IDF: 5.3
IDE: VS Code 1.92.0
TagetBoard: ESP32-C3-DevKit-RUST-1
Connection: built-in JATA, OpenOCD
launch.json:
"configurations": [
"type": "gdbtarget",
"request": "attach",
"name": "ESP32C3",
"program": "${workspaceFolder}/build/${command:espIdf.getProjectName}.elf",
"initCommands": [
"set remote hardware-watchpoint-limit 10",
"mon reset halt",
"maintenance flush register-cache",
"thb app_main",
"c"
"gdb": "${command:espIdf.getToolchainGdb}",
"target": {
"connectCommands": [
"set remotetimeout 500",
"-target-select extended-remote localhost:3333"
setting.json:
"idf.adapterTargetName": "esp32c3",
"files.associations": {
"freertos.h": "c",
"task.h": "c",
"array": "c",
"vector": "c",
"xstring": "c",
"xutility": "c",
"gpio.h": "c",
"temp_sensor.h": "c",
"uart.h": "c",
"esp_log.h": "c",
"esp_wifi.h": "c",
"assert.h": "c",
"subscription_manager.h": "c",
"stddef.h": "c",
"string.h": "c",
"freertosconfig.h": "c"
"idf.portWin": "COM8",
"idf.flashType": "JTAG",
"idf.openOcdConfigs": [
"board/esp32c3-builtin.cfg"
1.when start debug, it frequently prompt connection failure, just like this:
the "DEBUG CONSOLE" output:
GNU gdb (esp-gdb) 14.2_20240403
Copyright (C) 2023 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "--host=x86_64-w64-mingw32 --target=riscv32-esp-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
https://www.gnu.org/software/gdb/bugs/.
Find the GDB manual and other documentation resources online at:
http://www.gnu.org/software/gdb/documentation/.
For help, type "help".
Type "apropos word" to search for commands related to "word".
warning: could not convert 'main' from the host encoding (CP1252) to UTF-32.
This normally should not happen, please file a bug report.
2.Even if it is connected, I find that there cannot be a breakpoint.
a. the "DEBUG CONSOLE" output::
0x420db2da in semihosting_call_noerrno (id=536870912, id@entry=259, data=data@entry=0x3fcae1e4) at C:/JasonSoftware/Espressif/frameworks/esp-idf-v5.3/components/riscv/include/riscv/semihosting.h:77
mon reset halt
JTAG tap: esp32c3.cpu tap/device found: 0x00005c25 (mfg: 0x612 (Espressif Systems), part: 0x0005, ver: 0x0)
[esp32c3] Reset cause (3) - (Software core reset)
Register cache flushed.
thb app_main
Hardware assisted breakpoint 1 at 0x42006668: file C:/Code/forDebug/main/main.c, line 153.
GDB unhandled notify: breakpoint-created: {"bkpt":{"number":"1","type":"hw breakpoint","disp":"del","enabled":"y","addr":"0x42006668","func":"app_main","file":"C:/Code/forDebug/main/main.c","fullname":"C:\Code\forDebug\main\main.c","line":"153","thread-groups":["i1"],"times":"0","original-location":"app_main"}}
c
Continuing.
[New Thread 1070259692]
[Remote target exited]
[New Thread 1070261060]
[New Thread 1070254924]
[Switching to Thread 1070259692]
Thread 2 "main" hit Temporary breakpoint 1, app_main () at C:/Code/forDebug/main/main.c:153
153 xNetworkContext.pcHostname = CONFIG_GRI_MQTT_ENDPOINT;
Thread 2 "main" received signal SIGINT, Interrupt.
0x42005180 in usb_serial_jtag_ll_txfifo_writable () at C:/JasonSoftware/Espressif/frameworks/esp-idf-v5.3/components/hal/esp32c3/include/hal/usb_serial_jtag_ll.h:160
160 return USB_SERIAL_JTAG.ep1_conf.serial_in_ep_data_free;
b. the "OUTPUT" output:
[OpenOCD]
Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:26)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
C:\JasonSoftware\Espressif\tools\openocd-esp32\v0.12.0-esp32-20240318\openocd-esp32\bin\openocd.exe
Info : only one transport
option; autoselecting 'jtag'
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1001
Info : esp_usb_jtag: capabilities descriptor set to 0x2000
Info : esp_usb_jtag: serial (40:4C:CA:89:67:2C)
Info : esp_usb_jtag: Device found. Ba
se speed 40000KHz, div range 1 to 255
Info : clock speed 40000 kHz
Info : JTAG tap: esp32c3
C:\JasonSoftware\Espressif\tools\riscv32-esp-elf-gdb\14.2_20240403\riscv32-esp-elf-gdb\bin\riscv32-esp-elf-gdb.exe
Info : [esp32c3] datacount=2 progbufsize=16
Info : [esp32c3] Examined RISC-V co
re; found 1 harts
Info : [esp32c3] XLEN=32, misa=0x40101104
Info : [esp32c3] Examination succeed
Info : starting gdb server for esp32c3 on 3333
Info : [esp32c3] Found 8 triggers
Info : Flash mapping 0: 0x10020 -> 0x3c020020,
34 KB
Info : Auto-detected flash bank 'esp32c3.flas
h' size 4096 KB
Info : Using flash bank 'esp32c3.flash' size 4096 KB
Info : Flash mapping 0: 0x10020 -> 0x3c020020, 34 KB
Info
: Using flash bank 'esp32c3.irom' size 0 KB
020, 34 KB
Info : Using flash bank 'esp32c3.drom' size 36 KB
Info : Detected FreeRTOS version
: (10.5.1)
Info : JTAG tap: esp32c3.cpu tap/device found: 0x00005c25
Info : [esp32c3] Reset cause (3) - (Software core reset)
Info : Detected FreeRTOS version: (10.5.1)
Info : The target is not running when halt was requested, stopping GDB.
pping GDB.
pping GDB.
c. But when in debugging "Info : The target is not running when halt was requested, stopping GDB.", i found "idf.py monitor" has log output
Be clear than, I uncheck watchdog in menuconfig
VsCode Debug fail
Moderator: ZT
aliarifat794
rocotocloc
Re: VsCode Debug fail
This was my problem. Thank you.Check the power supply of the target device and also try to reset that.
