I want to port an ESP8266-based (+ host CPU) solution to the ESP32. Currently I have a number (2-4) of high-speed ADCs controlled by a host CPU via SPI using 16-bit data words (hence need 2-4 hardware controlled CSn lines). Samples are then stored to an SD card or transferred via UART to the ESP8266 with a transparent UART-to-WiFi firmware. Now I would like to remove the host CPU and use the ESP32 (actually an ESP-WROOM-32 module) to control the ADCs and stream out raw data directly via a Wi-Fi link using DMA having the Wi-Fi possibly configured as (soft-)AP. The best scenario would be using one core (e.g. CPU0) for continuous ADC sampling and the other core (e.g. CPU1) for continuous data transfer (payload bit rate should be >= 9Mbps!).
My questions:
- Is it possible to configure an SPI (and which one) as a master with 16-bit data word (i.e. assert CS, transfer 16 bit, de-assert CS)?
- Is there any reference on how to configure the SPI registers and use DMA to transfer data to the Wi-Fi stack (TCP/UDP)?
ESP32 as an SPI ADC sampler and Wi-Fi broadcast questions
- luca.gamma
Re: ESP32 as an SPI ADC sampler and Wi-Fi broadcast questions
Yes, it's most definitively possible to transfer in 16 bit of information. We're working on SPI documentation and drivers. Documentation probably will be included in the very next documentation release; the driver is scheduled to go into esp-idf 1.0.
- luca.gamma
Thanks for your answer, this sounds very interesting. Do you think it could be possible to have a preview of the SPI driver? While my question is about the timing I would like to be sure that SPI and GPIO are fast enough to control 4 devices (even using 4x GPIOs as chip select).
Users browsing this forum: Applebot, Semrush [Bot] and 2 guests
