If my current mesh network is like this:
A
B
C D
If device C or device D wants to send a message to device A, can they just use the `esp_mesh_send` function and write the address of device A as the first parameter? Then the mesh library will send it to B, and then B will transfer it to A, but this process is opaque and the caller cannot perceive it, right?
ESP32 WiFiMesh sending problem
aliarifat794
Re: ESP32 WiFiMesh sending problem
In the ESP-MESH network, devices can communicate with each other by simply specifying the destination address when using the esp_mesh_send function.
The ESP-MESH library handles the routing automatically. Device C or D sends the message to device B. Device B forwards the message to device A.
Troy Mitchell
Get it. Thanks for ur response.In the ESP-MESH network, devices can communicate with each other by simply specifying the destination address when using the esp_mesh_send function.
Best regards.
Users browsing this forum: Amazon [Bot], Baidu [Spider], Bing [Bot], Qwantbot and 1 guest
