esp8266 compiling error
devon_0
Postby devon_0 » Thu Aug 22, 2024 11:58 am
I am compiling my code on arduino ide for my esp8266.
when compiling i cam across this error:
WARNING: library U8glib claims to run on avr, sam architecture(s) and may be incompatible with your current board which runs on esp8266 architecture(s).
c:/users/toshiba/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.1.0-gcc10.3-e5f9fec/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld.exe: C:\Users\TOSHIBA\AppData\Local\Temp\arduino\sketches\06E6FB26B4FD5162FFD6D036F67EAC43/u8glib_progress_bar.ino.elf section `.irom0.text' will not fit in region `irom0_0_seg'
exit status 1
Compilation error: exit status 1
Inq720
Contact:
Re: esp8266 compiling error
Postby Inq720 » Fri Aug 23, 2024 11:01 am
I'll assume your question is, "what does this warning mean?" It is explicitly saying... the library you're using is not compatible with your ESP8266. If you think the library developer is being too conservative, you can brute force it, so the compiler will try to compile it.
