ESP32-S3 SPI interface to RC522
haz_coder
Postby haz_coder » Sat Oct 26, 2024 4:02 pm
I have been trying for the past 2 days to get the SPI working on my sample project. I have the ESP32-S3 connected to the RC522.
For the life of me, I am not able to get them to communicate properly.
Here is what I tried:
First, I ran the project with:
// Serial.print("MOSI: ");
  // Serial.println(MOSI);
  // Serial.print("MISO: ");
  // Serial.println(MISO);
  // Serial.print("SCK: ");
  // Serial.println(SCK);
  // Serial.print("SS: ");
  // Serial.println(SS);
The output I got matches my pin assignment:
// Setup SPI2 pins
const int SPI2_MISO = 13;
const int SPI2_MOSI = 11;
const int SPI2_SCK  = 12;
Here is my complete code. I only have a single RC522 connected for now to get it working.
I have the reset pin tied high, and the SDA pin tied low, so I am only trying to debug the communication lines, without any control lines, so I narrow down my debug.
Here is the complete code:
#include <Arduino.h>
#include <SPI.h>
#include <MFRC522.h>
// Setup SPI2 pins
// Create an instance of the SPIClass for SPI2-HSPI
SPIClass hspi = SPIClass(HSPI);
// Setup MFRC522
const byte NR_OF_READERS = 3;
const int RST_PIN = 8;   // Define Reset pin
const int IRQ_PIN_0 = 7;   // Define the interrupt pin
const int IRQ_PIN_1 = 16; // CHANGE...CONFLICTS WITH NEXTION
const int IRQ_PIN_2 = 10;
const int SS_PIN_0 = 15;  // Define SS for all 3 RC522
const int SS_PIN_1 = 9;
const int SS_PIN_2 = 14;
// Define SPI pin arrays
byte ssPins[] = {SS_PIN_0, SS_PIN_1, SS_PIN_2};
byte irqPins[] = {IRQ_PIN_0, IRQ_PIN_1, IRQ_PIN_2};
// Define
byte UIDCard[NR_OF_READERS][4];  // Matrix for storing UID over each reader
MFRC522 mfrc522[NR_OF_READERS];     // Create MFRC522 instances
// Forward declaration of handleRFIDInterrupt
void ICACHE_RAM_ATTR handleRFIDInterrupt();
// Forward declaration of writeStringToBlock
void writeStringToBlock(MFRC522 &rfid, byte blockAddr, String data);
// Forward declaration of readStringFromBlock
void readStringFromBlock(MFRC522 &rfid, byte blockAddr);
void initSPI2() {
  // Initialize the SPI2 bus
  hspi.begin(SPI2_SCK, SPI2_MISO, SPI2_MOSI, SS_PIN_0);
// Initialize RC522
void initRC522() {
  for (byte i = 0; i < NR_OF_READERS; i++) {
    mfrc522[i].PCD_Init(ssPins[i], RST_PIN); // Init each MFRC522 card
    mfrc522[i].PCD_DumpVersionToSerial();
    // Configure the interrupt pin
    pinMode(irqPins[i], INPUT_PULLUP);
    attachInterrupt(digitalPinToInterrupt(irqPins[i]), handleRFIDInterrupt, FALLING);
// ISR to handle RFID interrupt
void ICACHE_RAM_ATTR handleRFIDInterrupt() {
  // Loop through all readers to check the IRQ pin state
    // Check if the IRQ pin is LOW (indicating an interrupt)
    if (digitalRead(irqPins[i]) == LOW) {
      // Check if a new card is present
      if (mfrc522[i].PICC_IsNewCardPresent() && mfrc522[i].PICC_ReadCardSerial()) {
        Serial.print("Card detected on reader ");
        Serial.println(i);
        // Retrieve and print the UID
        Serial.print("Card UID: ");
        for (byte j = 0; j < mfrc522[i].uid.size; j++) {
          Serial.print(mfrc522[i].uid.uidByte[j] < 0x10 ? " 0" : " ");
          Serial.print(mfrc522[i].uid.uidByte[j], HEX);
        Serial.println();
        // Write a string to block 4
        writeStringToBlock(mfrc522[i], 4, "Hello, RFID!");
        // Read data from block 4
        readStringFromBlock(mfrc522[i], 4);
        mfrc522[i].PICC_HaltA(); // Halt PICC
  // Serial port for debugging purposes
  // Initialize SPI2
  initSPI2();
  // Initialize RC522
  initRC522();
void writeStringToBlock(MFRC522 &rfid, byte blockAddr, String data) {
  byte buffer[18];
  data.getBytes(buffer, sizeof(buffer));
  // Ensure the data fits in the block (16 bytes)
  if (data.length() > 16) {
    Serial.println("Data too long for block");
    return;
  // Pad the buffer with zeros if necessary
  for (byte i = data.length(); i < 16; i++) {
    buffer[i] = 0;
  MFRC522::StatusCode status = rfid.MIFARE_Write(blockAddr, buffer, 16);
  if (status != MFRC522::STATUS_OK) {
    Serial.print("MIFARE_Write() failed: ");
    Serial.println(rfid.GetStatusCodeName(status));
    Serial.println("Data written to block successfully");
void readStringFromBlock(MFRC522 &rfid, byte blockAddr) {
  byte buffer[18];
  byte size = sizeof(buffer);
  MFRC522::StatusCode status = rfid.MIFARE_Read(blockAddr, buffer, &size);
    Serial.print("MIFARE_Read() failed: ");
    return;
  Serial.print("Data from block ");
  Serial.print(blockAddr);
  Serial.print(": ");
  for (byte i = 0; i < 16; i++) {
    Serial.write(buffer[i]);
  Serial.println();
The output keeps giving me this:
Firmware Version: 0x0 = (unknown)
WARNING: Communication failure, is the MFRC522 properly connected?
