Code: Untitled.c Select all
This sketch shows the Ethernet event usage
#define ETH_PHY_TYPE ETH_PHY_LAN8720
#define ETH_PHY_ADDR 0
#define ETH_PHY_MDC 23
#define ETH_PHY_MDIO 18
#define ETH_CLK_MODE ETH_CLOCK_GPIO0_OUT
#define ETH_PHY_POWER 4
#include <ETH.h>
IPAddress staticIP(192, 168, 127, 244);
IPAddress gateway(192, 168, 127, 1);
IPAddress subnet(255, 255, 255, 0);
static bool eth_connected = false;
void WiFiEvent(WiFiEvent_t event)
switch (event) {
case ARDUINO_EVENT_ETH_START:
Serial.println("ETH Started");
//set eth hostname here
ETH.setHostname("esp32-ethernet");
case ARDUINO_EVENT_ETH_CONNECTED:
Serial.println("ETH Connected");
case ARDUINO_EVENT_ETH_GOT_IP:
Serial.print("ETH MAC: ");
Serial.print(ETH.macAddress());
Serial.print(", IPv4: ");
Serial.print(ETH.localIP());
if (ETH.fullDuplex()) {
Serial.print(", FULL_DUPLEX");
Serial.print(", ");
Serial.print(ETH.linkSpeed());
Serial.println("Mbps");
eth_connected = true;
case ARDUINO_EVENT_ETH_DISCONNECTED:
Serial.println("ETH Disconnected");
case ARDUINO_EVENT_ETH_STOP:
Serial.println("ETH Stopped");
default:
void testClient(const char * host, uint16_t port)
Serial.print("\nconnecting to ");
Serial.println(host);
WiFiClient client;
if (!client.connect(host, port)) {
Serial.println("connection failed");
return;
client.printf("GET / HTTP/1.1\r\nHost: %s\r\n\r\n", host);
while (client.connected() && !client.available());
while (client.available()) {
Serial.write(client.read());
Serial.println("closing connection\n");
client.stop();
void setup()
WiFi.onEvent(WiFiEvent);
pinMode(ETH_PHY_POWER, OUTPUT);
digitalWrite(ETH_PHY_POWER, HIGH);
if (!ETH.begin(ETH_PHY_ADDR, ETH_PHY_POWER, ETH_PHY_MDC, ETH_PHY_MDIO, ETH_PHY_TYPE)) {
Serial.println("ETH start Failed!");
else{ ETH.config(staticIP, gateway, subnet);
void loop()
Serial.println(ETH.localIP());
delay(1000);
