Can't launch monitor within VSCode (M1 Mac, MacOS Sequoia)
JamesBlonde
Postby JamesBlonde » Wed Sep 25, 2024 3:58 am
Hi All,
After upgrading to MacOS Sequoia my VSCode stopped launching. I reinstalled VSCode and had problems with the ESP-IDF extension. After extensive troubleshooting I’ve regained most functionality but still cannot launch the monitor within VSCode.
When trying to launch the monitor it appears to hang on this command:
export IDF_PATH='/Users/XXX/esp/esp-idf'
'/Users/XXX/.espressif/python_env/idf5.3_py3.12_env/bin/python' '/Users/XXX/esp/esp-idf/tools/idf_monitor.py' -p /dev/tty.SLAB_USBtoUART -b 115200 --toolchain-prefix xtensa-esp32s3-elf- --target esp32s3 '/Users/XXX/hello_world/build/hello_world.elf'
I am able to run it outside of VSCode using 'idf.py monitor' with the standard '. ./export.sh' approach found here - https://docs.espressif.com/projects/esp ... setup.html
Version Details:
OS: Mac OS Sequoia 15.0
VSCode: 1.93.1
ESP-IDF Framework: 5.3
Python: 3.12.6
ESP-IDF Extension: v1.8.1
Can anyone please help?
I noticed that both "IDF_PYTHON_ENV_PATH" and "PYTHON" environment variables are undefined in the doctor command output. Is that the problem?
Output of doctor command
---------------------------------------------- ESP-IDF Extension for Visual Studio Code report ---------------------------------------------
OS darwin arm64 24.0.0
System environment variable IDF_PYTHON_ENV_PATH
 undefined
System environment variable PATH
 /usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/TeX/texbin:/Applications/VMware Fusion Tech Preview.app/Contents/Public
System environment variable PYTHON
 undefined
Visual Studio Code version 1.93.1
Visual Studio Code language en
Visual Studio Code shell /usr/local/bin/bash
ESP-IDF Extension version 1.8.1
Workspace folder <HOMEPATH>/hello_world
---------------------------------------------------- Extension configuration settings ------------------------------------------------------
ESP-ADF Path (idf.espAdfPath) ${env:ADF_PATH}
ESP-IDF Path (idf.espIdfPath) <HOMEPATH>/esp/esp-idf
ESP-MDF Path (idf.espMdfPath) ${env:MDF_PATH}
ESP-Matter Path (idf.espMatterPath) ${env:ESP_MATTER_PATH}
ESP-HomeKit-SDK Path (idf.espHomeKitSdkPath) ${env:HOMEKIT_PATH}
Custom extra paths (idf.customExtraPaths) <HOMEPATH>/.espressif/tools/xtensa-esp-elf-gdb/14.2_20240403/xtensa-esp-elf-gdb/bin:<HOMEPATH>/.espressif/tools/riscv32-esp-elf-gdb/14.2_20240403/riscv32-esp-elf-gdb/bin:<HOMEPATH>/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin:<HOMEPATH>/.espressif/tools/riscv32-esp-elf/esp-13.2.0_20240530/riscv32-esp-elf/bin:<HOMEPATH>/.espressif/tools/esp32ulp-elf/2.38_20240113/esp32ulp-elf/bin:<HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20240318/openocd-esp32/bin:<HOMEPATH>/.espressif/tools/esp-rom-elfs/20240305
Custom extra vars (idf.customExtraVars)
    OPENOCD_SCRIPTS: <HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20240318/openocd-esp32/share/openocd/scripts
    ESP_ROM_ELF_DIR: <HOMEPATH>/.espressif/tools/esp-rom-elfs/20240305/
Virtual env Python Path (idf.pythonBinPath) <HOMEPATH>/.espressif/python_env/idf5.3_py3.12_env/bin/python
Serial port (idf.port) /dev/tty.SLAB_USBtoUART
OpenOCD Configs (idf.openOcdConfigs) board/esp32s3-builtin.cfg
ESP-IDF Tools Path (idf.toolsPath) <HOMEPATH>/.espressif
Git Path (idf.gitPath) git
Notification Mode (idf.notificationMode) All
-------------------------------------------------------- Configurations access -------------------------------------------------------------
Access to ESP-ADF Path (idf.espAdfPath) false
Access to ESP-IDF Path (idf.espIdfPath) true
Access to ESP-MDF Path (idf.espMdfPath) false
Access to ESP-Matter Path (idf.espMatterPath) false
Access to ESP-HomeKit Path (idf.espHomeKitSdkPath) false
Access to ESP-IDF Custom extra paths
Access to <HOMEPATH>/.espressif/tools/xtensa-esp-elf-gdb/14.2_20240403/xtensa-esp-elf-gdb/bin: true
