Requirement 'esptool~=4.8' was not met. Installed version: 4.8.dev5
zhangdi0615
Postby zhangdi0615 » Sat Oct 26, 2024 3:42 am
安装Espressif IDF后,编译时,出现这个问题。 请求帮助,请各位大咖帮忙给给建议
由于是使用公司电脑安装的。公司网络有一些限制,有一些网站不能访问或下载,不确定是不是影响到软件安装了
The following Python requirements are not satisfied:
To install the missing packages, please run "install.bat"
Diagnostic information:
IDF_PYTHON_ENV_PATH: C:\Espressif\python_env\idf5.3_py3.11_env
Python interpreter used: C:\Espressif\python_env\idf5.3_py3.11_env\Scripts\python.exe
Constraint file: C:/Espressif\espidf.constraints.v5.3.txt
Requirement files:
- C:/Espressif/frameworks/esp-idf-v5.3.1/tools\requirements\requirements.core.txt
Python being checked: C:\Espressif\python_env\idf5.3_py3.11_env\Scripts\python.exe
ESP-IDF v5.3.1-dirty
Luxni_
Re: Requirement 'esptool~=4.8' was not met. Installed version: 4.8.dev5
Postby Luxni_ » Tue Nov 05, 2024 9:53 am
已经影响了,你的环境没有搭建好。
