Cannot process component requirements. Multiple candidates to satisfy project requirements
Dharanesh
Postby Dharanesh » Wed Aug 28, 2024 7:38 am
"$ENV{IDF_PATH}/components/esp-homekit-sdk/components/homekit"
am alredy using the apple home kit in my ESP-IDF project
now i want to add the
"${ESP_MATTER_PATH}/components"
"${ESP_MATTER_PATH}/examples/common"
"${MATTER_SDK_PATH}/config/esp32/components"
${extra_components_dirs_append}
matter protocol in the project
when i head to add this
CMake Error at /home/dharanesh/esp/esp-idf/tools/cmake/component.cmake:251 (message):
ERROR: Cannot process component requirements. Multiple candidates to
satisfy project requirements:
requirement: "json_generator" candidates: "espressif__json_generator, json_generator"
requirement: "json_parser" candidates: "json_parser, espressif__json_parser"
i got this error how to resolve it
and this is my components CmakeLists.txt
cmake_minimum_required(VERSION 3.16)
  if(NOT DEFINED ENV{ESP_MATTER_PATH})
      message(FATAL_ERROR "Please set ESP_MATTER_PATH to the path of esp-matter repo")
  endif(NOT DEFINED ENV{ESP_MATTER_PATH})
  set(PROJECT_VER "1.0")
  set(PROJECT_VER_NUMBER 1)
  set(ESP_MATTER_PATH $ENV{ESP_MATTER_PATH})
  set(MATTER_SDK_PATH ${ESP_MATTER_PATH}/connectedhomeip/connectedhomeip)
  include(${ESP_MATTER_PATH}/examples/common/cmake_common/components_include.cmake)
  set(EXTRA_COMPONENT_DIRS
      "$ENV{IDF_PATH}/components/esp-aws-iot/libraries/coreMQTT"
      "$ENV{IDF_PATH}/components/esp-aws-iot/libraries/common/posix_compat"
      "$ENV{IDF_PATH}/components/esp-aws-iot/libraries/backoffAlgorithm"
      "$ENV{IDF_PATH}/components/esp-homekit-sdk/examples/common"
      ${extra_components_dirs_append})
  message(STATUS "EXTRA_COMPONENT_DIRS is : ${EXTRA_COMPONENT_DIRS}")
  project(code-flow)
  idf_build_set_property(CXX_COMPILE_OPTIONS "-std=gnu++17;-Os;-DCHIP_HAVE_CONFIG_H;-Wno-overloaded-virtual" APPEND)
  idf_build_set_property(C_COMPILE_OPTIONS "-Os" APPEND)
  idf_build_set_property(COMPILE_OPTIONS "-Wno-format-nonliteral;-Wno-format-security" APPEND)
  target_add_binary_data(${CMAKE_PROJECT_NAME}.elf "main/soul/root_cert_auth.crt" TEXT)
  target_add_binary_data(${CMAKE_PROJECT_NAME}.elf "main/soul/client.crt" TEXT)
  target_add_binary_data(${CMAKE_PROJECT_NAME}.elf "main/soul/client.key" TEXT)
  set(PARTITION_TABLE_CSV ${CMAKE_CURRENT_LIST_DIR}/partitions.csv)
  set(CMAKE_VERBOSE_MAKEFILE ON)
  set_property(GLOBAL APPEND PROPERTY EXTRA_PARTITION_TABLES ${PARTITION_TABLE_CSV})
Users browsing this forum: Applebot, Baidu [Spider], PetalBot and 3 guests