Access to <HOMEPATH>/.espressif/tools/riscv32-esp-elf-gdb/14.2_20240403/riscv32-esp-elf-gdb/bin: true
Access to <HOMEPATH>/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/riscv32-esp-elf/esp-13.2.0_20240530/riscv32-esp-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/esp32ulp-elf/2.38_20240113/esp32ulp-elf/bin: true
Access to <HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20240318/openocd-esp32/bin: true
Access to <HOMEPATH>/.espressif/tools/esp-rom-elfs/20240305: true
Access to Virtual env Python Path (idf.pythonBinPath) true
Access to CMake in environment PATH true
Access to Ninja in environment PATH true
Access to ESP-IDF Tools Path (idf.toolsPath) true
-------------------------------------------------------- Configurations has spaces -------------------------------------------------------------
Spaces in system environment Path true
Spaces in ESP-ADF Path (idf.espAdfPath) false
Spaces in ESP-IDF Path (idf.espIdfPath) false
Spaces in ESP-MDF Path (idf.espMdfPath) false
Spaces in ESP-Matter Path (idf.espMatterPath) false
Spaces in ESP-HomeKit-SDK Path (idf.espHomeKitSdkPath) false
Spaces in ESP-IDF Custom extra paths
Spaces in <HOMEPATH>/.espressif/tools/xtensa-esp-elf-gdb/14.2_20240403/xtensa-esp-elf-gdb/bin: false
Spaces in <HOMEPATH>/.espressif/tools/riscv32-esp-elf-gdb/14.2_20240403/riscv32-esp-elf-gdb/bin: false
Spaces in <HOMEPATH>/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin: false
Spaces in <HOMEPATH>/.espressif/tools/riscv32-esp-elf/esp-13.2.0_20240530/riscv32-esp-elf/bin: false
Spaces in <HOMEPATH>/.espressif/tools/esp32ulp-elf/2.38_20240113/esp32ulp-elf/bin: false
Spaces in <HOMEPATH>/.espressif/tools/openocd-esp32/v0.12.0-esp32-20240318/openocd-esp32/bin: false
Spaces in <HOMEPATH>/.espressif/tools/esp-rom-elfs/20240305: false
Spaces in Virtual env Python Path (idf.pythonBinPath) false
Spaces in ESP-IDF Tools Path (idf.toolsPath) false
----------------------------------------------------------- Executables Versions -----------------------------------------------------------
Git version 2.7.1
ESP-IDF version 5.3.1
Python version 3.12.6
Python's pip version 24.2
-------------------------------------------------- Project configuration settings ----------------------------------------------------------
-------------------------------------------------- Python packages in idf.pythonBinPath ----------------------------------------------------
annotated-types version: 0.7.0
argcomplete version: 3.5.0
bitarray version: 2.9.2
bitstring version: 4.2.3
certifi version: 2024.8.30
cffi version: 1.17.1
charset-normalizer version: 3.3.2
click version: 8.1.7
colorama version: 0.4.6
construct version: 2.10.70
cryptography version: 42.0.8
ecdsa version: 0.19.0
esp-coredump version: 1.11.0
esp-idf-kconfig version: 2.3.0
esp-idf-monitor version: 1.5.0
esp_idf_nvs_partition_gen version: 0.1.3
esp-idf-panic-decoder version: 1.2.1
esp-idf-size version: 1.6.0
esptool version: 4.8.0
freertos-gdb version: 1.0.3
idf-component-manager version: 2.0.3
idna version: 3.10
intelhex version: 2.3.0
jsonref version: 1.1.0
markdown-it-py version: 3.0.0
mdurl version: 0.1.2
packaging version: 24.1
pip version: 24.2
pyclang version: 0.5.0
pycparser version: 2.22
pydantic version: 2.9.2
pydantic_core version: 2.23.4
pydantic-settings version: 2.5.2
pyelftools version: 0.31
pygdbmi version: 0.11.0.0
Pygments version: 2.18.0
pyparsing version: 3.1.4
pyserial version: 3.5
python-dotenv version: 1.0.1
PyYAML version: 6.0.2
reedsolo version: 1.7.0
requests version: 2.32.3
requests-file version: 2.1.0
requests-toolbelt version: 1.0.0
rich version: 13.8.1
setuptools version: 71.0.0
six version: 1.16.0
tqdm version: 4.66.5
typing_extensions version: 4.12.2
urllib3 version: 1.26.20
---------------------------------------------------- Check ESP-IDF python requirements.txt -------------------------------------------------
Check ESP-IDF Python packages Python requirements are satisfied.
