Gamepad descriptor
Volanaro
Gamepad descriptor
Postby Volanaro » Sun Sep 29, 2024 9:11 am
hey guys so im making a 2 button game pad for a sequencal shifter. i have everything working, but i want to change how windows see's it, at the moment it sees it as 8 axis 2 button device, in "game Controllers", how do i get it to see it as "sequencal shifter"
i get i need to use descriptor, but no idea how to do that, iv tired diffrent methords, but nothing works, im using the latest BleGamepad and NimBLE:
#include <BleGamepad.h>
#include <BleGamepadConfiguration.h>
// Pin Definitions
const int BUTTON_1_PIN = 12;  // Pin for Button 1
const int BUTTON_2_PIN = 13;  // Pin for Button 2
// Create a gamepad configuration
BleGamepadConfiguration config;
// Initialize the gamepad instance with the name 'Gamepad Shifter'
BleGamepad gamepad("Sequential Shifter", "Craig Jenkins", 100);
    // Setup the gamepad configuration explicitly
    config.setModelNumber("Sequential Shifter");
    config.setSoftwareRevision("1.0");
    config.setSerialNumber("123456789");
    config.setFirmwareRevision("1.0");
    config.setHardwareRevision("1.0");
    config.setVid(0x1234);  // Set your Vendor ID
    config.setPid(0x5678);  // Set your Product ID
    config.setGuidVersion(0x0110); // Set your GUID Version
    // Only declare buttons
    config.setButtonCount(2); // Set button count to 2
    config.setHatSwitchCount(0); // No hat switches
    gamepad.begin(&config); // Initialize with the configuration
    // Setup button pins as input with pull-ups
    pinMode(BUTTON_1_PIN, INPUT_PULLUP);
    pinMode(BUTTON_2_PIN, INPUT_PULLUP);
    static bool button1State = false;
    static bool button2State = false;
    bool currentButton1State = digitalRead(BUTTON_1_PIN) == LOW;  // Low means pressed
    bool currentButton2State = digitalRead(BUTTON_2_PIN) == LOW;  // Low means pressed
    // Button 1 Logic
    if (currentButton1State != button1State) {
        button1State = currentButton1State;
        if (button1State) {
            gamepad.press(1); // Press Button 1
            Serial.println("Button 1 Pressed");
            gamepad.release(1); // Release Button 1
            Serial.println("Button 1 Released");
    // Button 2 Logic
    if (currentButton2State != button2State) {
        button2State = currentButton2State;
        if (button2State) {
            gamepad.press(2); // Press Button 2
            Serial.println("Button 2 Pressed");
            gamepad.release(2); // Release Button 2
            Serial.println("Button 2 Released");
    // Send updated gamepad state
    gamepad.sendReport();
    // Add a delay to debounce button presses
    delay(10);
Users browsing this forum: Baidu [Spider], YisouSpider and 2 guests
