I'm trying to setup an application that uses ESP-C6 with ESP-AT 4.0 for sending/receiving some data over BLE SPP.
I'm doing the following steps:
ATE0
AT+SYSLOG=1
AT+SYSMSG=5
AT+BLEINIT=2
AT+BLEADVPARAM=32,32,0,0,7,0
AT+BLEADVDATAEX=adv_params
AT+BLEADVSTART
Once connection is received from ESP via
+BLECONN:0, remote_addr
I'm setting up the SPP connection
AT+BLECONNPARAM=0,6,6,0,30
AT+BLESPPCFG=config
AT+BLESPP
After ">" response is received data is sent via SPP.
After a period of time I want shutdown the SPP and disconnect from the client and do:
+++ - for exiting the passtrough mode. I do receive the confirmation message from ESP: +QUITT
AT+BLEDISCONN=0
After sending the disconnection request AT command ESP seems to not responding anymore until I reset the ESP.
I suspected that it might be something on my end, hence I tried sending another command and seems to be working
AT+BLECFGMTU?
+BLECFGMTU:0,23
I also tried to message that sets data:
AT+BLESETPHY=0,2
+BLESETPHY:remote,2,2
What worked and triggered a disconnection, by receiving an asynchronous message, of the ESP server from the client was deinitializing the BLE
AT+BLEINIT=0
I tried to check whether sending AT+BLEDISCONN=0 might provide any response after the BLE has been deinitialized. I experienced the same issue.
Any thoughts on what I might be doing wrong here?
Is it possible that AT+BLEDISCONN=0 is intended only for client role and not for server role? The only instance I found in the manual for this commands was for client role, hence the questions.
Any advice or information is highly appreciated.
AT+BLEDISCONN blocking issue
Re: AT+BLEDISCONN blocking issue
Tested with ESP32C6 version v4.0.0.0 AT version firmware, no related issues were found. Please use the AT firmware on the esp-at master branch to test whether this problem still exists. If this problem still exists, please provide detailed logs of the AT command port and log port with timestamps.
Thank you for coming back to me with your reply.
I will come back with a series of traces as soon I can. I have the ESP on a custom PCB and is controlled by a different micro controller.
What I can say is that the version I did use was a snapshot of the master branch from Sept 2024 (technically newer than the v4.0.0.0 which was released on 29Dec 2023).