---------------------------------------------------- Check ESP-IDF debug adapter requirements.txt ------------------------------------------
Check Debug AdapterPython packages Error
---------------------------------------------------- Visual Studio Code launch.json --------------------------------------------------------
  "version": "0.2.0",
  "configurations": [
      "type": "gdbtarget",
      "request": "attach",
      "name": "Eclipse CDT GDB Adapter"
      "type": "espidf",
      "name": "Launch",
      "request": "launch"
---------------------------------------------------- Visual Studio Code c_cpp_properties.json ----------------------------------------------
    "configurations": [
            "name": "ESP-IDF",
            "compilerPath": "${config:idf.toolsPath}/tools/xtensa-esp-elf/esp-13.2.0_20240530/xtensa-esp-elf/bin/xtensa-esp32s3-elf-gcc",
            "compileCommands": "${config:idf.buildPath}/compile_commands.json",
            "includePath": [
                "${config:idf.espIdfPath}/components/**",
                "${config:idf.espIdfPathWin}/components/**",
                "${workspaceFolder}/**"
            "browse": {
                "path": [
                    "${config:idf.espIdfPath}/components",
                    "${config:idf.espIdfPathWin}/components",
                    "${workspaceFolder}"
                "limitSymbolsToIncludedHeaders": true
    "version": 4
----------------------------------------------------------- Latest error -----------------------------------------------------------------
    "code": 1,
    "killed": false,
    "signal": null,
    "cmd": "<HOMEPATH>/.espressif/python_env/idf5.3_py3.12_env/bin/python <HOMEPATH>/esp/esp-idf/tools/check_python_dependencies.py -r <HOMEPATH>/.vscode/extensions/espressif.esp-idf-extension-1.8.1/esp_debug_adapter/requirements.txt"
----------------------------------------------------------- Logfile -----------------------------------------------------------------
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T15:54:02.335Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T15:54:03.338Z"}
{"message":"Command failed: which -a python\n","stack":"Error: Command failed: which -a python\n\n\tat genericNodeError (node:internal/errors:984:15)\n\tat wrappedFn (node:internal/errors:538:14)\n\tat ChildProcess.exithandler (node:child_process:423:12)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T15:54:10.114Z"}
{"message":"Error finding python versions","stack":"Error: Command failed: which -a python\n\n\tat genericNodeError (node:internal/errors:984:15)\n\tat wrappedFn (node:internal/errors:538:14)\n\tat ChildProcess.exithandler (node:child_process:423:12)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","code":1,"killed":false,"signal":null,"cmd":"which -a python","level":"warn","timestamp":"2024-09-24T15:54:10.114Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T15:54:10.166Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T15:55:28.683Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T15:55:36.336Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T15:55:37.262Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T15:56:10.823Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T15:56:11.913Z"}
{"message":"non zero exit code 2\n\nesptool.py v4.8.0\nSerial port /dev/tty.SLAB_USBtoUART\n\nA fatal error occurred: Could not open /dev/tty.SLAB_USBtoUART, the port is busy or doesn't exist.\n([Errno 16] could not open port /dev/tty.SLAB_USBtoUART: [Errno 16] Resource busy: '/dev/tty.SLAB_USBtoUART')\n\n","stack":"Error: non zero exit code 2\n\nesptool.py v4.8.0\nSerial port /dev/tty.SLAB_USBtoUART\n\nA fatal error occurred: Could not open /dev/tty.SLAB_USBtoUART, the port is busy or doesn't exist.\n([Errno 16] could not open port /dev/tty.SLAB_USBtoUART: [Errno 16] Resource busy: '/dev/tty.SLAB_USBtoUART')\n\n\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T15:56:30.796Z"}
{"message":"non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.debug-console\nConnecting........","stack":"Error: non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.debug-console\nConnecting........\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T15:56:31.918Z"}
