Warning message re parsing
stevenbennett
Postby stevenbennett » Fri Sep 06, 2024 9:08 am
Is there a solution to this warning message: "e:\Users\Steven\Documents\GitHub\ESP-IDF\LED_strip/build/compile_commands.json" could not be parsed. 'includePath' from c_cpp_properties.json in folder 'LED_STRIP' will be used instead. ??
Thank you
stevenbennett
Re: Warning message re parsing
Postby stevenbennett » Sat Sep 07, 2024 4:14 pm
I worked it out, the warning is because at that point in the process the build folder does not yet exist consequently /build/compile_commands.json" could not be parsed.
