I use the VS-code (latest version) on a Windows 11 PC with the framework 5.3.1.
When I start a new project and set the target to ESP32-S3, I get a message saying the environment variable is set to ESP32. The message is:
Target 'esp32s3' specified on command line is not consistent with target 'esp32' in the environment.
I have set the target by the command idf.py set-target esp32s3
How do I change the environment setting from esp32 to esp32s3?
There are various suggestions coming up, when I search for a solution. I have tried several of them, but the error message is still there.
Regards,
Jorgen
Target in environment
MicroController
Re: Target in environment
The "other" target to set is the environment variable IDF_TARGET.
Not sure how to make VScode set this variable for the build process inside the IDE though.
Thanks MicroController.
The problem has been reported before and workarounds have been suggested. I have found one and it works for me, provided, I do the three steps right after creating a new project. I have not made any exhaustive investigation trying out several combinations.
I hope this is read by someone involved in the development/coding of the ESP-IDF. To that person, please change the ESP-IDF such that the command:
really sets the target everywhere necessary including the environment variable ESP_TARGET and also on the bottom line in VS code.
Regards,
Jorgen
Regards,
Jorgen
Gypsy_Smyth
I do not know if you ever found a fix for this. I found this post because I was having the same problem. I found the following page:
https://www.cnblogs.com/HoNorthNorth/p/17944546
which covers how to fix this in VSCode. You may need a translator for this, but their instructions did work for me.