{"message":"non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.usbserial-21120\nConnecting...","stack":"Error: non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.usbserial-21120\nConnecting...\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T15:56:31.918Z"}
{"message":"non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.UEBOOM\nConnecting...","stack":"Error: non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.UEBOOM\nConnecting...\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T15:56:31.919Z"}
{"message":"non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.JabraHeadsetAdelaide\nConnecting...","stack":"Error: non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.JabraHeadsetAdelaide\nConnecting...\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T15:56:31.921Z"}
{"message":"non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.Bluetooth-Incoming-Port\nConnecting...","stack":"Error: non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.Bluetooth-Incoming-Port\nConnecting...\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T15:56:31.923Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:05:09.968Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:05:10.969Z"}
{"message":"non zero exit code 2\n\nesptool.py v4.8.0\nSerial port /dev/tty.usbserial-21120\n\nA fatal error occurred: Could not open /dev/tty.usbserial-21120, the port is busy or doesn't exist.\n([Errno 16] could not open port /dev/tty.usbserial-21120: [Errno 16] Resource busy: '/dev/tty.usbserial-21120')\n\n","stack":"Error: non zero exit code 2\n\nesptool.py v4.8.0\nSerial port /dev/tty.usbserial-21120\n\nA fatal error occurred: Could not open /dev/tty.usbserial-21120, the port is busy or doesn't exist.\n([Errno 16] could not open port /dev/tty.usbserial-21120: [Errno 16] Resource busy: '/dev/tty.usbserial-21120')\n\n\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T16:05:26.547Z"}
{"message":"non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.debug-console\nConnecting.........","stack":"Error: non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.debug-console\nConnecting.........\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T16:05:28.278Z"}
{"message":"non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.SLAB_USBtoUART\nConnecting....","stack":"Error: non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.SLAB_USBtoUART\nConnecting....\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T16:05:28.278Z"}
{"message":"non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.UEBOOM\nConnecting....","stack":"Error: non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.UEBOOM\nConnecting....\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T16:05:28.278Z"}
{"message":"non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.JabraHeadsetAdelaide\nConnecting....","stack":"Error: non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.JabraHeadsetAdelaide\nConnecting....\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T16:05:28.279Z"}
{"message":"non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.Bluetooth-Incoming-Port\nConnecting....","stack":"Error: non zero exit code null\n\nesptool.py v4.8.0\nSerial port /dev/tty.Bluetooth-Incoming-Port\nConnecting....\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1421636)\n\tat ChildProcess.emit (node:events:519:28)\n\tat ChildProcess._handle.onexit (node:internal/child_process:294:12)","level":"error","timestamp":"2024-09-24T16:05:28.279Z"}
{"message":"OpenOCD server failed to start because of Error: esp_usb_jtag: could not find or open device!\n❌ Error: esp_usb_jtag: could not find or open device!\n","stack":"Error: OpenOCD server failed to start because of Error: esp_usb_jtag: could not find or open device!\n\tat Socket.<anonymous> (/dist/extension.js:2:1452853)\n\tat Socket.emit (node:events:519:28)\n\tat addChunk (node:internal/streams/readable:559:12)\n\tat readableAddChunkPushByteMode (node:internal/streams/readable:510:3)\n\tat Readable.push (node:internal/streams/readable:390:5)\n\tat Pipe.onStreamRead (node:internal/stream_base_commons:191:23)","level":"error","timestamp":"2024-09-24T16:06:59.817Z"}
