifi_config_t s_modem_wifi_config;
extern char hub_id[9];
extern esp_err_t mqtt_pause(void);
extern esp_err_t mqtt_resume(void);
static void stop_wifi_retry_timer(void)
if (wifi_retry_timer != NULL)
ESP_LOGI(TAG, "Stopping wifi retry timer.");
xTimerStop(wifi_retry_timer, 0);
xTimerDelete(wifi_retry_timer, 0);
static void wifi_retry_timer_callback(TimerHandle_t xTimer)
if (wifi_retry_count < WIFI_RETRY_MAX_COUNT)
esp_wifi_connect();
wifi_retry_count++;
ESP_LOGI(TAG, "Retry to connect to the AP: %s (Attempt %ld)", wifi_cred.ssid, wifi_retry_count);
else
// Switch to LTE mode
//set LTE mode logic
stop_wifi_retry_timer();
static void start_wifi_retry_timer(void)
if (wifi_retry_timer == NULL)
wifi_retry_timer = xTimerCreate("WifiRetryTimer", pdMS_TO_TICKS(5000), pdTRUE, (void *)0, wifi_retry_timer_callback);
ESP_LOGE(TAG, "Failed to create retry timer!");
else
if (xTimerStart(wifi_retry_timer, 0) != pdPASS)
ESP_LOGE(TAG, "Failed to start retry timer!");
else
ESP_LOGI(TAG, "Wi-Fi retry timer created and running successfully.");
else
xTimerStart(wifi_retry_timer, 0);
static void wifi_event_handler(void* arg, esp_event_base_t event_base, int32_t event_id, void* event_data)
static bool processing_disconnection = false;
if (event_base == WIFI_EVENT)
switch (event_id)
case WIFI_EVENT_STA_START:
esp_wifi_connect();
case WIFI_EVENT_STA_CONNECTED:
if(!flag_wifi_connected)
ESP_LOGI(TAG, "Wi-Fi Connected");
flag_wifi_connected = true;
case WIFI_EVENT_STA_DISCONNECTED:
if (!processing_disconnection) // Process disconnection only if not already processing
ESP_LOGI(TAG, "Wi-Fi Disconnected");
processing_disconnection = true;
if (get_current_network_mode() == NETWORK_MODE_ONLY_WIFI && wifi_retry_timer == NULL)
start_wifi_retry_timer();
mqtt_pause();
case WIFI_EVENT_STA_STOP:
ESP_LOGI(TAG, "Wi-Fi STA Stopped");
default:
else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP)
ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
sprintf(wifi_ip, IPSTR, IP2STR(&event->ip_info.ip));
ESP_LOGI(TAG, "got ip:%s", wifi_ip);
mqtt_resume();
void wifi_init_sta(void)
if (wifi_initialized)
ESP_LOGW(TAG, "Wi-Fi already initialized, skipping initialization.");
return;
// Check if the default Wi-Fi interface already exists
esp_netif_t *sta_netif = esp_netif_get_handle_from_ifkey("WIFI_STA_DEF");
if (sta_netif != NULL)
ESP_LOGW(TAG, "Default Wi-Fi interface already exists");
else
// Create the default Wi-Fi interface
sta_netif = esp_netif_create_default_wifi_sta();
if (sta_netif == NULL)
ESP_LOGE(TAG, "Failed to create default Wi-Fi interface");
return;
ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
ESP_EVENT_ANY_ID,
&wifi_event_handler,
NULL,
&instance_any_id));
ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
IP_EVENT_STA_GOT_IP,
NULL,
&instance_got_ip));
get_wifi_credentials_file(wifi_cred.ssid, wifi_cred.pass);
ESP_LOGI(TAG, "Got credentails as SSID:%s Password:%s", wifi_cred.ssid, wifi_cred.pass);
bzero(&wifi_config, sizeof(wifi_config_t));
memcpy(wifi_config.sta.ssid, wifi_cred.ssid, sizeof(wifi_config.sta.ssid));
memcpy(wifi_config.sta.password, wifi_cred.pass, sizeof(wifi_config.sta.password));
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
ESP_LOGI(TAG, "wifi_init_sta finished.");
wifi_initialized = true;
void wifi_deinit_sta(void)
if (!wifi_initialized)
ESP_LOGW(TAG, "Wi-Fi not initialized, skipping deinitialization.");
return;
ESP_LOGE(TAG, "Disconnecting from Wi-Fi");
esp_wifi_disconnect();
esp_wifi_stop();
esp_wifi_deinit();
ESP_ERROR_CHECK(esp_event_handler_instance_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, instance_any_id));
ESP_ERROR_CHECK(esp_event_handler_instance_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, instance_got_ip));
// Destroy default Wi-Fi netif
esp_netif_t *netifConf = esp_netif_get_handle_from_ifkey("WIFI_STA_DEF");
if (netifConf != NULL)
esp_netif_destroy_default_wifi(netifConf);
// Deinitialize the network interface
// esp_netif_deinit();
void wifi_task(void *pvParameter)
ESP_LOGI(TAG, "Wi-Fi task created successfully");
wifi_init_sta();
while (1)
if (get_current_network_mode() != NETWORK_MODE_ONLY_WIFI)
wifi_deinit_sta();
ESP_LOGW(TAG, "Deleting wifi_task");
// Delete the task
vTaskDelete(NULL);
Below is the code for mqtt_manager.c which is being initialized in the start using mqtt_app_start function
mqtt_manager.c
// headers
