Hallo at every one,
I just installed IDE Eclipse and at the end I add ESP IDF from the web 5.3.1.
When I try to start, I import an example "Hello World", but to build I have this error message.
CMake Error: CMake was unable to find a build program corresponding to "MinGW Makefiles". CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
I forget something? Need to install any other tools?
Thank you in advance,
Valter
Problem on IDE Eclipse
Re: Problem on IDE Eclipse
your lucky to get that far, I can't add the IDF in to the IDE as it throws errors.
So your doing better than me mate.
Hi, thanks for your share. I'm worried, but eclipse IDE is running. Someone use it?
Users browsing this forum: ChatGPT-User, Qwantbot and 8 guests
