how to update periodic timer?
natee.th
Postby natee.th » Tue Aug 13, 2024 3:55 pm
Hi everyone, I'm trying to figure out how to make a rhythm machine from esp32, using the esp_timer_start_periodic function, but I don't know how to adjust the time with any command or method, can you give me some advice?
    const esp_timer_create_args_t periodic_timer_args_bpm = {
        .callback = &periodic_timer_callback_bpm,
        /* name is optional, but may help identify the timer when debugging */
        .name = "periodic"};
    ESP_ERROR_CHECK(esp_timer_create(&periodic_timer_args_bpm, &periodic_timer_bpm));
    /* The timer has been created but is not running yet */
    ESP_ERROR_CHECK(esp_timer_start_periodic(periodic_timer_bpm, 2500));
static void periodic_timer_callback_bpm(void *arg)
    bpm_rise_signal = !bpm_rise_signal;
    gpio_set_level(SYNC_OUT_PIN, bpm_rise_signal);
aliarifat794
Re: how to update periodic timer?
Postby aliarifat794 » Tue Aug 13, 2024 4:16 pm
You can modify your code to adjust the timing based on BPM (beats per minute). You can then use this interval when calling adjust_timer_interval.
#include "esp_timer.h"
esp_timer_handle_t periodic_timer_bpm;
bool bpm_rise_signal = false;
#define SYNC_OUT_PIN 25 // Example GPIO pin
void setup_timer(int interval_us)
        .name = "periodic"
    // Create the timer
    // Start the timer with the given interval
    ESP_ERROR_CHECK(esp_timer_start_periodic(periodic_timer_bpm, interval_us));
void adjust_timer_interval(int new_interval_us)
    // Stop the current timer
    ESP_ERROR_CHECK(esp_timer_stop(periodic_timer_bpm));
    // Start the timer again with the new interval
    ESP_ERROR_CHECK(esp_timer_start_periodic(periodic_timer_bpm, new_interval_us));
void app_main(void)
    // Example: Set initial BPM interval
    int initial_interval_us = 2500;
    setup_timer(initial_interval_us);
    // Adjust timer to a new interval after some condition
    int new_interval_us = 5000; // Example: New interval (e.g., based on BPM)
    adjust_timer_interval(new_interval_us);
MicroController
Postby MicroController » Wed Aug 14, 2024 9:22 am
Users browsing this forum: Bytespider, PerplexityBot and 1 guest
