Is my Wemos D1 mini working correctly ?
Posted: Fri Nov 29, 2024 3:08 pm
by daba1955
I'm developing a project to automate the flushing of some gent's urinals at a venue.
i'm using an AM312 PIR module as a "footfall" detector, the output is connected to D2 of the Wemos D1 mini, but the input never goes low, I've measured the voltage on pin D2 at 2.8V with the PIR unplugged. The PIR gives a HIGH output when it senses body movement, but I don't think it has output capability to pull the input LOW when it relaxes.
So, I thought about using an NPN transistor to pull the input LOW when the AM312 output goes HIGH, however, I measured the current from pin D2 to GND and was surprised it was a hefty 84mA. Is this normal for an ESP8266 input ?
Re: Is my Wemos D1 mini working correctly ?
Posted: Sat Nov 30, 2024 8:45 am
by daba1955
I think the answer lies here....
" NodeMCU/ESP8266 has 17 GPIO pins which can be assigned to functions such as I2C, I2S, UART, PWM, IR Remote Control, LED Light and Button programmatically. Each digital enabled GPIO can be configured to internal pull-up or pull-down, or set to high impedance. When configured as an input, it can also be set to edge-trigger or level-trigger to generate CPU interrupts."
Since my PIR is active-high, I believe I need to set D2 as PULL_DOWN, but I have no idea how to do that in Arduino code.
Whilst I am continuing to research this, can someone please enlighten me...
Posted: Mon Jul 21, 2025 5:40 pm
by jgrunschel
If you are using the Arduino IDE, then this forum post in the Arduino Forums claims you can use the following command:
pinMode(4, INPUT_PULLDOWN);
Forum URL for reference:
https://forum.arduino.cc/t/pullup-and-pulldown/657225
FYI, according to the following image, D2 is GPIO4, which should be referred to as 4 in code, but I am not certain.
However, the Arduino documentation does not claim to support INPUT_PULLDOWN.
https://docs.arduino.cc/language-refere ... o/pinMode/
It is annoying to have to add hardware, but you could add your own resistor (10k) between the pin and ground. The following link gives an in-depth explanation of everything.
https://deepbluembedded.com/arduino-pin ... -pulldown/
Lastly, I have a WROOM D1 Mini (it is close to a Wemos D1 Mini), and used the following code to get it to work:
int ledPin = 2;  // LED connected to digital pin 13
int inPin = 27;  // pushbutton connected to digital pin 7
bool val = 0;    // variable to store the read value
void setup() {
  pinMode(ledPin, OUTPUT);           // sets the digital pin 2 as output
  pinMode(inPin, INPUT_PULLDOWN);    // sets the digital pin 27 as input
void loop() {
  val = digitalRead(inPin);   // read the input pin
  digitalWrite(ledPin, val);  // sets the LED to the button's value
Here is the pinout:
WROOM Mini D1 Pinout.png (253.5 KiB) Viewed 183 times
All I did was use a Dupont Female-Female Jumper between 3.3V and GPIO27 to "toggle" the onboard LED.
For reference, I changed the input pin mode to just INPUT, and when I removed the jumper wire, the pin "floated" until the voltage fell below the digital pin threshold. This caused the LED to flicker and "die". It makes for an interesting effect, but terrible as a user interface.
Hope this helps.