{"message":"OpenOCD server failed to start because of Error: \n❌ /Users/XXX/.espressif/tools/openocd-esp32/v0.12.0-esp32-20240318/openocd-esp32/share/openocd/scripts/target/esp_common.cfg:9: Error: \nat file \"/Users/XXX/.espressif/tools/openocd-esp32/v0.12.0-esp32-20240318/openocd-esp32/share/openocd/scripts/target/esp_common.cfg\", line 9\n","stack":"Error: OpenOCD server failed to start because of Error: \n\tat Socket.<anonymous> (/dist/extension.js:2:1452853)\n\tat Socket.emit (node:events:519:28)\n\tat addChunk (node:internal/streams/readable:559:12)\n\tat readableAddChunkPushByteMode (node:internal/streams/readable:510:3)\n\tat Readable.push (node:internal/streams/readable:390:5)\n\tat Pipe.onStreamRead (node:internal/stream_base_commons:191:23)","level":"error","timestamp":"2024-09-24T16:06:59.817Z"}
{"message":"OpenOCD Exit with non-zero error code 1","stack":"Error: Spawn exit with non-zero1\n\tat ChildProcess.<anonymous> (/dist/extension.js:2:1453522)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:305:5)","level":"error","timestamp":"2024-09-24T16:06:59.820Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:11:40.050Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:11:40.988Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:12:20.523Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:12:21.515Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:12:47.546Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:12:48.355Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:14:16.919Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:14:17.983Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:18:56.486Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:18:58.138Z"}
{"message":"Command failed: which -a python\n","stack":"Error: Command failed: which -a python\n\n\tat genericNodeError (node:internal/errors:984:15)\n\tat wrappedFn (node:internal/errors:538:14)\n\tat ChildProcess.exithandler (node:child_process:423:12)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:19:18.844Z"}
{"message":"Error finding python versions","stack":"Error: Command failed: which -a python\n\n\tat genericNodeError (node:internal/errors:984:15)\n\tat wrappedFn (node:internal/errors:538:14)\n\tat ChildProcess.exithandler (node:child_process:423:12)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","code":1,"killed":false,"signal":null,"cmd":"which -a python","level":"warn","timestamp":"2024-09-24T16:19:18.844Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:19:18.893Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:20:36.809Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:20:44.953Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:20:45.895Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:21:05.754Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-24T16:21:06.908Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-25T01:27:05.030Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-25T01:27:09.593Z"}
{"message":"Command failed: which -a python\n","stack":"Error: Command failed: which -a python\n\n\tat genericNodeError (node:internal/errors:984:15)\n\tat wrappedFn (node:internal/errors:538:14)\n\tat ChildProcess.exithandler (node:child_process:423:12)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:305:5)","level":"error","timestamp":"2024-09-25T03:31:39.251Z"}
{"message":"Error finding python versions","stack":"Error: Command failed: which -a python\n\n\tat genericNodeError (node:internal/errors:984:15)\n\tat wrappedFn (node:internal/errors:538:14)\n\tat ChildProcess.exithandler (node:child_process:423:12)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat ChildProcess._handle.onexit (node:internal/child_process:305:5)","code":1,"killed":false,"signal":null,"cmd":"which -a python","level":"warn","timestamp":"2024-09-25T03:31:39.251Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-25T03:31:39.391Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-25T03:31:40.644Z"}