static const char *TAG = "[MQTT_MANAGER]";
esp_mqtt_client_handle_t client = NULL;
mqtt_topic_t hub_sub_topic_request;
mqtt_topic_t hub_pub_topic_event;
extern const uint8_t client_cert_pem_start[] asm("_binary_client_crt_start");
extern const uint8_t client_cert_pem_end[] asm("_binary_client_crt_end");
extern const uint8_t client_key_pem_start[] asm("_binary_client_key_start");
extern const uint8_t client_key_pem_end[] asm("_binary_client_key_end");
extern const uint8_t server_cert_pem_start[] asm("_binary_mosquitto_org_crt_start");
extern const uint8_t server_cert_pem_end[] asm("_binary_mosquitto_org_crt_end");
char *json_resp;
char *json_err;
static void log_error_if_nonzero(const char *message, int error_code)
if (error_code != 0) {
ESP_LOGE(TAG, "Last error %s: 0x%x", message, error_code);
return esp_mqtt_client_stop(client);
return esp_mqtt_client_start(client);
static void mqtt_event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data)
ESP_LOGD(TAG, "Event dispatched from event loop base=%s, event_id=%" PRIi32, base, event_id);
esp_mqtt_event_handle_t event = event_data;
esp_mqtt_client_handle_t client = event->client;
int msg_id = -1;
switch ((esp_mqtt_event_id_t)event_id)
case MQTT_EVENT_CONNECTED:
ESP_LOGI(TAG, "MQTT_EVENT_CONNECTED");
msg_id = esp_mqtt_client_subscribe(client, hub_sub_topic_request.topic, 0);
ESP_LOGI(TAG, "sent subscribe successful, msg_id=%d", msg_id);
msg_id = esp_mqtt_client_publish(client, hub_pub_topic_event.topic, get_hub_online_string(), 0, 0, 0);
ESP_LOGI(TAG, "sent publish successful, msg_id=%d", msg_id);
case MQTT_EVENT_DISCONNECTED:
ESP_LOGI(TAG, "MQTT_EVENT_DISCONNECTED");
case MQTT_EVENT_SUBSCRIBED:
ESP_LOGI(TAG, "MQTT_EVENT_SUBSCRIBED, msg_id=%d", event->msg_id);
case MQTT_EVENT_UNSUBSCRIBED:
ESP_LOGI(TAG, "MQTT_EVENT_UNSUBSCRIBED, msg_id=%d", event->msg_id);
case MQTT_EVENT_PUBLISHED:
ESP_LOGI(TAG, "MQTT_EVENT_PUBLISHED, msg_id=%d", event->msg_id);
case MQTT_EVENT_DATA:
ESP_LOGI(TAG, "MQTT_EVENT_DATA");
case MQTT_EVENT_ERROR:
ESP_LOGI(TAG, "MQTT_EVENT_ERROR");
if (event->error_handle->error_type == MQTT_ERROR_TYPE_TCP_TRANSPORT)
log_error_if_nonzero("reported from esp-tls", event->error_handle->esp_tls_last_esp_err);
log_error_if_nonzero("reported from tls stack", event->error_handle->esp_tls_stack_err);
log_error_if_nonzero("captured as transport's socket errno", event->error_handle->esp_transport_sock_errno);
ESP_LOGI(TAG, "Last errno string (%s)", strerror(event->error_handle->esp_transport_sock_errno));
default:
ESP_LOGI(TAG, "Other event id:%d", event->event_id);
void mqtt_app_start(char *hub_id)
esp_err_t err = esp_netif_init();
if (err != ESP_OK)
ESP_LOGE(TAG, "Failed to initialize TCP/IP stack: %s", esp_err_to_name(err));
return;
// Create the default event loop
err = esp_event_loop_create_default();
if (err != ESP_OK)
ESP_LOGE(TAG, "Failed to create default event loop: %s", esp_err_to_name(err));
esp_netif_deinit();
return;
ESP_LOGI(TAG, "Starting MQTT process");
esp_err_t esp_mqtt_err;
sprintf(hub_sub_topic_request.topic,"header/%s/hub/request",hub_id);
sprintf(hub_pub_topic_event.topic,"header/%s/hub/event",hub_id);
const esp_mqtt_client_config_t mqtt_cfg =
.broker.address.uri = "mqtts://urlxxxx.iot.us-east-1.amazonaws.com:8883",
.broker.verification.certificate = (const char *)server_cert_pem_start,
.credentials =
.authentication =
.certificate = (const char *)client_cert_pem_start,
.key = (const char *)client_key_pem_start,
client = esp_mqtt_client_init(&mqtt_cfg);
if (client == NULL)
ESP_LOGE(TAG, "Failed to initialize MQTT client");
return;
// The last argument may be used to pass data to the event handler, in this example mqtt_event_handler
esp_mqtt_err = esp_mqtt_client_register_event(client, ESP_EVENT_ANY_ID, mqtt_event_handler, NULL);
if (esp_mqtt_err != ESP_OK)
ESP_LOGE(TAG, "Failed to register MQTT event handler: %s", esp_err_to_name(esp_mqtt_err));
/* esp_mqtt_err = esp_mqtt_client_start(client);
ESP_LOGE(TAG, "Failed to start MQTT client: %s", esp_err_to_name(esp_mqtt_err));
I'm printing the Internal Free heap size using esp_get_free_internal_heap_size() and every time I get connected to the MQTT broker and publish a message, there is a decrease in available heap size by almost 800-900 bytes.
Users browsing this forum: Baidu [Spider], ChatGPT-User, Google [Bot], PerplexityBot, YisouSpider and 2 guests
