Does ESP-AT support WiFi provisioning over BLE?
I would like to make use of the existing apps for this (e.g. https://github.com/espressif/esp-idf-pr ... ng-android)
https://docs.espressif.com/projects/esp ... oning.html
aliarifat794
Re: WiFi provisioning over BLE
As far as I know, it does.Does ESP-AT support WiFi provisioning over BLE?
You can learn about BluFi Provisioning. BluFi provisioning is done through the mobile device's Bluetooth interface. Therefore, it requires the mobile device to have Bluetooth and GPS enabled, and the EspBluFi app must be downloaded.
- Android: `EspBluFi App & Source Code <https://github.com/EspressifApp/EspBlufiForAndroid>`_
- iOS: `EspBluFi App <https://apps.apple.com/cn/app/EspBlufi/id1450614082>`_
- iOS: `EspBluFi App Source Code <https://github.com/EspressifApp/EspBlufiForiOS>`_
1. Download the EspBluFi app on your mobile device.
2. Set the BluFi device name.
Command:
Response:
3. Enable BluFi.
Command:
Response:
4. Create a BluFi connection and perform provisioning.
Enable Bluetooth and GPS on your mobile device, launch the EspBluFi app, find the device named ``blufi_test`` and click to enter, then click ``Connect`` to establish the connection. At this point, the ESP device should print a log similar to ``+BLUFICONN``, and the application page will also display similar information, indicating that the BluFi connection has been successfully established.
At this point, click the ``Configure`` button on your mobile device, which will redirect you to the ``Configure`` page. On this page, fill in the Wi-Fi SSID and password, then click the ``OK`` button to start the provisioning process. The application page will also display similar information.
At this point, the ESP device should output the following log
At this point, the ESP device's provisioning has been successfully completed.
Command:
AT+BLUFINAME="blufi_test"Response:
OK3. Enable BluFi.
Command:
AT+BLUFI=1Response:
OK4. Create a BluFi connection and perform provisioning.
Connected <mac>
Discover service and characteristics success
Set notification enable complete
Set mtu complete, mtu=...At this point, click the ``Configure`` button on your mobile device, which will redirect you to the ``Configure`` page. On this page, fill in the Wi-Fi SSID and password, then click the ``OK`` button to start the provisioning process. The application page will also display similar information.
Post configure params complete
Receive device status response:
OpMode: Station
Station connect Wi-Fi now
Station connect Wi-Fi bssid: <mac>
Station connect Wi-Fi ssid: <ssid>At this point, the ESP device should output the following log
WIFI CONNECTED
WIFI GOT IPAt this point, the ESP device's provisioning has been successfully completed.
