ESP32 has been refused by HTTPS connection
tankist
Postby tankist » Thu Oct 10, 2024 10:56 am
I use https://github.com/earlephilhower/ESP8266Audio library for listening web radio streams. It works pretty well except the case I try to connect to HTTPS servers instead of HTTP. In my country almost no radio broadcasting via HTTP, all station use HTTPS.
I found out the problem is in HTTP request. It looks like
  HTTPClient http;
  bool res = http.begin(client, url);
  http.addHeader("Icy-MetaData", "1");
  http.collectHeaders( hdr, 4 );
  http.setReuse(true);
  http.setFollowRedirects(HTTPC_FORCE_FOLLOW_REDIRECTS);
  int code = http.GET();
And after that http.GET() returns -1 that means HTTPC_ERROR_CONNECTION_REFUSED. "client" has type as NetworkClient and it has no any methods to set certificate as I found out. All examples I found only concern WiFiClientSecure class so I do'n know if it's the issue of the certificate or not.
The example requested URL is "https://stream2.datacenter.by/radiomir" and it work well in my desktop audio player.
Any suggestions how to fix that?
lbernstone
Re: ESP32 has been refused by HTTPS connection
Postby lbernstone » Wed Oct 16, 2024 4:24 am
https://github.com/espressif/arduino-es ... Client.ino
You must supply a certificate, or tell NetworkClientSecure to setInsecure.
Users browsing this forum: PerplexityBot, Semrush [Bot] and 1 guest
