Simple AT command using ESP32-WROOM and usb/ttl connector
momen_ahmed
Postby momen_ahmed » Fri Sep 13, 2024 1:24 pm
I'm trying to test the AT commands with esp32-WROOM and usb/ttl ,
the connections : Tx of esp32 -> Rx of ttl
Rx of esp32 -> Tx of ttl
3.3v of esp32 -> 3.3v of ttl
GND of esp32 -> GND of ttl
EN pin of esp32 -> 3.3v
GPIO0 of esp32 -> 3.3v (for normal mode)
after that when I test a simple AT command that's what appears
WhatsApp Image 2024-09-13 at 16.19.06_53736b79.jpg (108.84 KiB) Viewed 8795 times
somethings related to booting while I expect normal "OK" response
any explanations for that ??
esp-at
Re: Simple AT command using ESP32-WROOM and usb/ttl connector
Postby esp-at » Wed Oct 09, 2024 12:13 pm
could you please try the lastst v3.4.0.0 firmware:
https://docs.espressif.com/projects/esp ... aries.html