Using VS Code with PlatformIO.
.ini:
[env:esp32-s3-devkitc-1]
platform = espressif32
board = esp32-s3-devkitc-1
framework = arduino
monitor_speed = 115200
lib_deps =
miguelbalboa/MFRC522@^1.4.11
Any help is appreciated. I have scoured the internet for a solution. SPI should not be that hard...not sure why it's made so hard.
haz_coder
Re: ESP32-S3 SPI interface to RC522
Postby haz_coder » Sun Oct 27, 2024 11:42 pm
I figured it out.
Replaced hspi with just SPI in the below
hspi.begin(SPI2_SCK, SPI2_MISO, SPI2_MOSI, SS_PIN_0);.
So SPI.Begin...
Works given I am using the standard pins. Not sure how you'd go about using SPI2 or SPI3 with your pins...don't need it for my project, but not straight forward it seems.
There is a few other items in the code that I had to change for properly setting up the IRQ, but had to get the SPI working to get to the rest.
woosop
Postby woosop » Mon Mar 17, 2025 3:28 pm
Hi, I am trying to configure XIAO ESP32-C3 with RC522. Do you have any suggestions? Can it be possible?
woo
lbernstone
Postby lbernstone » Wed Mar 19, 2025 1:32 am
AFAIK the example should work. Just call SPI.begin with the correct parameters.
horace99
Postby horace99 » Sun Mar 23, 2025 10:50 am
this works on a ESP32-C3-MINI-1
Code: Untitled.cpp Select all
// ESP32-C3 MRFC522 RFID reader
#include <MFRC522v2.h>
#include <MFRC522DriverSPI.h>
#include <MFRC522DriverPinSimple.h>
#include <MFRC522Debug.h>
// ESP32-C3 pins used by MFRC522 RFID reader (VCC to 3.3V)
#define SCK 4
#define MISO 5
#define MOSI 6
#define CS 7
MFRC522DriverPinSimple ss_1_pin(CS); // Configurable, take an unused pin, only HIGH/LOW required, must be different to SS 2.
MFRC522DriverSPI driver_1{ ss_1_pin};
MFRC522 reader = driver_1; // Create MFRC522 instance.
Serial.begin(115200); // Initialize serial communications with the PC for debugging.
while (!Serial)
; // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4).
Serial.println("\n\nESP32-C3 MFRC522");
reader.PCD_Init(); // Init each MFRC522 card.
Serial.print(F("Reader "));
static uint8_t i = 0;
i++;
Serial.print(i);
Serial.print(F(": "));
MFRC522Debug::PCD_DumpVersionToSerial(reader, Serial);
* Main loop.
delay(2000);
Serial.println("reading RFID");
// Look for new cards.
if (reader.PICC_IsNewCardPresent() && reader.PICC_ReadCardSerial()) {
i++;
Serial.print(i);
// Show some details of the PICC (that is: the tag/card).
Serial.print(F(": Card UID:"));
MFRC522Debug::PrintUID(Serial, reader.uid);
Serial.println();
Serial.print(F("PICC type: "));
MFRC522::PICC_Type piccType = reader.PICC_GetType(reader.uid.sak);
Serial.println(MFRC522Debug::PICC_GetTypeName(piccType));
// Halt PICC.
reader.PICC_HaltA();
// Stop encryption on PCD.
reader.PCD_StopCrypto1();
serial output
ESP32-C3 MFRC522
Reader 1: Firmware Version: 0x92 = v2.0
reading RFID
reading RFID
Reader 1: Card UID: 15 64 FD C2
PICC type: MIFARE 1KB
reading RFID
reading RFID
reading RFID
reading RFID
reading RFID
Reader 2: Card UID: BF EC 0C 04
reading RFID
reading RFID
reading RFID
Reader 3: Card UID: C3 65 94 95
Users browsing this forum: Applebot, Qwantbot and 1 guest
