Problem on IDE Eclipse
Posted: Thu Nov 21, 2024 5:22 pm
by Valter
Hallo at every one,
I just installed IDE Eclipse and at the end I add ESP IDF from the web 5.3.1.
When I try to start, I import an example "Hello World", but to build I have this error message.
CMake Error: CMake was unable to find a build program corresponding to "MinGW Makefiles". CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
I forget something? Need to install any other tools?
Thank you in advance,
Valter
Re: Problem on IDE Eclipse
Posted: Sat Nov 23, 2024 12:28 pm
by Teh2024
your lucky to get that far, I can't add the IDF in to the IDE as it throws errors.
So your doing better than me mate. :-(
Posted: Mon Nov 25, 2024 9:43 am
by Valter
Hi, thanks for your share. I'm worried, but eclipse IDE is running. Someone use it?
