Memory problem with MQTT and new()
Jonathan2892
Postby Jonathan2892 » Wed Oct 02, 2024 2:27 pm
I have a project which is mainly written in C++ and uses a lot of
new()
. Somehow this causes the MQTT-client to not be able to allocate memory. I have tried to fix this problem by using different sdkconfig options, but I wasn't able to solve the problem. The free HEAP before the mqtt-client tries to allocate its memory is around 4MB, so should be more than enough.
In sdkconfig I have:
CONFIG_SPIRAM_USE_MALLOC=y
CONFIG_SPIRAM_MEMTEST=y
CONFIG_SPIRAM_MALLOC_ALWAYSINTERNAL=2048
CONFIG_SPIRAM_TRY_ALLOCATE_WIFI_LWIP=y
CONFIG_SPIRAM_MALLOC_RESERVE_INTERNAL=32768
CONFIG_SPIRAM_ALLOW_BSS_SEG_EXTERNAL_MEMORY=y
CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC=y
CONFIG_MQTT_TASK_CORE_SELECTION_ENABLED=y
CONFIG_MQTT_USE_CORE_0=y
Now I wonder, if
new()
always goes into internal memory and mqtt needs some space there and can not be completely allocated in external memory?
Do I need to tell
new()
to allocate specifically in external memory?
Setup:
- esp32s3-N16R8
- esp-idf 5.3.1
Hope someone can help...
Best
MicroController
Re: Memory problem with MQTT and new()
Postby MicroController » Wed Oct 02, 2024 4:57 pm
Now I wonder, if
new()
In this case it does for all objects smaller than 2KB.
That is likely the case.
Do I need to tell
new()
Yes, if you explicitly want an object in external RAM.
You can do this by manually allocating sizeof(X) bytes from the heap in external RAM, then use the placement new operator with that memory.
Users browsing this forum: Amazon [Bot] and 2 guests