{"message":"Cannot access filePath: ${env:ADF_PATH}","stack":"Error: ENOENT: no such file or directory, access '${env:ADF_PATH}'\n\tat Object.accessSync (node:fs:246:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9017)\n\tat Se (/dist/extension.js:2:1421806)\n\tat /dist/extension.js:2:1650824\n\tat ua (/dist/extension.js:2:1651892)\n\tat async /dist/extension.js:2:1868405","level":"error","timestamp":"2024-09-25T03:35:18.402Z"}
{"message":"Cannot access filePath: ${env:MDF_PATH}","stack":"Error: ENOENT: no such file or directory, access '${env:MDF_PATH}'\n\tat Object.accessSync (node:fs:246:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9017)\n\tat Se (/dist/extension.js:2:1421806)\n\tat /dist/extension.js:2:1651002\n\tat ua (/dist/extension.js:2:1651892)\n\tat async /dist/extension.js:2:1868405","level":"error","timestamp":"2024-09-25T03:35:18.402Z"}
{"message":"Cannot access filePath: ${env:ESP_MATTER_PATH}","stack":"Error: ENOENT: no such file or directory, access '${env:ESP_MATTER_PATH}'\n\tat Object.accessSync (node:fs:246:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9017)\n\tat Se (/dist/extension.js:2:1421806)\n\tat /dist/extension.js:2:1651094\n\tat ua (/dist/extension.js:2:1651892)\n\tat async /dist/extension.js:2:1868405","level":"error","timestamp":"2024-09-25T03:35:18.403Z"}
{"message":"Cannot access filePath: ${env:HOMEKIT_PATH}","stack":"Error: ENOENT: no such file or directory, access '${env:HOMEKIT_PATH}'\n\tat Object.accessSync (node:fs:246:11)\n\tat t.accessSync (node:electron/js2c/node_init:2:9017)\n\tat Se (/dist/extension.js:2:1421806)\n\tat /dist/extension.js:2:1651190\n\tat ua (/dist/extension.js:2:1651892)\n\tat async /dist/extension.js:2:1868405","level":"error","timestamp":"2024-09-25T03:35:18.403Z"}
{"message":"Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n","stack":"Error: Open On-Chip Debugger v0.12.0-esp32-20240318 (2024-03-18-18:24)\nLicensed under GNU GPL v2\nFor bug reports, read\n\thttp://openocd.org/doc/doxygen/bugs.html\n\n\tat /dist/extension.js:2:1424988\n\tat ChildProcess.exithandler (node:child_process:415:7)\n\tat ChildProcess.emit (node:events:519:28)\n\tat maybeClose (node:internal/child_process:1105:16)\n\tat Socket.<anonymous> (node:internal/child_process:457:11)\n\tat Socket.emit (node:events:519:28)\n\tat Pipe.<anonymous> (node:net:338:12)","level":"error","timestamp":"2024-09-25T03:35:19.437Z"}
JamesBlonde
Re: Can't launch monitor within VSCode (M1 Mac, MacOS Sequoia)
Postby JamesBlonde » Wed Sep 25, 2024 10:49 pm
bump
Anyone out there?
JamesBlonde
Postby JamesBlonde » Sat Sep 28, 2024 3:03 am
Espressif...you tell people to use this forum for support but I'm getting nothing.
Can someone please provide some guidance here?
radurentea
Postby radurentea » Mon Sep 30, 2024 8:33 am
Hi, sorry for late reply. I would recommend for future issues related to the esp-idf vs code extension, to open an issue directly on the github repo: https://github.com/espressif/vscode-esp ... ion/issues
Regarding your issue, I don't see any issue with the configuration and I was not able to reproduce it with a similar environment. The python paths being undefined in the doctor command is not an issue (it's a bug within the doctor command)
I would suggest to make a clean install of the extension. Uninstall it first following these steps: https://github.com/espressif/vscode-esp ... the-plugin. Sometimes there might be some esp-idf settings left overs in the settings.json both of your workspace and vs code user's settings. You can open both by using the command palette (CMD + shift + P) and just type "settings.json" (see screenshot) and remove any properties starting with "idf."
Let me know if this solved your issue
JamesBlonde
Postby JamesBlonde » Tue Oct 01, 2024 4:39 am
Thanks for you for the troubleshooting advice. I tried these steps (including clearing all key/value pairs in JSON files that contained IDF) but the problem persists - i can program & flash but not monitor from VS Code.
Did you have any other suggestions? I will also raise a ticket on GitHub repo as you recommended.
Update: Adding link to the GitHub ticket for posterity: https://github.com/espressif/vscode-esp ... ssues/1323
Thank you.
