If you try to set a different log level for a tag that has already emitted some log messages, the change won't take effect unless the tag string in the call is exactly the same const char* pointer as is used in the log messages.
The problem is that the code only does a fast search of the cache, meaning that is looks for the tag string address rather than doing a strcmp to accept a match of a different instance of the same string.
So this function would be effective in a very limited case, but if an application implements a command to change log levels for a collection of components within the application it is likely that the tag string will be collected in a buffer of the command parser, it won't be the exact const char* string defined within the component that will be logging with that tag.
For my own fork of v2.1 I modified log.c so that esp_log_level_set() would do the slow search of the cache. I could not merge that code directly to master because of commit cfd95b62c that implemented the fast search of the cache. If I modify the code again on master and issue a PR, might you accept it?
esp_log_level_set() for a tag is not effective if tag has already logged
Re: esp_log_level_set() for a tag is not effective if tag has already logged
Looks like a bug, and something we would accept a PR for if you submit it. As far as i understand this means replacing
`if (s_log_cache.tag == tag) {`
with
`if (strcmp(s_log_cache.tag, tag) == 0) {`,
right?
with
right?
Yes, the change to strcmp is the essence of the change. When I implemented this, I followed what was done in get_cached_log_level() to update the item generation as well, but I don't know important that is. I am attaching the diff of my change and will take your advice about whether the generation update should be done. Part of my change was in updating the existing uncached entry; that has already been implemented in cfd95b62c. Also I noticed a bug in a comment in my change: "Set new level from cache" should read "Set new level in cache".
- log.c.diff.txt
- (2.92 KiB) Downloaded 1063 times
To close the loop, this problem is being addressed in PR 1557.
Users browsing this forum: trendictionbot and 0 guests
