How can I check and analyze the sniffer log and determine the network bitrate?
Hi everyone.. I already have a fully functional thread network, no surprise... Anyway, now I'm testing the behavior of the thread network using the Wireshark sniffer (tutorial on the OpenThread website).
The test I started was to send a payload between nodes, send random generated data and send it over the network.
To send the data, I used C code that sends data to another node, testing the behavior and whether the network would support the data being transferred, knowing the 250kbps limit that the thread network supports. The data is generated randomly in 500 bytes increments and sent to the receiving node until the last 5000 byte packet is received. This data is sent at an interval of 30 seconds.
I'm having trouble determining the data rate (bitrate) used in a payload on my thread network. Attached is a packet capture made by Wireshark (file in zip format because the site does not support attachments with the *.pcapng extension) using the tutorial on the OpenThread website. If you can analyze it and help me determine the network usage, data rate, etc. I would be very grateful.
Users browsing this forum: Google [Bot], trendictionbot and 2 guests
